Hi
I found the following description for your error Description:- The rotation of the main motor is faulty.
Detection is executed every 100 msec after the start of motor rotation; however, the drive detection signal is absent for 2 sec. Remedy:- Replace the main motor. Replace the DC controller PCB.
This was here: Error Codes Canon iR4570 Code E010 0001
On this webpage where you can change the code you are receiving to a different one if required (or view them all) by using the drop down menus along the top of the page. You can also change the make & model using the drop down menus if you wish. You can also get a Service Manual from this page using the link.
Hope this is helpful, if so would you please register that with Fixya
Cheers
QUOTE
Detecting Error E007 at canon copier iR2270, iR2870, iR3570, iR4570, iR3530.
As part of its protective mechanism, the machine checks for the following error conditions.
Error Code: E007 Detail: 0000
Sympton: The fixing film rotates in an abnormal way.
Description: The reading of the main thermistor is in excess of 100 deg C with the fixing motor in a locked state and in addition, the machine fails to detect the marker signal for 6 second.
UNQUOTE
Good luck and please post back that you are successful, giving thumbs up, or that I can be more helpful.
OK, but first try to clear the error under service mode, then replace fixing film assy, for EU 240V is FG6-6041. To clear the error: * 2 8 * COPIER FUNCTION CLEAR ERR OK Turn off and on ( main switch )
its due to excess tonner . and the same solved. thanks for your reply
