Question about Acer AL1916W 19" LCD Monitor
I'm using the AL1916w 19" as a secondary monitor for my laptop. I went to turn it on the other morning whilst it was connected and it didn't turn on. I've tried it with other computers and it seems to acknowledge that it is connected however the screen remains completely black. Any ideas??
  • 11,361 Answers
Look for bad caps just like other failed monitors as shown in my album first.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Oct 03, 2010
Acer AL1916W 19" LCD Monitor Antitheft enable tobe disabled
Press CTRL + ALT + DEL to kill this process, uninstall unwanted programs from your computer and clean Windows registry using some reliable software such as Reginout. Thanks
May 13, 2010 | Acer AL1916W 19" LCD Monitor
The power went out twice in a one hour period a couple of days ago. After the second outage, my monitor would not come back on. Unfortunately, I had removed it from the surge protector to plug something...
1) Have you checked the fuse in the mains plug ?
2) There may also be a secondary fuse, inside the monitor (don't as me how to dismantle it, all I know is carefully) on the main cct board near to the power in socket.
Mar 14, 2010 | Acer AL1916W 19" LCD Monitor
My lcd monitor says no signal then turn off then orange light cums on iav plug my blue lead in to my lap top and the monitor but there is a line in bit at the back what goes into that and where does that...
yes that 15 pin connector is called as vga connector it is present in laptop at back when lcd of laptop is not working then that display can be seen by connecting external monitor at vga connector
Mar 03, 2010 | Acer AL1916W 19" LCD Monitor
Acer AL1916W about 2 years old. Turned on this
Bad caps in the power supply, common problems with 2-year old monitors, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Jan 25, 2010 | Acer AL1916W 19" LCD Monitor
My ACER AL1916 blinks several times before picture is displayed when the monitor is turned-on for the first time in the early morning and stays stable all day. I connected it using VGA cable. Any...
Usually this happens when the monitor is trying to translate the signal given off by the video card.
Nothing to worry about, simply a process that the system needs to go through.
If this solution has helped you, please take the time to rate me.
Oct 04, 2009 | Acer AL1916W 19" LCD Monitor
Acer al1916w wont turn on
My living room monitor faced the same issue before.
I called up Acer, and they fixed the power LCD board in the monitor.
Do not buy a new one yet, unless the warranty is over.
Jan 01, 2009 | Acer AL1916W 19" LCD Monitor
Acer Al 1916 W mind of it'e own
you need a new power inverter, better yet a new monitor. I have the same monitor as my secondary.
Jul 21, 2008 | Acer AL1916W 19" LCD Monitor
Problems with monitor Acer AL1916w
I'm using the Al1916W and it looks great at 1440 x 990. Make sure you have the latest Screen card drivers installed.
Apr 03, 2008 | Acer AL1916W 19" LCD Monitor
Annoying discolouration across monitor
Does your monitor uses external Power Supply Unit ?
May be the video board need services.
Feb 13, 2008 | Acer AL1916W 19" LCD Monitor
ACER AL1916 wont turn on
hi, first aid... check if the power switch is ok on the monitor, and let me know how you confirm the switch is ok???
Dec 30, 2007 | Acer AL1916W 19" LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
41 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
