Question about Barbeques Galore 38-inch Grand Turbo 175781 (NG) All-in-One Grill / Smoker
Can i convert grand turbo grill 287037 using ng to propane
5 Suggested Answers
  • 4736 Answers
SOURCE: Can a Turbo STS 3
The original BBQ's Galore went bankrupt, but was bought by new owners, who still operate it as BBQ's Galore. However, they did buy any of the older company's parts supply. However, all you need are the burner orifices for each burner (including the rear burner) and a Hose/Regulator Assembly to connect the grill to the grill tank. Follow the conversion instructions in the Owner's Manual (see link below) and you should be able to do it.
http://www.grill-repair.com/images/grill/turbosts.pdf
I suspect if you call BBQ's Customer Support 800-752-3085. They can provide the orifices, as they are universal in fit. The Hose/Regulator Assembly can be purchased from any hardware store or home improvement center that sells grills and accessories, for about $30.00.
Once converted, you will see marked improvement in the heating capacity of Propane Gas, as opposed to Natural Gas. The grill will preheat faster and maintain higher temperatures longer.
I hope this helped you, Bradley and thanks for choosing FixYa. Happy Grilling!!
Posted on Aug 10, 2011
Testimonial: "Thanks for the detialed response, I'll try it!"
SOURCE: Turbo STS grill, converting to propane
I would like to convert my Turbo STS grill from propane to natural gas. Where can I find the correct sized orifices?
Posted on Nov 02, 2010
cadesertmax
  • 274 Answers
SOURCE: I would like to convert
Contact GrandHall customer service at 214.349.1097
Posted on Jul 20, 2011
TheMobilian
  • 8220 Answers
Burner orifices must be resized or adjusted to accommodate higher pressure LP.
Air shutters should be opened all the way to allow maximum air to gas ration.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Sep 14, 2011
Converting a natural gas Webber genesis bbq to propane. Can you buy a kit to convert?
Hello, Kevin -
Do you mean a Weber (not Webber) Genisis grill? If so . . . see the information from the Weber grill company regarding the conversion of a natural gas grill to propane here:
https://consumer-care.weber.com/hc/en-us/articles/360001730474-How-can-I-convert-my-grill-from-liquid-propane-LP-to-natural-gas-NG-or-vice-versa-
Bottom line:
The Weber company does not recommend it and does not provide a conversion kit.
Best wishes.
Apr 30, 2018 | Grilling
How do I convert my weber s-470 NG outdoor gas grill to liquid propane?
Hi You will half to replace the NG Jets to Propane ones. Go to your manufactures web site and search for jets for propane. Some manufactures don't make them. Good luck.
Jun 09, 2014 | Grilling
Can't find a natural gas regulator for a BBQ Galore 4 burner slide in grill. Believe it is a SST ( or sts) Turbo model. Any suggestions on what might be a valid substitute? Grand Hall ( the parts...
I assume you have already check with BBQ's Galore ( 800-752-3085 ), as they usually stock conversion kits, if that particular model is approved for conversion. Also, you will need 4 new Natural Gas Burner Orifices. The Propane ones will not work satisfactorily, if at all.
Hope this helped and Happy Grilling!!
Jun 28, 2011 | Barbeques Galore Turbo STS 4-Burner...
I need to convert a weber nat. gas grill to propane and i can not find the kit, can you help?
OK - you may not like this answer, but it is what is is :^)
Its common to find kits that convert propane to natural gas (NG) but not the other way around. This is because NG has less energy per square foot than propane, therefore, the holes in your NG grill controls and burners will be bigger to move more gas and get the BTU's you need.
When you convert from propane to NG, you can simply drill the holes bigger and remove the regulator. But the reverse is not practical because you can't make the holes in a NG grill smaller without buying all new burners and control knobs. I guess that's the bottom line - your "kit" is simply to replace the burners and controls with propane-specific parts. You might be better off to just buy a new grill by the time you go through all that. If you have a Weber, their web site has all the manuals and part numbers you would need.
Keep in mind that propane tanks are under higher pressure and you MUST have a regulator. I've heard of some people that simply slap a regulator on their NG grill, but you will not get even burning or proper performance (again because the holes will be too big). In my opinion, it's simply not worth the danger to you or your family.
Aug 07, 2010 | Weber Genesis Silver B Grill
Turbo STS grill, converting to propane from natual gas, orafices arn't available from Turbo
Jun 17, 2010 | Barbeques Galore Turbo STS 4-Burner with...
Have a 4 burner built in naturals gas woud like to replace the valves can't get them loose what to do
try wd40
try going the other way than normal, rightyloosie,leftytighty
some gas manufactures thread the gasvalves backwards for safety
Oct 16, 2009 | Barbeques Galore 52-inch Grand Turbo...
No gas to burners
Check the gas tubes(all of them)for mud wasp or dirt dobber cocoons in the passage ways.
Jul 19, 2009 | Barbeques Galore 38-inch Grand Turbo...
Barbeques Galore 38-inch Grand Turbo 175781 (NG) All-in-One Grill / Smoker Logo
1,258 people viewed this question
Top Barbeques Galore Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Are you a Barbeques Galore Grilling Expert? Answer questions, earn points and help others
