Question about Lexmark X5470 All-In-One InkJet Printer
Printer reads no cartridge when one is in - Lexmark X5470 All-In-One InkJet Printer
    Genius:
  • 1,456 Answers
Hello
Remove the ink cartridge (or cartridges) from the printer.
Turn the cartridges over so you can see the copper foil portion of the cartridge casing. You'll see many neatly punched holes in this copper tape. Look closely: if any of the holes seem to be torn, with jagged edges, or if there are tears anywhere else on the copper foil, the cartridge has been physically damaged. Replace it. If the foil appears to be all right, continue.
Moisten the tip of your finger. Gently rub it over the small print head on the bottom of the cartridge. The print head will look like a small plastic or glass window. Rub away any old, dried ink that may have collected on the print head. Old, dried ink has "killed" many a cartridge, particularly if you haven't used the printer in a while. Use your finger tip rather than a towel or a cotton swab: Your fingertip won't leave stray fibers on the print head which could cause further problems.
Seat the cartridges back into the printer. Firmly snap shut the cartridge carrier. Let the printer take the cartridge head back to the proper starting position on the track. Close your printer service bay.
Turn off your printer. Unplug it from the power source for 10 seconds. Plug it back in and turn on the printer.
Follow your onscreeen software instructions on aligning the cartridge heads. The alignment prompt comes up each time the printer detects the cartridge has been replaced or moved. Be sure to note whether this is a new or an old cartridge when you answer the dialog questions.
Use a brand new cartridge, one that is freshly packaged, if the alignment process on the old cartridge fails. This will tell you, definitely, whether the problem is a cartridge problem or a larger printer problem.
Replace the printer if no cartridge--regardless of age-- will successfully align in the printer.
Posted on Oct 03, 2010
Printer is not registering new cartridge, which is full and an HP "02" . Printer was out of cyan blue for a while, printing in black and white, then replaced it. Ink is flowing, checked with...
Hello.
New cartridges that are not HP brand can sometimes give these errors. If they are HP brand then the issue is with the sensor that reads the cartridges "chip" The ink levels are not read like the fuel in your car, there is a page counter on the cartridge and when it hits 0 then it assumes there is no ink. So the issue seems to be it is not reading the chip correctly. Try removing all the cartridges. turn the printer off for 10 mins and replace the cartridges 1 by 1. This can sometimes correct the issue. If not the pins that read the cartridges chip can be checked for dirt of dry ink that may be interfering with the pins touching the cartridge. these pins are in the Cartridge holder for each colour, inside the printer. use a torch to see them properly.
Good Luck. Regards GM
May 26, 2011 | HP Office Equipment & Supplies
10.00.00 supply memory error Unable to read cartridge data
Memory Supply Error 10.00.00 The printer is unable to read or write to the print
cartridge e-label, or the e-label is not on the cartridge.
Basically what is happening is the printer cannot read the small chip on the toner cartridge. The chip is located on toner cartridge as it is inserted into the printer. 1 - Make sure the toner is firmly seated into the printer. 2 - Power cycle the printer with the toner out of the printer. Install the toner back into the printer. 3 - Install another toner cartridge. 3 - Verify that the e-label connector is firmly seated in connector
Contact a local HP Authorized Service Center for further assistance.
Sep 01, 2010 | HP LaserJet 2420 Printer
Why won't my canon printer MP460 read my ink cartridges? It keeps saying "Cannot read ink cartridges" on the black ink.
Hi, are you using Canon or refilled cartridges? If you are using Canon, there's a problem with the cartridge. If you are using refilled cartridges it's because the cartridge has been used. When you first put a Canon cartridge in, the printer reads the cartridge and knows it's a new one, I'm not sure of the mechanics of it, I don't know if it blows a chip or fuse in the cartridge but it can read a new one. If it's been used, it can't read it so you get the message that it can't read it.
Turn off the staus monitor and the message will go and you can carry on printing, it won't tell you when the cartridges are empty, you'll just notice the print quality going downhill.
Jul 05, 2010 | Canon PIXMA MP460 All-In-One InkJet...
I have put an "compatible toner cartridge in my Samsung CLX-2160N
By using refill cartridges there is no easy way to reset your printer to except it. The chip located on the cartridge is letting the printer know that the cartridge is emtpy. The solution is to buy a brand new cartridge and this will clear the message for you.
Jun 04, 2010 | Samsung CLX-2160N All-In-One Printer
Printer cannot find new black cartridge. Left cartridge missing.
The electronics are bad on your compatible and your printer can't recognize it's there. Return this cartridge and get your money back. The next cartridge you buy, ask if the electronics have been tested to be functional. I recommend refils from Cartridge World or Office Depot.
Apr 05, 2009 | Lexmark X4530 InkJet Printer
Printer won't read cartridge
If you have tried multiple cartridges and it still does not read the cartridges, then it is time to replace the printer.  The 920 is an older printer and has done good to work this long.
Dec 31, 2008 | HP DeskJet 920c InkJet Printer
Hp psc2410xi
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    OR
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    Print cartridge error
    try to take out the ink cartridge and check if there are any leaks inside. check also if there is still ink left in the cartridge. have the ink cartridge replace and the printer cleaned.
    hope this helps.
    fixya!
    Jan 29, 2008 | HP PSC 2410 All-In-One InkJet Printer
    Won't read Cyan cartridge
    The cartridge could be bad. The cartridge might not be in slot well. And the printer could also be bad. The software might need to be uninstalled and then reinstalled restarting your computer several times as well to reset everything. Try downloading printer drivers and software from printer maker support page. Check for known solutions at the printer site.
    Aug 02, 2007 | Epson Stylus CX6600 All-In-One InkJet...
    Lexmark X5470 All-In-One InkJet Printer Logo
    54 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
