Question about Whirlpool Duet GHW9150P Front Load Washer
My duet keeps flashing F1,what dose that... - Whirlpool Duet GHW9150P Front Load Washer
  • 15,935 Answers
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
Thanks for using FixYa - a 4 THUMBS rating AND POSITIVE TESTIMONIAL is appreciated for answering your FREE question
Posted on Oct 03, 2010
I have a Whirlpool duet front load washer model #WFW8500SR02 ,it stopped before the cycle was done and flashed F1.now i can't get it to do anything.the lights still come on and it clicks like it...
Hello & Welcome to FixYa
F1 error in your whirlpool cabrio indicates bad control and should be replaced to resolve the error code. However, you can contact Whirlpool as well prior to replacing the control yourself as I have seen whirlpool paying for the parts themselves just because this is known to be a common issue. Please get back to me if you have any other questions.
Kevin
Oct 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F1 keeps flashing and beeping
you can google your oven model for its codes. on our maytag oven the F1 code means defective touch pad or control board.
Jun 21, 2010 | GE Profile JT952 Electric Double Oven
F1 flashing on gas stove-manual says to push clear-where is clear button
HI. This actual code cannot be cleared by pushing the Clear/off button. This actual button will usually be located on the touch pad and is a basic cancel button. You can try to reset the entire control board by simply unplugging the unit for 5 minutes. This may correct the issue. If resetting dose not correct this fault, the necessary actions are to have the defective main PCB replaced, asap.
F1 - Defective control board(PCB)
May 23, 2010 | Frigidaire FGB24S5A Gas Single Oven
Washer keeps coming onf1
An F1 is almost always a defective main control board. Could try unplugging the unit for a few minutes and see if it will reset. The part # for the board is W10110072. The cost of the part is around $119.46...
Apr 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I HAVE A WHIRLPOOL DUET
this is a communication error on the ccu board replace the ccu board
Mar 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Old duet washer -error message F - 01 flashing
An F1 is almost always a defective main control board. Could try unplugging the unit for a few minutes and see if it will reset. The part # for the board is W10110072. Sears sells it for $119.46 or you could check E-Bay.
Feb 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F1 code for duet sport
you have a bad machine controller, check the warranty in your use and care guide to see if the part is covered under manufacturer warranty.
Jan 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Hotpoint ultima
F1 means short circuit motor triac.
You need to call an engineer.
Oct 26, 2008 | Hotpoint Ultima WF860 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
77 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
