Question about Whirlpool Dryers
The heating part not werking - Whirlpool Dryers
  • Whirlpool Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Sounds like your problem may be with the heating coil. Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For further instructions on how to replace the element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Posted on Oct 03, 2010
How do i enter code on alfa romeo 156 jtd radio where can i find the code ? blaukpunt werke gmbh BP700532314916
You need another number to find your code. Go to this site to get it. https://www.radio-code.co.uk/blaupunkt-radio-codes.html
Oct 31, 2015 | Alfa Romeo Cars & Trucks
Ld-2040sh mashing moter the werking mother burning what I do now
First, get someone to help you write a question others might understand. What the heck does "mashing moter the werking mother burning" possibly mean?
Dec 10, 2014 | Cars & Trucks
What is werk
UrbanDictionary defines werk as:
"A congratulatory declaration of support, praise or approval, for an outstanding achievement in any area of life. Probably for original, sensational or courageous accomplishments in the fields of art, fashion, music, sport and friendship."
Jul 13, 2014 | Computers & Internet
Cod deblocare blaupunkt-werke gmbh seria bp 4495s2574323 please !!
Cod deblocare blaupunkt-werke gmbh seria bp 4495s2621334 please !!
Nov 21, 2013 | Car Audio & Video
I wot my codes to werk
work? There's usually a special menu for that.
Oct 28, 2012 | Nintendo DS Lite Pink Console
Sond not werking ibm t60 model pls
Download the latest sound drivers from the ibm website and install them.Restart your PC and that would work your sound.
Mar 21, 2011 | IBM SoundMAX Integrated Digital Audio
How do I enter code into my blaupunkt radio/cassette?
HY ACORDING TO THE MANUAL YOU SHOULD TURN THE IGNITION ON SWITHCH THE RADIO OFF PRESS THE AS BUTTON WHILE YOU TURN THE RADIO ON,AFTER 5 SECONDS YOU SHOULD HER A BEEP AND ON DISPLAY YOU CAN SEE 10SAFE AFTER 5 MORE SECONDS YOU SHOULD BE ABLE TO ENTER YOUR CODE USING FIRST FOUR BUTTONS FOR 0-YOU PRESS ONCE AND SO ON WITH THE OTHER DIGITS.
Jan 30, 2008 | Car Audio & Video
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
