Magnavox TV Hi, I have a problem with my console tv and hope you can help me; the tv is approx 6-7 yrs old and recently the volume started going up by itself and the tv cannot be turned off; if I put it on smart sound it will work for a few minutes and then the volume starts going up again! We unplug it to turn it off because it come back on immediately; I hope you can help me solve this problem as I have tried every thing I know but nothing helps! Thanks, rebsmom
  • rebsmom May 27, 2008
    The volume works fine if I put it in smart sound...I didn't have any problems until I played a dvd on it and why doesn't it turn off? I know the volume button is working and there is some other reason that the volume goes up and the tv will not turn off!
    rebsmom
  • 2,335 Answers
I would suggest to check the volume up button to see if it is stuck, if that is the case the other functions on the TV will not work.
If you can open the TV and use a contact cleaner to spray where those buttons are and see if that fixes it.
If that did not work, you can try to desolder it and install a new one to restore the functionality of your TV
Posted on May 27, 2008
  • Jaime Hernandez May 27, 2008
    If that is the case with your TV, is more likely the microprocessor that is not providing the proper commands when you do not use the smart mode. The power can not be turn OFF because the microprocessor still dealing with the volume commands being active.
    Genius:
  • 2,035 Answers
Please provide the model number of the tv ?
The main reason for malfunction is due the main board is defective you need to replace the main board..................
No color when playing dvd
try to connect cables again. make sure you push them strongly to maka sure it works. if that won't work your dvd or tv is damaged
Apr 06, 2010 | RCA Televison & Video
Magnavox old tv wont come on and stay on
I have a similar problem. I recently got a comcast dvr cable box, and after receiving the second box, my tv started going off and coming on all by itself. It may have something to do with the cable. For me, I think the cable box blew, or shorted something in the tv.
Jul 24, 2009 | Philips Magnavox 27MS343S 27" TV
I have a Magnavox projection screen tv. The tv
Will you have got a lot of years on this unit. There could be a lot of things wrong here are some things to check.
SMD capacitor 2009 on Small Signal Board
Check fuse on SSB location 1003
Check resistor 3306 15 ohm surface mount
audio output IC 7700 on the Small Signal Module
May 15, 2009 | Philips Magnavox 51MP392H Rear Projection...
Everything works except picture
Most probable cause is the vertical output IC. You can get a replacenment at the following link.
http://servicemanuals.vstore.ca/
Feb 02, 2009 | Philips Magnavox 51MP392H Rear Projection...
Connecting to cable tv
if you have a cable that has 1 red 1 yellow and 1 white plug it will usually work plug the white cable into the white input and try alternating the yellow and red in the yellow input
Jan 01, 2009 | Philips Magnavox DVD/VCR Dual Player
60" Projection Tv - Approx 6 yrs old
Your CRT fluid needs to be replaced. After many years the crt cooling fluid gets a ton of alage built up in the tubes.  This will cause the screen to get a halo effect or get darker.
You only need to replace the fluid in the blue and green tubes.
Dec 03, 2008 | Philips Magnavox 9P6034C 60" Rear...
Phillips 52" tv
It might be simply a matter of having someone adjust the magnetic rings on the yoke of your picture tube to refocus it - a lost art.
A 15 minute job for a seasoned veteran, perhaps, but expect to pay a minimum charge of 1 hour's labour, at $85-90 CDN.
Sep 18, 2008 | Philips Magnavox 27MS343S 27" TV
Philps TV problem
When I turn the TV on, I get a horizontal line across the screen approx 1/3 from the top. My TV make is Diamond and is approx 6 yrs old
Mar 14, 2008 | Philips Magnavox 27MS343S 27" TV
MAGNAVOX BIG SCREEN TV
Hi, I am having the same exact issue with mine. Although, it is only about 2 yrs old. We are still trying to find out what is wrong with it.
Aug 01, 2007 | Philips Magnavox 51MP392H Rear Projection...
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
