Question about Bosch HBN 7052 GB Stainless Steel Electric Double Oven
We have a Bosch 49.0 gb and the door keeps flopping forward therefore not closing fully. Is this weak hinge springs, if so how can were can we get replacement springs from and instructions on how to change them?
3 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: Oven door won't close fully.
The only satisfactory solution, is to replace both the oven door hinges,\ which is a fairly straightforward job to do.
Please rate my solution.
Thanks
Posted on Nov 09, 2009
barkencoa
  • 3463 Answers
SOURCE: Our Bosch electric oven is 5 years old. We
Either you have not refitted the door back correctly, or the door hinge springs are weak, a common problem.
This being the case, then the only solution is to replace door hinges.
Posted on Feb 11, 2010
Door will not stay closed
Hello,Sounds like the door hinge springs are weak, it will probably be necessary to replace them both.
Thanks
Jun 02, 2010 | Whirlpool GBS277PDS Electric Single Oven
Oven door not closing properly
If it is a drop down door with hinges on the bootom of the oven door, then it is likely to be weak door hinge springs, the usual solution is to replace both hinges.
If it is a swing open door, then the problem is related to a worn or broken door catch, or worn striker pin.
Apr 13, 2010 | Ovens
Feb 11, 2010 | Bosch Ovens
Door will not close tight
If it is a drop down door with hinges on each side, then it is the hinge springs that usually cause the porblem, as they become weak over time.
The only solution is to replace both the door hinges, as they are not adjustable.
Thankyou.
Feb 01, 2010 | Bosch Appliances 27 in. Wall Oven Electric...
Thanks
Nov 09, 2009 | Bosch Ovens
Doors don't shut all the way and light stays on
It sounds like your door hinges are worn, usually on older ovens due to weight of door. Most oven doors can be removed by simply raising the tabs/ fitting small screwdriver on both hinges(refer to user manual) etc. Once door is removed you can place a medium size screwdriver or similar in the hinge slot, pushing the hinge plate on the bottom in an outward direction, thereby bending this plate(very slightly) forward. This will make the door close fully, activating the door switch, and turning off the oven light. This is only a short term solution, as this hot air escaping can lead to further problems. Hinge pair will need replacing. Door hinges are spring loaded ALWAYS KEEP FINGERS AND HANDS CLEAR OF LOADED HINGES.
Sep 18, 2009 | Jenn-Air JJW8230D Electric Double Oven
The upper oven door dosen't shut tight.
Door not closing properly is normally due to weak door hinges.
Normal procedure is to replace both the hinges.
Plz rate my solution.
Thanks.
Jan 07, 2009 | Thermador SC302T Electric Double Oven
Bosch oven door does not close tightly, takes FOREVER to heat
All you need to do is replace the oven door hinges. as the springs are weak.
It is a fairly straight forward repair to do.
To obtain new hinges, got to:
www.bosch-spareparts.co.uk
or
www.espares.co.uk/bosch
Thankyou.
Jan 05, 2009 | Bosch HBL 745 Stainless Steel Electric...
The oven door on my Whirlpool oven won't stay closed
Sounds like the door hinge springs are weak, it will probably be neccessary to replace them both.
Please leave feedbck
Dec 06, 2008 | Ovens
Neff oven door (U1661)
The door is v heavy and the hinges being right at the bottom take a lot of strain, especially when the door is in 'half open' position. Once the springs start to wear the hinges are no longer strong enough to hold the top of the door firmly closed. Our U1661 is 8 years old and we've had the hinges replaced twice under extended warranty. The second time the hinges they supplied don't hold the door in this position and it will just drop straight down if you don't support it while you open it.
Oct 20, 2008 | Neff U1661 Double circotherm super...
Bosch HBN 7052 GB Stainless Steel Electric Double Oven Logo
78 people viewed this question
Top Bosch Ovens Experts
ashburton
reliableservice
Are you a Bosch Oven Expert? Answer questions, earn points and help others
