Question about Leifheit Soehnle 63673 Melody centerpoint scale
How deo I reset my Soehnle melody bathroom scale to zero after changing batteries?
I just installed a new CR243 battery in my Soehnle bathroom scale, A red light came on inside, but nothing happens on the screen. Can you help?
Sometimes a CR2340 battery is still in it's package, but it may be very weak, even though it tests OK. Try another good battery.
Jun 15, 2017 | Soehnle Health & Beauty
Programming soehnle volga
If battery replacement did not help, the scale may have failed.
Sep 19, 2016 | Soehnle 63691 Volga WhiteGrey Body Balance...
How do i reset my digial bathroom scale
Remove all the batteries. In ones with memory, there are two sets, a 9 volt and 2 x AA.
The GNC WirelessWeight GS-7006 Digital Bathroom Scale accurately measures weight, body fat, water hydration, bone and muscle mass. This item features a removable wireless display that can be conveniently mounted on the wall, so you can see the readout clearly. Built with durability in mind, the scale is made from extra-strong tempered safety glass. The GNC bathroom scale also features an energy-saving auto on/off function and auto zero.
  • Removable wireless wall mount readout display
  • Measures weight, body fat, water hydration, bone and muscle mass
  • Energy-saving auto on/off and auto zero
  • Extra-durable tempered safety glass
  • Weight capacity: up to 330 lbs
  • Requires one 9V and 2 AAA batteries (included)
Jul 16, 2015 | GNC Digital Bathroom Scale
I changed the battery and now when turned on all icons on screen flashing non stop
try repeated pressure to reset (5-6 times in 10 sec) or could see if there is a small hole near battery compartment, push with paperclip (button reset)
Jun 06, 2014 | Soehnle Exacta 63694 Body Fat and Water...
I replaced the 9 volt battery on my Soehnle scale and the display on the front reads 8888888 and stays that way, never going to 00. Please advise.
mcdevito75 here, You can try to disconnect the battery, then step on the scale then step off, Now re-install the battery and see how it works. If same contact scale manufacturer.
Jun 29, 2010 | Soehnle Linea Quattrotronic Digital...
Need reset scales have no instructions
mcdevito75 here, There should be a button or knob close to the scale indicator you can press or turn to return the scale indicator to zero.
Jun 26, 2010 | Soehnle Exacta 63694 Body Fat and Water...
My weighing scale is not working
try checking the battery and installing a new one
Jan 12, 2010 | Soehnle Linea Quattrotronic Digital...
Reset digital bathroom scales
I cannot reset my digital scale to lbs. it is a conair ww body mass scale
Aug 25, 2009 | Health & Beauty
I changed the battery on bathroom scale Salter 987
I had the same problem with my Salter 987 scale. Pull the battery out for about 10 seconds and put it back in. Then push the scale once so it turns on. After the blinking stops, push it once more. The scale will now zero itself. After the scale has zero'd itself it may turn off after a brief moment. It's now ready to use normally. If you're standing on the scale when it's trying to calibrate to zero, it will assume your weight is zero. Don't stand on the scale after replacing the battery untill you first complete the steps listed above.
Jul 21, 2009 | Salter Stainless Steel Electronic Bathroom...
Leifheit Soehnle 63673 Melody centerpoint scale Logo
583 people viewed this question
Top Leifheit Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Leifheit Health and Beauty Expert? Answer questions, earn points and help others
