Question about Acer Computers & Internet
My Netbook is Acer, Aspire One 751H, Model ZA3, My Netbok has Acer eRecovery Management software Version 7.0.8. Before first use I have created Factory Default Disc as well Disc for Drivers and Applications. I want to reinstall Operating System as well as I want my data back which is in my documents. My OS crashed then I have tried both the options Alt F10 and from Recovery Disc. Both way, it is creating c:/backup folder but it is found to be empty. While using I have stored my data in my documents(User Account) Why the created folder C:/backup is empty? What has gone wrong? Which is correct method? Where we should store Data so that after recovery we will get it back?
xCAUSALITYx
  • 210 Answers
SOURCE: d2d recovery
Unfortunately once your original HDD has been replaced you lose all e-recovery features and there is no-way this can be reversed.
If you could get hold of the image from your old drive you maybe able to write it to your new, its a bit messy though.
The main reason for the "factory default image backup" you have not working now is because a snapshot of the C: drive is stored on D: drive so when you replaced the drive itself you basically made that disc useless for eRecovery features.
Sorry its bad news.
Cheers
Posted on Jun 17, 2008
It really works!
Thanks a lot.
Posted on Jul 27, 2008
SOURCE: accessing the acer aspire one hidden partition files using the f10 and alt f10 method
I am not sure if you are asking how to access it or not. I will assume you are. The One series does not have a restore partition on it. It comes with disks that you can use with an external drive to restore it.
Posted on May 23, 2009
  • 39 Answers
SOURCE: i have 1recovery **** named aspire 5610 dvd2 should i have a dvd1 disk also
go to http://www.sysresccd.org/Download
download the iso and burn it to a cd.
boot your computer with it
read the explanations coming up on the screen and when you see that you can choose how to start, type "wizard"
choose the top choice (auto)
when it starts right click on the desktop and start GPARTED.
one of the discs will be marked as "boot"
right click the disc called "recovery" (or the one that is not marked as boot).
choose manage flags
set it to Boot.
press apply on top (not always needed tho)
in the left picture (the one that opened from the start)
type reboot
remove the cd when you see the acer logo again.
the acer recovery manger should start.
Posted on May 29, 2009
drifterK
  • 4924 Answers
SOURCE: restore acer aspire to factory setting
if you can not use the f10 or f12 key ..it means that it do not have the boot menu there ...or it do not have a restore partition ...the F10 command is available in Hp laptops..with a recovery partition made on the hard disk ..
here you will need a installation cd of the operation system you want to install and the drivers from the acer support site..to suit it ..and just boot from cd by choosing that in the bios setting boot sequence ..and go for it
Im not sure for the model but if it do not have a optical drive ..than you will need to make a usb flash drive bootable with windows in it ,,and for that you need this kinda soft ..
http://wintoflash.com/download/en/
this is a tool that will take a windows from a disk and put it in a usb unit and make it boot-able ..
also here is a windows Xp..image that can be burn on a disk with nero in the background ..and after that boot-from cd and install it ..
http://thepiratebay.org/torrent/5388204/Windows_Xp_Genuine
download it with utorrent..than be sure you have nero installed.and just insert a blank cd-r and double click the image file to burn it on disk ..
after that insert it in the laptop ..and restart ...if teh boot order is ok ..it will prompt you to boot from cd ..and press any key to continue..if not..go to bios by pressing F2 ..and in there on boot sector ..select cd /dvd first boot device ..and than use F10 to confirm and save changes..and restart an go for it ..
Do not forget to rate me ..
Posted on May 29, 2010
System recovery boot
The Acer Aspire line of netbooks have two methods to restore the computer to a working state: System Restore, an application included with Windows, or Acer eRecovery Management, a proprietary application that is packaged with Acer PCs.
If errors appear when running Windows, or if the computer begins to behave strangely, first run System Restore to determine whether reverting the PC to a previous state fixes the problem.
If the problem remains unresolved, or worsens, you can use Acer eRecovery Management to format the hard drive and reload the Acer Aspire netbook to its factory state.
Navigate to the "Start" menu. Select the "Control Panel."
Type "restore" into the Search box.
Press "Enter" then select "Restore Your Computer to an Earlier Time" from below the "Action Center."
Click "Open System Restore."
Click "Next" on the "Restore System Files and Settings" screen.
Select a restore point that was created when the computer was functioning properly. Click "Next," then click "Finish."
Click "Yes" to confirm.
Windows will perform a system recovery on the Acer Aspire One.
Turn on the Acer netbook. Hold down the "Alt" and "F10" buttons simultaneously on the boot screen to load Acer eRecovery Management from the recovery partition.
Select "Restore Operating System to Factory Defaults" from the options.
Click "Next" to recover the system to its original state.
Acer drivers and Manuals downloads
http://us.acer.com/ac/en/US/content/drivers
Jul 16, 2013 | Acer Aspire 5050-3242 Notebook
Fomat my computer
Which OS you are using??
To Format your laptop,you need bootable CD....
Format steps for windows 7:- windows 7 format
Format steps for windows XP:- windows XP format
If you need any kind of technical assistance, you can contact support cell at http://www.vtechsquad.com
Sep 18, 2012 | Acer Aspire One PC Notebook
Reset to factory seting
Unlike other laptops, Acer Aspire notebook/laptops integrate a computer management utility called 'Acer eRecovery Management' to create backup of hard drive data, create restore point, reinstall applications & drivers, and reset Acer Aspire One Netbook 8.9 to factory setting.
Step 1: Before starting your Acer Aspire One laptop, ensure that there is no external storage device attached to it. Now start your laptop.
Step 2: Press 'Alt + F10' when the laptop starts booting, and wait for a moment while Windows loads the reset files.
Step 3: When 'Acer eRecovery Management' window appears, select 'Restore System from factory default' and click 'Next' to continue.
Step 4: Again click 'Next' to reset your Acer laptop. This process will erase all data from your hard disk and reset your Acer one to original factory settings.
Step 5: Click 'OK' in the notification window to begin the the resetting operation. Now wait while your Acer Aspire One is reset to factory settings.
Tips: You can also create a backup copy of your notebook data before factory reset. Simply click 'Backup' in 'Acer eRecovery Management' window.
If you face any issue with your Acer Aspire One Notebook/Laptops/Desktop, feel free to get expert technical assistance at
http://www.vtechsquad.com/acer-support/
Jul 22, 2011 | Acer Aspire One PC Notebook
How to reformat aspire one netbook d150
If acer gives you a cd wherein you can insert it and reformat back to original settings, please make sure you shut down the pc and then press repeatedly F12. Then select Boot to CD. Follow the prompts and select Format C: drive to begin reformatting it..
Jul 19, 2011 | Acer Aspire One Netbook
Restore Acer Aspire ONE D150-1165 Netbook
On help and support menu, type restore system. You will get an option to what date your OS will restored. Make sure you decide the correct date ( when the OS is still working fine). Key in the date ( or choose the preset date) the enter. Wait for process done completely. Your OS should be restored now.
Jun 28, 2011 | Acer Aspire One D150-1587 Netbook
Do you know where to download th e acer erocovery management for acer aspire one 751h? Ihave the partition labeled PQSERVICE but i miss the program (start up Alt + F10 doesn't work)
Hi kazol97,
"Go to this "Website."
"Download the User's Manual!"
Search for the {Acer eRecovery Management}.
It will give you the instructions.
!Important: "Take a 'moment to rate the help', so I can get 'credit' for the work.
Thank you!" - paul7of9
Click here: http://support.acer.com/us/en/product/default.aspx?tab=1&modelId=1112
Mar 12, 2011 | Acer Aspire One 751h-1885 Netbook
Missing Acer eRecovery Management icon where do I go to download the latest version or if it is located on the pqservice(z) drive how can I install the software?
Hi. This software is currently not available for download. You may check if it is still installed in your notebook.
To launch Acer eRecovery Management:
• Click Start > All Programs > Acer Empowering Technology > Acer eRecovery
Management.
To read more, click this.
Feb 06, 2011 | Acer Aspire 5610-4648 Notebook
How to reset myacer to manufact setting
  1. Consider what data you still need from your Acer Aspire One's hard drive. Save the files to an external USB device.
  2. Restart the Acer Aspire One's operating system. Wait for the Acer logo to appear on the LCD screen.
  3. Press the "Alt" and "F10" keys at the same time to bring up the recovery menu. Press "Enter."
  4. Click "Next." Follow the prompts that appear on the screen to restore the operating system back to factory settings.
  5. Use the drop-down boxes to select the time zone and language information for your Acer Aspire One. Restart the netbook when you are prompted to finish restoring the computer.
  6. Connect the external USB device to your Acer Aspire One and transfer the data you saved earlier back to the netbook.
Nov 12, 2010 | Acer Aspire One Netbook 8.9" Notebook
Computers & Internet Logo
347 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
