Question about Magic Chef Kitchen Ranges
I have a magic chef 38ha-26cx-on. ive plugged it in to a 220 and when i turn the breaker on the "SURFACE" and "OVEN" lights turn and the oven heating coil turns on without the knobs being turned on. any way to fix this?
    Brigadier General:
  • 6,966 Answers
Hi again,
Thank you for the chat rating and the review.
Posted on May 27, 2008
Oven will not light
check to see if both sides of the 220 are hot , had the same thing happen and found one side had come loose , which caused the breaker to trip in thr frist place
Mar 05, 2012 | Magic Chef Kitchen Ranges
Magic chef oven will not turn on
Why don't you plug it in?
Dec 30, 2011 | Magic Chef Ovens
I have a used Magic chef glass topped range, but no manual. The model #29c030715417 and serial#38HA/6tvw. I can' figure how to get the oven temp up to speed, or get the broiler to work correctly...
Number 33 is your oven sensor. If it does not read 1100 ohms at room temp OR if it is open OR shorted to frame then it is defective and the control does not know what the oven temp is and won't work right. 38HA-6TVw is your model number by the way. I sold appliance parts before I retired.
Your element is either going to be good or bad no in between so it will do no good to replace it. If that sensor turns out to be good then your control is faulty. You can have it rebuilt if it is NLA.
Service manual and more here
Aug 23, 2011 | Kitchen Ranges
Good Morning, I bought a used Magic Chef stove. I don't have the manual. The alarm/bell keeps going off. The display shows "F-1" Would you please let me know how to turn off this alarm? I keep...
F1 Defective Touch Pad or Membrane
Replace Touch Pad or Membrane
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
Display Condition Remedy
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Nov 20, 2010 | Magic Chef Kitchen Ranges
No power to Magic Chef Electric oven
I'm not familiar with this oven, but it ought to have protection against this kind of exciting burn-out.
This could be a fuse: find it and replace it, or it could be a circuit breaker: look for a reset button.
As I said, I don't know this oven; this attempt to help is based on the general idea that it ought to have some built in protection.
Dec 11, 2009 | Magic Chef 9815 Electric Single Oven
I just cleaned by hand by magic chef wall oven and now I can't
Pilotless ignition means that a hot surface ignitor lights the oven burner. It does take a little bit of time to light the burner. Maybe 30 seconds. If you want to make sure it lights take the bottom panel out from the oven and observe the hot surface glow and the burners light. No real danger as the gas valve will only open after the hot surface ignitor has satisfied the gas valve. Let me know how it goes. ken
Jan 02, 2009 | Magic Chef 9122 Gas Single Oven
Magic chef oven
look at the burners in your oven,they usually go bad where they plug in.it will look like a peice is missing.if this is not the case one of the wires is loose on you breaker and you're running on 110
Nov 14, 2008 | Magic Chef 31203 Gas Kitchen Range
Oven not working (lighting) on magic chef stove top/oven
look at the burners in the oven,they usually go bad where they hook to the unit,it will look like a peice is missing.if this is not the case, a wire is loose in your breaker and you're running on 110 instead of 220
Sep 04, 2008 | Magic Chef 31203 Gas Kitchen Range
Pilot lights
you need to plug the oven in; pull it out and you should locate the pwr cord or you may already have it plugged in and have a breaker turned off or a gfi tripped
Jun 19, 2008 | Magic Chef Kitchen Ranges
Surface Heat and other lights will not light up. Will not get hot but is trying - gets slightly warm. This includes burners and oven. The cooking light will come on in the oven but nothing more. The...
you have a power promblem start where the cord connects to the range and go back from there to the fuses before you pull it out turn off the breakers loose connections will cause the cord to short out sometimes
May 24, 2008 | Magic Chef Kitchen Ranges
Kitchen Ranges Logo
90 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Dan Webster
Dan Webster
Mike Carew
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
