Question about Nuance Communications ScanSoft Dragon Naturally Speaking (naturalspeaking) for PC
Double printing I am using DNS 9 to dictate to a Windows application on several computers. On one of them, DNS is suddenly printing both the raw and the corrected version on the screen. It is as if the screen had become the dlittle dictation box as well. How do I fix it? (The application happens to be a Voice-to-Voice English to Spanish Translator, but it all runs fine on the other machines.)
How do i enter service mode
Use DHCP : Off Use BOOTP : Off Use RARP : Off Enable DNS Dynamic Update : On Use Zeroconf Function : On IP Address : 192.168.1.20 Subnet Mask : 255.255.255.0 Gateway Address : 192.168.1.1 LPD Printing : On IPP Printing : On IPP Printer URI : printer RAW Printing : On Raw Port Number : 9100 RAW Mode Bi-direction : Off FTP Printing : On Primary DNS Server Address : 0.0.0.0 Secondary DNS Server Address : 0.0.0.0 DNS Host Name : NB-17FB0000859B9287 DNS Domain Name : Multicast DNS Service Name : Canon iPF710 (9B9287)
Nov 21, 2012 | Canon imagePROGRAF IPF605 Printer
How to assign DNS?
DNS is a function of the Windows network or a service. if you are using windows xp or higher you can type the name of the computer into the run command to access it.
\\homecoumputer
double slash then the name of the computer.
if you want a dns to connect to your system remotely i would recommend ddns. they have a free service and its easy to use.
Apr 04, 2011 | Computers & Internet
We have a Canon EOS 500D. After using it for 18 months we suddenly have a Raw notice and cannot print photos. We dont know where this has come from or to get rid of it. Advise please.
Sounds to me as if someone has set the image "Quality" to RAW files which are more for a professional or advanced amateur use. Page 70 of your owners manual will show you how to set this "Quality" to jpg. I'm going to include a screen shot of this page because it has diagrams and instructions far better then what I can explain just in type.
Also the RAW files you have must me downloaded to your computer, opened in your image software program and converted to jpg file format before you can print, e-mail or any other "normal" thing people do with jpg format.
RAW is just that the actual raw file of the image captured where as the jpg file format is the compressed version with corrections already made in camera. RAW files need correction in post processing.
I suspect you are using the Rebel's direct printing feature which can not process RAW file format, I don't think you want to print RAW as there has been not corrections.
I know this will help.
Here is the diagrams.
T1iA1
T1iA2 diagram
Feb 20, 2011 | Canon EOS 500D / Digital Rebel T1i Digital...
Printer Won't Print
Step one: Restart the computer
Click Start and click Shut Down.
Click Restart or select Restart from the menu. Click OK.
After the computer restarts, double-click the Printer icon in the system tray located at the bottom, right of the computer. The print queue opens. If no documents appear in the print queue, the issue is resolved.
If the issue continues, proceed to the next step.
Step two: Check the product cable, Disconnect the USB cable from the product and from the computer.
Wait 5 to 6 seconds. Reconnect the USB cable to the product and computer.
(NOTE: The product must be connected directly to the computer using a USB cable or a powered USB hub. If the product is connected to the computer through a non-powered USB hub, or if the type of hub is unknown, connect the product directly to the computer) after the product is connected to the computer, the product should start printing the jobs in the print queue. If the issue continues, proceed to the next step.
Step three: Determine whether the product is paused or offline, Click Start and click Printers and Faxes. The Printers and Faxes window appears. In the Printers and Faxes window, right-click the product icon and click Open. The Printers folder opens. On the menu bar, click Printer. Make sure that the Pause Printing and Use Printer Offline options are not selected. If a check mark appears next to either option, click to remove it. If the menu includes Use Printer Online, click that option.
If neither Pause Printing nor Use Printer Offline is selected, press Esc to leave the menu without making changes.
Step four: Stop the print queue, Double-click Macintosh HD, Double-click the Application/Utilities folder.
Open the Print Setup Utility folder; Double-click the appropriate product in the product list to open the print queue.
Click Start Jobs. (NOTE: If the queue was accidentally stopped, the print job will resume automatically. If the issue continues, proceed to the next step)
Step five: Delete the print jobs, Double-click Macintosh HD, Double-click the Application/Utilities folder.
Open the Print Setup Utility folder, Click a print job and click the Delete icon. Repeat the steps for all the jobs in the print queue, Click Start Jobs, Double-click the appropriate product in the product list to open the print queue.
When the print queue is empty, click Start Jobs. Try the print job again. If the issue continues, proceed to the next step.
Step six: Remove and re-add the product to the printer list, Double-click Macintosh HD, Double-click the Application/Utilities folder, Open the Print Setup Utility folder, Select the appropriate product.
Click the red X to delete the product from the computer, Disconnect the USB or Ethernet cable from the product.
Close all open windows and restart the computer, after the computer is restarted, double-click Macintosh HD.
Double-click the Application/Utilities folder, Open the Print Setup Utility folder, and Reconnect the USB or Ethernet cable to the product. If the product is not automatically added, click Add. Select the product to add and click the Add button. After a few seconds, the product appears in the printer list. Try the print job again.
Jul 18, 2008 | HP DeskJet 5150 InkJet Printer
HP Deskjet F380 All-in-one Won't print
Solution:-
Step one: - Restart the computer
Click OK.
Step two: - Check the product cable
After the product is connected to the computer, the product should start printing the jobs in the print queue.
Step three: - Determine whether the product is paused or offline
In the Printers and Faxes window, right-click the product icon and click Open . The Printers folder opens.
If the menu includes Use Printer Online , click that option.
Step four: - Stop the print queue
Double-click Macintosh HD.
Open the Print Setup Utility folder.
Click Start Jobs.
Step five: - Delete the print jobs
Click a print job and click the Delete icon. Repeat the steps for all the jobs in the print queue.
Click Start Jobs.
Step six: - Remove and re-add the product to the printer list
Click the red X to delete the product from the computer.
Close all open windows and restart the computer.
After the computer is restarted, double-click Macintosh HD .
Jul 15, 2008 | HP DeskJet F380 All-In-One Printer
HP Deskjet F380 - NOT PRINTING - only scanning
Solution:-
Click OK.
Click Start Jobs.
Click Start Jobs.
Jul 12, 2008 | HP DeskJet F380 All-In-One Printer
HP Deskjet F380
Solution:-
Click OK.
Click Start Jobs.
Click Start Jobs.
I cannot print but i can scan
Solution:-
Click OK.
Click Start Jobs.
Click Start Jobs.
Jul 09, 2008 | HP DeskJet F380 All-In-One Printer
Blank Pages
The probability is that the new print server is either configured for a longer "page" than the cross match card.
There are different ways to fix this and it really depends on the application used to print the cards.
My first suggestion would be to fix the print server - followed by setting the page size in the application and finally configuring the form length for the profile you are using in the printer - the application settings usually take precedence over the other two, but I have found when using Windows server to drive the printer that Windows dictates the form size and a custom form may need to be created.
May 29, 2008 | AMT Datasouth Datasouth Documax 3300...
Nuance Communications ScanSoft Dragon Naturally Speaking (naturalspeaking) for PC Logo
Top Nuance Communications Computers & Internet Experts
David Payne
David Payne
Are you a Nuance Communications Computer and Internet Expert? Answer questions, earn points and help others
