Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side not dispensing ice out front
Hi-- We remodeled our kitchen; when we put the fridge back and reconnected water line, it made ice and dispensed water, but when lever was was moved to "crushed ice" only water came out. When the lever was moved further right for "ice cubes" nothing. I undid the top hinge and pushed the 5-pin connector together while my wife tried the selector lever. Now, on crushed ice, no water ran out (good) and the motor hummed but no ice pushed out front. On "ice cube" the motor hummed--no ice. Lifted the tray out-- spiral dispenser rod turns manually, not frozen stuck. Seems like the motor just isn't turning. We've bought new appliances, but want to have this one working correctly to sell. Any solutions out there? Or are we looking at a big repair bill....... Any suggestions greatly appreciated!
    Champion:
  • 210 Answers
Could be frozen auger motor, try turning motor by hand.
Posted on Jul 22, 2008
Water dispenser in door does not dispense
Had this happen on my LG side-by-side a few years back. It's a common part. Find the version for your make and model. Easy ti replace. It is located where the water suppy connects to the bottm refridge.
http://www.amazon.com/LG-Electronics-MJX41178908-Refrigerator-Water/dp/B00AUDAJ0I
Oct 25, 2015 | GE Profile 26.6 cu. ft. Side-by-Side...
Water filter/ice system does not work. Water goes into the fridge but no ice is made and no water comes out of the front door dispenser
No water and no ice sounds like a bad water valve. It is located behind the panel where the water line enters the fridg.
Oct 18, 2009 | GE Profile PSW26P Stainless Steel Side by...
No ice and no water dispenser
Would have to talk you thru with chat .
Jul 17, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile Performance - No water dispensing or ice making
NOT ENOUGH WATER PRESSURE AT WATERLINE OR WATER VALVE IS BAD AND NEEDS REPLACED
Jul 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water & Ice dispenser quit on Kenmore 106.9535110
recheck the electical connection at upper frz door hindge sometime a wire could be pushed out but check to see that the control lock was not set by accident
Dec 11, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
Dec 06, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
GE Profile side by side fridge - water dispenser doesn't work
More than likely, your water line is freezing up in the door. You can remove all of the ice cubes and lower the freezer temp to about 3. Leave the freezer door open for about 5 minutes or so and if this does not work, leave the door open a little longer. Also, disconnect the water line at the base of the freezer door, near the floor, and press the dispenser lever. If you have water there, you most likely have a frozen line in the door. Changing the water filter often will help but it is not the answer and is can get quite expensive. By the way, Make sure to hold the dispenser lever forward for at least a couple of minutes each time you test for water flow. If you do not get water at the connector at the base of the door after you have disconnected the line, you have a problem with the valve in the back of the refrigerator.
Nov 11, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GSS25L GE no water
Check the electrical connector that is next to the water pipe at the bottom of the freezer door
Aug 19, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Water/Ice Dispenser is not working
at the very least replace that water filter.clogged water filter will reduce water pressure to the line.
Feb 24, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
229 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
