Question about BOSE(R) SoundDock 10 Bluetooth dock (3108400000) Docking Station
Can i connect my laptop to a bose 10 sounddock via bluetooth. both devices are bluetooth enabled
4 Suggested Answers
SOURCE: No sound from Bose SoundDock
I had this problem on my SoundDock. My iPod would charge on the dock just fine and when I played my iPod on the dock, it would look like it was playing, but have no sound. Since my Bose was out of warranty, this is what I did to fix it. #1 Unplug the adapter. #2 Unscrew the four large screws on the bottom of the speaker and the three small screws under the dock. #3 You'll see one long ribbon connection and one very short one. Check to see if the ribbon connector coming from the front of the speaker system came loose from the green board. You'll only be able to see 1/2 an inch of it sticking out, and it's not easy to plug it back in, but it's possible. Just take your time. #4 Carefully put everything back together being very careful not to let the ribbon fall out of the plug again. #5 Make sure to plug in the DC adapter the correct way. There's a very subtle difference, but there is a difference. There are four prongs - two are square and two have slightly rounded corners. If it's not plugged in the correct way, the dock will have a static clicking sound. On my adapter, the words "DC power" are on the top of the plug.
Posted on Nov 24, 2009
  • 17 Answers
SOURCE: Bose SoundDock will no longer
My guess is that the iPod connector in the Sounddock is loose or damaged. You can get a new connector and solder it on yourself (very difficult!) or you could get a replacement PCB at http://www.chargeconverter.com/store/index.php?route=product/category&path=37 which is quite easy to replace (see http://ridax.wordpress.com for description).
Posted on Feb 14, 2011
SOURCE: Bose Sounddock problem
(1) If I had my iPod in the dock, disconnected and reconnected the power it would play. If I pushed either of the volume controls on the Bose system, sound would disappear. Unplug and Replug the Bose power supply, sound returned. (2) Using the remote, if sound was playing and I pressed a volume control, sound would disappear. Unplug and Replug the Bose power supply, sound returned to default volume. (3) With sound, hit pause then play, no sounds.
I saw these solutions but had no compressed air to clear out the Bose side of the connection or the iPod Nano (2nd Generation) side of the connection. Inspection of the Bose side of the connection showed that it was quite clean. I suspect that the problem was with my iPod. I used an iPod USB connector, inserted and removed this several times from my iPod. I hoped this would help clear the connection pads inside the device. Worked. Back to the good life with music
Posted on Sep 28, 2011
My bose bluetooth mobile won't link to my apple I pad,when I try to link them ,my I pad tell me that the sound system is not on
Switch your Bose Speaker off.
Open iPad - Settings - Bluetooth - Switch Bluetooth Off
Switch iPad Bluetooth On and quickly switch Bose Speaker On.
They should talk to each other as they find each other and fall in love :>)
Bose Bluetooth speakers from I-pod are listed in the link below with manuals.
On my Bowers and Wilkins T7 Bluetooth speaker you have to press the Bluetooth button on the SPEAKER the first time you connect it. After it is paired, it finds itself as soon as the speaker is turned on. I can highly recommend the B&W T7.
BLUETOOTH Speakers Bose
Jan 02, 2016 | Apple Bose SoundDock Series II Digital...
Bose soundock 10
You want to plug the SoundDock into a 220 receptacle, is that correct, and the Soundock works off of 120v., correct. I tried to find the specs for the Bose SoundDock, i.e. its wattage rating but it seems that Bose does not publish these specs. At any rate a 220v to 120 v converter should work
The 300 watt converter listed above should work fine. Wahtever converter you use, make sure it operates at 60/50 hz.
May 19, 2014 | BOSE(R) SoundDock 10 Bluetooth dock...
Blue tooth speaker wont turn back on.
Unable to connect to a device?
Before attempting any of the following steps, make sure that you are running the latest software version on your SoundLink Wireless Mobile speaker. Click here to visit the software update center and update your speaker. If you are still having difficulty connecting to a device after updating the software, continue to the troubleshooting steps.
Unable to connect with a previously paired device?
Please try the following to resolve this issue:
Perform a product resetTo perform a SoundLink speaker reset, following these steps:
  1. On the speaker, press and hold Mute for 10 seconds, the LEDs will flash briefly
  2. Press Power to turn the SoundLink speaker back on
Clear the pairing list on both the SoundLink Wireless Mobile speaker and the source
  1. On the SoundLink speaker, press and hold the Bluetooth button for approximately 10 seconds until you hear a tone. The SoundLink speaker clears all Bluetooth devices from its memory and becomes discoverable
  2. Clear the list on your Bluetooth device. For more information, please refer to the manufacturer of the device
  3. Perform a product reset. On the speaker, press and hold Mute for 10 seconds, the LEDs will flash briefly. Press Power to turn the SoundLink speaker back on
  4. Try pairing the device again by following these steps:
    1. With the Bluetooth device and the SoundLink speaker both turned on, press and hold the Bluetooth button on the speaker for three seconds to make the speaker discoverable. The Bluetooth indicator will slowly fade on and off approximately once every second to show the speaker is in discoverable mode
    2. Set your Bluetooth device to "Discoverable." This will allow your device to discover the SoundLink speaker
    3. On your device, locate the Bluetooth device list. Select "Bose SoundLink" from the list
    4. If your device asks for a passkey, enter digits 0000 and press OK. Some devices also ask you to accept the connection. Your Bluetooth device indicates when pairing is complete. The SoundLink speaker indicates pairing is complete when the Bluetooth indicator stops fading on and off and remains on
Be sure the SoundLink speaker is within 30 feet of the Bluetooth deviceThe system is designed to operate at a range of 30 feet. However, performance can be diminished by obstacles such as walls or metal, and may also be affected by other Bluetooth devices. Try moving the SoundLink speaker closer to the Bluetooth device.
Be sure the source's Bluetooth function is OnMany Bluetooth enabled devices have an option where the Bluetooth feature can be turned On or Off. This option may be set to Off to save the battery life of the device. Be sure this option is set to On. If the Bose product is paired to the Bluetooth enabled device, it should automatically reconnect when its Bluetooth function is turned on. If the Bose product doesn't automatically reconnect, manually select the Bose product within the Bluetooth list on the device.
Manually connect the SoundLink speaker in the device listSome devices will pair to a device but not automatically connect. Go to the pairing list of the device and check if this is the case. If it is, try connecting to the SoundLink speaker.
Oct 20, 2013 | Just Wireless Bluetooth Headset Wireless...
My Toshiba L775 -S7307 won't stream to my Bose Sounddock 10. Does my computer support A2DP?
According to the Toshiba website, your laptop does not have Bluetooth, with means it won't have A2DP. You can buy a dongle to get Bluetooth to your laptop.
http://www.toshiba.com/us/computers/laptops/satellite/L770/L775-S7307
Oct 14, 2013 | Toshiba Computers & Internet
Were q ifind parts for mi bose sonuddock theres no audio comen out
Hello, contact www.Invebo.com. they support the Bose Sounddock and also sell the USB charge upgrade kit to enable youto charge the Iphones on a Sounddock Original.
Aug 09, 2010 | Bose SoundDock Digital Music System for...
Bose Docking Station incompatibility with IPOD Touch
You need to reset your ipod. You can go online to find out how to do this. I had to do it with mine and then it worked perfectly.
Aug 08, 2009 | Bose SoundDock digital music system...
Does the new bose dock station charge the new ipod touch (32g)?
The new SoundDock II charges your new iPod touch and is fully compatible all iPods and the iPhone 3G. Also the SoundDock Portable will do this. But..
Better news-> Call Bose. They can upgrade the 30-pin connector to charge via USB-only and function with the remote as well. $99. This will make your iPod touch 100% compatible and somewhat future-proof your SoundDock. If the SoundDock was purchased within 90 days (at full retail price), they will do the upgrade for a smaller fee or even free I think.. (new 1 year warranty given with repair/mod) btw- This is an Apple issue, not a Bose issue. All 3rd party iPod connection devices had to make this change at some point.
May 31, 2009 | Bose SoundDock digital music system...
BOSE(R) SoundDock 10 Bluetooth dock (3108400000) Docking Station Logo
735 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
