Question about Biostar M7NCD Pro Motherboard
My M7NCD motherboard will not read my video card but I put the video card in another computer and it worked. Is there another way to get my monitor hooked up without buying another video card and etc.
  • 13,433 Answers
Okay, since the card works on another motherboard, that indicates that there is noting wrong with the card.
The problem is either the motherboard, cpu or memory. Or you might not have connected all the proper power cables to the board.
If possible test each part on another motherboard to confirm what is faulty.
Please keep me updated on your progress.
Posted on Oct 03, 2010
Can i up grade to windows 7 on this board
They don't list W7 drivers
http://www.biostar-usa.com/mbdownloads.asp?model=M7NCD%20ULTRA
I think XP is the latest it will support well, partly due to the CPUs you can put in it.
Feb 04, 2014 | Biostar M7NCD ULTRA Motherboard
Not able to see the display output on monitor but computer is on and even windows also boots up but no display on the monitor, monitor is working fine in this case (checked with other cpu)
try starting up in safe mode (F8 on startup), lower the resolution settings of your computer then restart in normal mode.
hope the above helps.
Jul 26, 2011 | Mercury KVM400M-U Motherboard
I dont no what kind of internet driver will fit to my motherboard m7ncd
just buy a lan card that will fit in to a PCI slot then connect it to your mboard then you are good to go
akuma_ryu21
dont forget to rate!
Jan 26, 2011 | Biostar M7NCD ULTRA Motherboard
Screen will not stay on, getting message no input signal
The message input signal means no signal is being feed to the monitor.
Check the cable use to connect the monitor to the video card.. fix and secure the connection.
If the computer is reading and you know its working, check the video card.
Turn off the CPU disconnect the video card from the motherboard and reconnect.
Try to open your CPU and see if it reacts with your monitor. If nothing happens replace your video card
May 18, 2010 | HP Vs17 17" LCD Flat Panel Monitor
When I turn my monitor on, the green power button comes on and then turns to amber. Nothing will display. What should I try
You need to check your video card. Check if it is still ok and functioning properly. You can also try checking your memory card. that are the two pieces usually causes that problem. Try this :
1. Double check the cable that connects the monitor and video card. Remove the connection of your monitor to your CPU (the video card cable is what i mean) then turn on your monitor. If the monitor displays a message like this " Check signal cable" it means it is working fine and there is a problem in your CPU.
2. This step is just for PC that are using PCIE or AGP video card,not built in there motherboard. Remove your video card if you have a PCIE or AGP video card, using an eraser (pencil eraser) you can clean the connectors of your video card (the coppers that is use to connect it to motherboard).
3. Try to remove your memory card. And the same as what you do in your video card, use an eraser to clean up the copper connector of your memory.
4. Put it all back in place. Make sure it is properly connected. Then turn on your computer.
If your monitor is still not working, you may use an internal speaker so that you can check if there is a problem in your motherboard.
If you don't know the meaning of the beeps try to read my tips and tricks i have the beep codes there..
Feb 27, 2010 | Computers & Internet
My computer will light up but not produce an image to the monitor, the monitor works but says it is in power save mode how can i fix it?
this has to do with the video out put, try every video out put you have from your graphic card to your motherboards video output.. this happened to my friend andwe had to switch the connector from his video card to his motherboard....
Feb 25, 2010 | Dell (002TR) Motherboard
I have a new video card and new monitor my computer still reads no signal
your video card is probly too new for your moniter so it cant process the commands the motherboard is sending. get a new moniter
Sep 25, 2009 | Computers & Internet
M7NCD ULTRA raid drivers
If the SATA drive is operating in 3.0 Gbps mode and your motherboard can only support 1.5 Gbps mode, the drive will not be detected in BIOS or XP. Try jumpering the drive to SATA 1.5 Gbps mode. The label on your hard drive should indicate which pins should be shorted to achieve this setting; if not, look up your particular model on WD's website to find the manual.
Nov 05, 2007 | Biostar M7NCD ULTRA Motherboard
Windows did not detect SATA during installation
You need the manual to your motherboard to set it up in the BIOS. http://www.biostar-usa.com/docsmain.asp In the drop down menu select M7NCD ULTRA. I hope this helps. Let me know.
Jun 30, 2007 | Biostar M7NCD ULTRA Motherboard
Biostar M7NCD Pro Motherboard Logo
64 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Matthew Spark
Matthew Spark
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
