Question about Zyxel Computers & Internet
Hi I have a couple of acer laptops on my router and they are fine. I have just bought my bookkeeper and my son an IBM think pad each but these do not connect. They see the router and the signal is excellent as it is very close but I get the error message On the first one Limited or no connectivity This problem occurred because the network did not assign a network address to this computer And on the other Pop up box Windows is unable to connect to the selected network. The network may no longer be in range. Please refresh the list of available networks and try again Both these connect at my unit on a BT router with no problem. Also they will connect to a BTOpenzone router Do you have any idea why this should be so. Many thanks in advance.
watz up
  • 6 Answers
SOURCE: netgear dg834gt problem connecting to hp pavilion dv4000
HI
NOTE: The following setup info .is for da PPPoA connection type.(most common in UK).
Its advised to keep da ethernet connected to your laptop untill you configure da wireless on the router, you can disconnect da ethernet cable after the confoguration is over to connect wirelessly.
Try the following: check if your PC is communicating correctly with router. (You might need to restart the computer, after the router is connected to it). On the desktop click on Start and then on Run. In the open box, type cmd.
It will bring up the command prompt window
Type command ipconfig in that window and press the Enter / Return key on the keyboard. It will bring up results similar to the image below.
Note the values of IP Address and Default Gateway in the ipconfig command results. If the IP address is in the range of 169. 254.x.x or 0.0.0.0, then your PC is not communicating to the router. In such a case contact your router vendor for support.
If the IP Address is in the range of 192.168.x.x then the network setup should be ok. Note down the values of IP Address and Default Gateway. Close the command prompt window.
Open Internet Explorer window and in the address bar type in the address that you found for Default Gateway. In case of a Netgear router it should be 192.168.0.1
It should bring up the logon window similar to the image below. Type the router username and password in the respective text boxes. Refer your product manual for the default Router username and password. In case of most Netgear routers, default username is admin and password is password. Then click on the Login button to continue.
In the next window that appears, click on the setup wizard button
This should bring up the Setup Wizard page similar to the image below. Select Country as UK and Language as English. Under Auto-Detect Connection Type, select No. Then click on Next button.
Basic Settings page will appear. Under Does Your Internet Connection Require A Login?, select Yes.
Configure the following settings in the window:
  • Encapsulation: Set it to PPPoA (PPP over ATM)
  • Login: Type your login name. (in most cases its the primary email address that you get from your ISP)
  • Password: Type you account password. (make sure there are no spelling or case mistakes)
  • Service Name: Leave blank.
  • Idle Timeout: Set to 0.
  • NAT: Select Enable.
Now click on the Apply button. (Please note that it may take up to 5 minutes to apply the new settings)
Then ckick on da wireless settings option.( its on the left pane on the window).
- keep the channel as 11.
- mode can be g&b
Make sure that da option WIRELESS ACCESS POINT is enabaled.
Also check da security options .... I would suggest use WPA-PSK encryption.
make a note of da shared key(network password).
ckick apply and wait till it saves the settings.
Disconnect the ethernet and try connecting to the wireless network with the correct security key.
Hope this helps you.
cheers
SHADAB
Posted on Sep 13, 2008
  • 42 Answers
SOURCE: "unable to connect to selected network" error
Hi, May be your router is now running a more secure algorith and needs password etc which the old one can't handle. You may have to downgrade your router to the older system..not a good idea.
Posted on Jan 10, 2009
  • 15 Answers
SOURCE: Not able to type in network key for wireless
1) If you are using the Windows Default Wireless Network Connection. Open the windows where you you will see a list of all wi-fi connections near by your location. On the left panel(Related Tasks) click on "Change Advance Settings" >> Wireless Network Connection Properties >> Click "Wireless Network" Tab >> from the Preferred Networks: list, remove the wi-fi connection you are trying to connect. Once your W-Fi connection settings are removed. You can either add it manually clicking on the Add button and entering all informaiton manually, or from the wi-fi network list click the network name it will ask you to enter the netowkr key....
OR
2) if you are using any other Wi-Fi connection application, like the Intel's, follow the same procedure. delete the settings and try connecting again.
Posted on Feb 11, 2009
SOURCE: Can't connect my Ipod touch to my router?
i had the same problem too with my'n. My issue was on of my setting's was set to block that wi-fi connection. Try switching your setting for finding internet connection from automatic to manual. that should do the trick!
Posted on Apr 25, 2009
heuweiler
  • 56 Answers
SOURCE: HELP!!!!!! Trying to enable wpa-psk security on my laptop?
You should set the security on your computer wifi card to wpa-psk and then type in the securitycode which is written in your Zyxel Router.
If this is not possible with your networkcard, change to wpa or wpa2 inside the Zyxel. And do the same procedure with your networkcard, when detected the Router.
Posted on May 04, 2009
Just installed a TP-Link TL-WR940N router. IBM and Dell laptops connect fine. My son's Toshiba Satillite will not?
check to see if you inserted router name and WEP password correctly in your son's computer. I'm thinking you were tired when you got to your son's puter.
regards,
Digital Denizen
rate us and ask another question if it doesn't work
Nov 27, 2010 | Toshiba Satellite A215-S4747 Notebook
Windows 7 and D-Link DSL-2640R router. I have recently bought a new laptop which supports windows 7, the talktalk cd will not work so i do not know my routers settings. Well my internet connection always...
Hi
I presume that your internet was working fine before you bought your new laptop. Unless you've done something to change it it should still be working as before.
You shouldn't need a CD - if you think about it you don't need a CD when you log in in Starbucks so why should you need one at home?
The only thing you need to know is the router's wireless name; Talktalk 12345etc, and its password - which is the password your son is using.
I can't explain why you can't connect when your son is connected - as the router should be able to host 253 laptops (very very slowly mind) - unless the router has been set with an access list that only allows his laptop to connect.
Nov 24, 2009 | Computers & Internet
I just bought a used ibm think pad laptop
Hi there.
If you have just bought the laptop chances are the operating has been removed to you cannot see any data that used to be on it, you need to go and purchase a windows OS that the laptop was built for (i'm guessing XP) and re-install the operating system again.
Good luck and thanks for using FixYa!!
Apr 21, 2009 | IBM ThinkPad R40 2681
IBM Thnink Pad R52 Shuts Down unexpectedly
it might be the battery, try plugging it in while doing that.
Jul 09, 2008 | IBM ThinkPad R52 Notebook
I HAVE A DELL COMPUTER, AND A LYNKSYS MODEM AND ROUTER. I HAVE TRYED SEVERAL TIMES TO GET THE ROUTER TO WORK SO I CAN USE MY IBM T40 LAPTOP, WIRELESSLY. EACH TIME MY INTERNET ACCESS ON THE DELL IS TURNED...
sounds to me like u r running the dell in the usb, and it has to be on for the ibm to work, or you have a dual ip addressing problem, which is a negative to the ibm when the dell is off.
My son has a IBM think pad as well, and when he uses the Ibm with his linksys wireless router he has the same problem, or did until I addressed the dual ip address issue, which I had to change the Ip address on our netgear, and left his as was and changed the one from My Dell inspiron 8600, I suggest you go to the linksys web site and follow the re install of new drivers for your router and if possible upgrade. they have available w wireless handing software program available to linksys customers as a trial you can download called NETMAGIC which also works quite well, and your able to monitor your network and it usually works well, I've used it until I upgraded to my netgear wireless G router.
hope this info helps you out.
Jun 12, 2008 | Computers & Internet
Wireless connection
There are a few requirements other than the laptop and the wireless card. You need to also have an Wireless AP/Router that must be connected to the modem that connects to your ISP. All your PCs must then connect to this router either using the wired/Ethernet ports or WiFi.
If such a device (WiFi AP/Router) already exists and is connected to your modem and your other PC(s) are tied up to it and can access the Internet, you need to install the drivers (in a CD that came with the wireless card) to your IBM ThinkPad. Thereafter, you need to configure your laptop's wireless networking to access the AP/router. Your AP/Router must also be configured to accept wireless clients.
Please post back with brand/model of your AP/Router.
Hope this be of initial help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Feb 01, 2008 | IBM ThinkPad T20 2647 Notebook
Ibm think pad t30
To my knowledge, your laptop (IBM ThinkPad X30 2672) does not have any built-in WiFi. It's modes of connection are IrDA, modem, Ethernet, USP, Firewire aside from the regular serial & parallel. This would indicate that if you are wireless you either have a USB dongle or PCMCIA card. Please post back with your WiFi brand/model and your Operating System. Further, please post back likewise your WiFi AP/Router brand/model.
The message "a network cable is unplugged" pertains to the absence of a lan cable connected to your Ethernet port.
Good luck, kind regards and will await your second post.
Nov 16, 2007 | IBM ThinkPad X30 2672 Notebook
Computers & Internet Logo
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
