Question about Philips Audio Players & Recorders
I have the philips 6 gb go gear and when i upload pics they dont appear on the console can you please help!
  • 8,596 Answers
Make sure the pictures are in a format recognized by the spec sheet - available form Philips website if you have lost it - also, make sure the photo size is not too large.
Posted on May 27, 2008
Want to use my current speakers with a new surround sound system. Current system is 5.1 channels, rated at 100w per channel @ 8. Ohms. New System is rated 145watts, 5.2 channels at 6 Ohms. Will b ok?
Hi Ronald.
8 Ohm speakers will work just fine as replacements for the
6 ohm speakers. When fitting speakers you need to consider
The power handling capability. The impedance and the frequencies
involved. Power handling is expressed in wattage ie 100W.
Unfortunately this can be expressed in rms, max or peak music. The rms value (root mean square) is the only really relevant figure as this is the continuose handling power at 1 KHz. The impedance
is the resistance that the amp sees but is not a dc resistance and
varies with frequency. The lower the impedance the more power
will be drawn from the amp. In the event of a short circuit across
the speaker the amp will try to deliver infinite power into an infinitly
small load in an infinitesimal amount of time and will self destruct.
Using an 8 Ohm speaker draws less power than a 6 Ohm speaker.
Connecting speakers in parallel; results in the impedance beingreduced. For example two 8 Ohm speakers in parallel will result
in a 4 Ohm impedance load but in series will be 16 Ohms.
Incidentally the the .1 (5.1) is the sub woofer which only has
to handle the bass frequencies, a small percentage of the
amplifiers overall frequency response..
Connect your speakers and then power up the amp last
after double checking there are no shorts on the speaker
cables.
All the very best from Vintie.
Jan 07, 2017 | Audio Players & Recorders
Headphone jack on my phone isnt working right dont know whats wrong been having the problem for a few days dont knoww how to fix it
Take it to a cell phone repair shop locally and let them look into it, you could need to have a new main board installed.
Jan 06, 2017 | The Audio Players & Recorders
How do I remove the speaker that is held in place by plastic circle that has been melted in certain spots over the edge of the speaker.
You can just use some snippers carefully then when you replace it either use gorilla or a glue gun.
ELECTREPAIRUSA@ELECTREPAIRUSA or you can contact us at that address as we repair/renovate all items electronic and electrical old and new.
Feb 06, 2016 | Audio Players & Recorders
MY PANASONIC 5CD STEREO SKIPS WHILE PLAYING CD'S I HAVE USED A HEAD CLEANER AND IT STILL DIDN'T WORK.I HATE TO DISCARD IT.
The laser pick-up unit fault [weak]. You have to replace it with a new one of similar number. Contact any service technician. To replace this part, you have to take out the whole mechanism from the system; and this is a skilled work.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. Electro help
Dec 26, 2014 | Audio Players & Recorders
I have a matsui MCH 750 mini hi-fi,i am having problems with the FM radio channels,sometimes or most of the time i get what seems like the channels are not tuned in properly or the aeriel is not good
If you're sure the FM signal strength at your area is good, the fault is with its AFT [Automatic Fine Tuning] system circuit inside the device. Contact any service technician to get it repaired. This is not a user repairable fault. http://electronicshelponline.blogspot.com/
Nov 01, 2014 | Audio Players & Recorders
I have a Rowe R80 jukebox and after moving it it has no sound through the speakers I am in New Zealand
Well, in addition to all the fine suggestions that are here, I would like to add the simple and easy things that may have happened during the move.
IF YOU ARE NOT GETTING A LOUD POP WHEN THE MACHINE IS POWERED ON.......
1) Make sure that the wires on the terminals below are still connected to the screws. There is one ground and one each for left and right. The lower the tap the lower the (max) volume of the jukebox.If they are not connected there will be no sound.
There is a jumpers on the terminal strip where the volume control connects. Make sure that these connections are correct and tight. Also make sure that the jumpers did not fall off.
If you are getting the loud pop in the speakers when the power is turned on .....
Check the plug on the side of the mechanism, just below the back of the tone are.(looks like a little tube socket) Check to see that it is connected to the mech and the CORRECT PLACE on the amplifier. It mat be possible to have this end in the wrong place. bf77613e-82a3-4e37-b8fe-cc80f4d4dbcb.jpg
Check all all your connections against the pic.
I hope this was helpful.
Mar 24, 2014 | Audio Players & Recorders
HOW TO INSTALL GAMES IN MP6
Hi there:
Just as you do it on others, like phone. Click to install. No necessary for tutorial. Also could check this video...
Hope this helps.
Nov 14, 2012 | Audio Players & Recorders
I need philips tuner amplifier AH718 SERVICE MANUAL FOR REMEDIAL MAINTENACE
A service manual would have to be requested directly from Philips.
Sep 01, 2010 | Philips Audio Players & Recorders
22 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
