Question about Dell SE198WFP LCD Monitor
I have a blue pad lock middle montor - Dell SE198WFP LCD Monitor
  • 11,361 Answers
Black vertical line down the middle of my copies? This only happens when using the feeder.
theres a good chance that excess toner or Rubber degredation is what is causing your Black line/band,
The Manual feed tray Uses A feed roller and a Seperation Pad
If toner has spilt on to the top of the manual feed Roller Housing theres a good chance it may be Seeping on to the print paper Via the Feed roller
Instructions:-
open tray One at the front of tray one is a Closed Hatch which can be opened Upwards using the finger release catches on either end. Once lifted upwards the Manual feed roller should be clearly Visible - Rotate the feed roller until you can see the blue lock plate ho;ding the fed roller in place, insert a flat blade screw driver an d twist gently until you hear the lock plate release , remove the feed roller. You should now see the Offending Seperation pad. Cleaning the Seperation pad should be done using a Rubber restoration Liquid and LintFree Cloth. Use the same on the Feed roller . refit roller to tray and close and lock the Blue plate .
close down the Service Hatch and return to machine -
You may need to run several pages through tray one before all tread marks Dissapear
Sep 13, 2013 | HP Color LaserJet 5500 Printer
I have an hp p3005 with the jam code 13.01.00. It has had the feed rollers and sep pads replaced. When it runs it appears to catch on the separation pad itself since it shows a small buckle in the middle...
Replaced seperation pad?. separation pad work is to block multiple paper feeding,but in yourcase paper not at all feeding means paper pickup roller not picking up the papers.replace both 2 & 3 paper pickup rollers..
See the snap shot,view from under.
Pickup roller( red)
Un lock to remove pick up roller(blue),observe the angle of the roller & same way insert new one other wise it wont fix..
Bee care full while removing roller, paper sensor flag should not distubed(yellow)
bee pateince dont do harsh..best of luck.
Oct 11, 2011 | HP LaserJet P3005 Printer
Mouse pad want move
Some computer's include a lock button on the laptop for example on an Hp Pavillion the lock button is in the middle top part of the touch pad. Please tell me what software you are using (Windows 7, Vista, or Xp) and what model of the Acer you are using, or go into your control panel and look under printers and hardware for a touch pad tab and see if you accidentally locked it there. Or a wire has come loose in the laptop and you may need to buy a new Touch pad for your.
Feb 22, 2010 | Acer Computers & Internet
Hi i am using viewsonic lcd VA1703WB monitor.i am getting a horizantal line in the middle of the montor.i bought the system in jan07.please give a proper advice to rectify the problem.
The most likely cause is blown diodes in the screen.
You will have to take it to your local Viewsonic agent to check it out.
Best wishes,
Graemevm
Nov 13, 2009 | ViewSonic VA1703wb Monitor
Keyboard letters coming in to numbers
Generic comments
Are you using a lap top? If so ... the is a probability you have the num lock on which turns certain keys into numbers (they have little blue numbers on the keys) so you can use the "key pad" in the middle of your keyboard. Press the Fn (probably blue too) and num to turn this off.
If you are on a desk top ... you are going to have to look in the help section of your software for an answer to this problem'
Sorry, I tried :-)
A
Oct 02, 2009 | Classic Electronics Computers & Internet
Dell Lattiude D600 cursor locked in middle of screen - even after we turn on and off - no way to do anything because cursor won't move - not even little blue mouse in the middle of the screen
Try booting up after installing an external USB mouse. This may give you a mouse to install new keyboard drivers.
If the problem is the keyboard/tracking pad, (hardware) installing another keyboard may eliminate the issue.
Jun 14, 2009 | Dell Latitude D600 Notebook
Touch pad locked on averatec 6200
Is there a lock button in the middle just above the touch pad? If there is, push it once.
Mar 16, 2009 | Averatec 6200 Notebook
Dell SE198WFP LCD Monitor Logo
mukhtar21 shaikh
mukhtar21 shaikh
