Question about Hoover 24 in. HD97E Free-standing Dishwasher
Hoover HD97E dishwasher Error code E4 after running for 4 minutes - how can I fix this please?
5 Suggested Answers
SOURCE: Dishwasher problem powerpoint IDW12
clean the filter on the intake pipe, just done mine.
Posted on Dec 02, 2008
  • 209 Answers
SOURCE: dishwasher time E4
check for open circuit electrically with the heater element
Posted on Oct 15, 2007
daba2
  • 10 Answers
SOURCE: hoover dt999
E4 Error on other machines (eg. Baumatic) means that the bottom catch tray (condensate trap) below the machine has too much water in it. This condensate is supposed to evaporate away, but too much will mean it builds up over a period of time. There is a float that trips a microswitch in my Baumatic which detects this, it only needs 2 - 3mm of water before the microswitch is activated.
If this is the problem with your machine (try it annd see), there are several solutions posted in forums - best seems to be to remove plastic access hole caps from base and mop out the tray with sponge. TURN OFF AT MAINS BEFORE POKING AROUND INSIDE THE BASE. May have to repeat at regular intervals to.
What causes it ? - I think it is excess condensate from steam inside the wash cabinet, follow the manufacturers advice to open the door as soon as the wash cycle has ended to release as much steam as possible to stop it condensing inside the machine.
Peramnent solution ? - I don't think possible - My guess is it's just a bad design.
Dave
Posted on Oct 04, 2008
  • 4 Answers
SOURCE: error e3
Drain pump probably not working. Put machine on cycle 7 and it should turn on the drain pump straight away. you can hear this near the bottom of the machine. if it is silent hten the pump probably needs replacing. I repaired mine be removing it and then dismantle the magnet from the tube then give it a good clean out.
Posted on Mar 02, 2009
My dishwasher is just flashing F10 all the time
Codes are pretty generic between Hotpoint, Hoover and Whirlpool.
Heating element fault
Issue: The LED lights on your dishwasher are displaying in the following sequence (please see below these error codes for your LED reference
  • LED 1: OFF
  • LED 2: ON
  • LED 3: OFF
  • LED 4: ON
Action: We recommend you call our customer service centre to book an engineer.
Here is the Hoover site.
http://service.hoover.co.uk/advice-centre/dishwashers/
Error codes Hotpoint
Jun 19, 2016 | Hoover 24 in. HD97E Free-standing...
My Teka DW7 57 FI VRO2 dishwasher shows the error code E4.
E4 means it is overfilled because of too much inlet water. Turn off the main supply. Remove excess water from the base pan and restart the dishwasher. DW7 57 FI Teka official website Bathroom Kitchen Professional Kitchen and...
Apart from using the manual instructions, you can get technical help from the company directly too.
Hope this helps!
May 15, 2016 | Dishwashers
Dishwasher has been stored for a few months, we have just connected it back up and switched and error code E4 has come up. What does this mean and how to I rectify it?
E4 means that the dishwasher has a problem with discharging water. Check that the discharge tube is not bent and the siphon is not blocked and the filters are not blocked. Depending on how you stored the dishwasher, check for evidence of rodents or insects building nests in the unit.
The manual for the HD97 is available from Hoover at http://service.hoover.co.uk/manuals/Manuals.aspx?Section=3 . Enter the model number and the link will come up. The manual for the free-standing version does not seem to be available separately.
I hope this helps.
Jun 12, 2011 | Hoover 24 in. HD97E Free-standing...
My dishwasher says E4
The error code E4 means selector switch pads is stuck.
First try a hard reset. Unplug the unit for 10 minutes and then switch on the dishwasher. Most cases you won't get the error message.
If you still get the error message then you need to take to service center to get it repaired. Mostly, the inner connectivity between the pad and circuit board is loose/bad.
Hope this helps.
Shane
Feb 27, 2011 | Kenwood KDW243A Builtin Dishwasher
Error code E4 is on our display of our KDW243A dishwasher - what does this mean please?
Error code E4 means there is an overflow. Water is probably trapped. If you get error code E4, just tilt the machine back about 45 degrees and let the water drain out. It should come out on both sides. Then, you should be good to go.
Dec 14, 2010 | Kenwood Dishwashers
I have just bought the above dishwasher 2nd hand
cold water will not clean the dishes/aka break down the detergant
May 31, 2010 | Hoover 24 in. HD97E Free-standing...
Leaking water from door
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
stuykx
May 19, 2010 | Hoover 24 in. HD97E Free-standing...
Error 4
check out the following link... i think it will be useful for u...
http://www.fixya.com/support/t1213494-dishwasher_flashing_error_code
thank you good luck
Jun 02, 2009 | Hoover 24 in. HD98E Built-in Dishwasher
Error e3
Feb 03, 2008 | Hoover 24 in. HD97E Free-standing...
Hoover Whisper HD97E
Try checking the water level, and level switch? Is the outlet hose high enough of the floor? If you tip the machine back you should see one or two clear plastic tubes, take one end of these and blow through them and the do it the other way round.
Nov 26, 2007 | Hoover 24 in. DT999 Free-Standing...
Hoover 24 in. HD97E Free-standing Dishwasher Logo
438 people viewed this question
Top Hoover Dishwashers Experts
Gil Shultz
Are you a Hoover Dishwasher Expert? Answer questions, earn points and help others
