Question about Eagle Industries FishElite 640C GPS Receiver
Hello, I bought a 640c from a friend of mine but he lost the SD card. I'm trying to order the map for Japan from Navionics but it won't let me download to a regular 2 Gig SD card. Do I have to have a specific card to do this. Help
  • 1 more comment
  • vitamin_sea Oct 03, 2010
    Thanks,
    I have a regular size Panasonic 4GB SD card but when I go to the Navionics web store it will not let me get past the section that states that it is locating the Navionics card. It does not find the card that is in the slot. The computer sees it Ok. I'm stuck
  • vitamin_sea Oct 04, 2010
    I reformatted and had the same results. Try it yourself with a regular SD card. However at another site "Fugawi" I can order the card already loaded. It indicates that its a CF card. Also on the capatability chart it shows that it may use a micro SD card. Stuck.
    I tried using a 4GB SD card with no results. Navionics site will not let me get past that as it's looking for the Navionics card. Another chart site "Fugawi" indicates that I can order the card CF type from them already loaded but the area coverage cost a bit more than I need.
You will need a 4GB SD card or better to download the map from Japan on your 640c. Click on the link below to order:
http://cgi.ebay.com/4GB-SD-SDHC-Secure-Digital-Flash-Memory-Card-Camera-/200527110210?pt=Digital_Camera_Memory_Cards&hash=item2eb058e042
Posted on Oct 04, 2010
    President:
  • 1,139 Answers
Hi, no you should not need any specific SD card but some devices are a bit picky about how they are formatted. I would advise putting the SD card into your computer and formatting it to FAT32, not NTFS or any other filing system. Try downloading the map to your computer first and then transferring it to your SD card afterwards if that is possible.
Hope this helps
Posted on Oct 03, 2010
    President:
  • 1,216 Answers
The problem is you lost your original card Ya???
Before i give you the answer i want to let you know that your machine has 2 Expansion Slot Type SD (Secure Digital) Card Slot, MultiMediaCard (MMC) slot
that means that you can only use an sd card or an mmc card which will work perfectly.
Now it may be possible that you are using a micro sd card or mini sd card instead of an sd card which is not compatible with your device.i can say that because we use micro sd in mobiles . camcorders,cameras etc. so may be you had taken that.Check your card and tell me this.
One thing more if you are using a correct card you may lack memory due to which this error had occured.
Finally answering the lagt line of your question , just get an SD card or an MMC card from the market for your device and this will be fully compatible.
Thanks.
Please accept the solution if helped.
Regards
Will the hds7 gen 2 read navionics lake map?
Yes, all Lowrance products will use and display Navionics map data.
Compatibility Guide America
Here is a link to the navionics compatability page so you can see which map cards will work in your unit.
Feb 03, 2015 | Lowrance HDS7 GEN2 Insight 83/200KHZ
My IPad worked well with Navionics untill few days ago, then following problem appeared: when running my boat with trolling speed ( like 2 mph) the screen shows my position on map with the red arrow and...
Go into Settings - Navionics App and make sure that Mobile Data is enabled and also Background App Refresh. Finally, Location set to Always. It sounds like it is not being updated, but just setting your position on opening.
It is not a particularly good app and very basic although I have not tried the Paid version. I have a Humminbird 998 HD Side Imaging and the Navionics Mappind SD Card which gives much better results.
Aug 05, 2017 | Lands Phones
Navionics Gold charts will not display on a Lowrance Endura
i have lost my maps on the gold card Australia e&n i have not taken the card out of my lowrance gps sounder lms 339c since new some three & a half years can they be restored i have had no luck trying to contact navionics australia
Jun 07, 2010 | Navionics Gold United States East...
Loading Maps
MapCreate Topo does not have lake maps. There are 'some' maps on Lowrance's web site (Free Enhanced Lake Maps) but you may need to purchase lake maps on SD cards for the area you're interested in.
Jun 02, 2009 | Lowrance iFinder H2O GPS Receiver
Need map updates for GPS
Dependant on the type of unit you have, you can order MMC or SD cards from several companies. I have used Navionics with much success. They have a buy-back program where you can get a discount towards the latest cards when you turn in your old ones. Also, if you have a memory card device, you can access tons of lakes directly from the Lowrance website. Then save to acard and load into you boats unit.
Triton72
Mar 25, 2009 | GPS
Global map 5200c loading problems- navionics platinum hot maps
I had the same problem with my handheld Lowrance Hunt C. After installing the card and locking it in place, I had to slide the card "out" toward the locking mechanism. It barely moves, but worked after that. Whenever I load the card, I now slide it out and it works every time.
Mar 22, 2009 | Lowrance Globalmap 5200c Color...
Navionics gold card & humminbird 78c2
Hi!
You NEED to have a gps lock in order for the card to show it's true potential.
Also check in the menu for a setting that says "Map detail" and change it to all available. It could be the setting is on a lesser choice (like the internal mapping and not the new sd card)
Hope this helps!
Mike
Aug 06, 2008 | Navionics: Gold+ Chart Cartridge
Navionics gold sd card
Make sure that you go into MAP data and select this chart as the map info. You might just be using the internal base map right now.
Mitch
Aug 05, 2008 | Navionics Gold United States East...
Can not get a program to read my navionics sd card I have windows xp
Raytech Navigator software reads navionics cards and even comes with a card reader for an sd card. It also works on windows xp. Navionics also sells PC software to view their cards.
Here's a Raytech link:
http://www.raymarine.com/Default.aspx?site=1&section=2&page=710
Jul 26, 2008 | GPS
Map upgrade
I would like to order new maps for mine GPRS-ICN 330. I am interested bought new maps from the countries like:Holland,Spain, France, Germany, Belgian. I need to upgrade mine GPRS navigation (new maps).
And tell me it's possible to have them in Polish language?
Tell me where I can bought them because when I looking in yours web site I can't find the products what I need.
Thank you for your help in advance.
Is mine contact email:spo8@interia.eu
Sep 24, 2007 | Navman iCN 330 GPS Receiver
Eagle Industries FishElite 640C GPS Receiver Logo
129 people viewed this question
Top Eagle GPS Experts
fordexpert
Computer Links
carl blood sr
Are you an Eagle GPS Expert? Answer questions, earn points and help others
