Question about HP Officejet Pro L7680 All-In-One Printer
Random I have multiple problems when printing from a computer -- including random sheets that print. Also, duplex thing doesn't work. Prints a bit, then stops. Nightmare!
  • Joel Jupp May 27, 2008
    officejet pro l7680 all-in-one.
    basically, the printer doesn't seem to do anything right. i can print a page or two sometimes, but other times, it seems totally defunct.
    Problem Solver:
  • 5 Answers
What's the model and brand? Need more specific symptoms.
Posted on May 27, 2008
HP Deskjet 970 Some Duplex Pages Printed with One Side Blank
You have to check the settings when sending a print job through
Mar 21, 2017 | HP DeskJet Office Equipment & Supplies
Paper Jam in Duplex mode when printing more than 1 sheet
check between the rollers there will be small bits of paper jammed in that is the reason.
Sep 09, 2008 | Minolta magicolor 2350 Laser Printer
My scanner just started smearing the first page of a duplex to pdf but when I scan just front of document it doesn't smear it
Your question is not clear.
Sometimes using technical jargon makes it harder for people to understand each other (this applies to both askers and answerers).
I always advise askers to use normal language as much as possible and answerers to do the same and where jargon is unavoidable, to explain as they go along.
Please post again to clarify what you mean by "..a duplex to pdf..", in normal language not in technical jargon.
A PDF is not a real, physical document. It is a digital document on a computer or a webpage created in PDF format.
A Duplex document is a real document, printed on both sides of each sheet of paper.
If you are trying to scan a multiple page Duplex Document using the Sheet Feeder of your scanner, the ink on the reverse side may be getting caught up in, affecting and/or staining one of the rollers in the Sheet Feeder.
The bottom roller in most non-industrial Scanner Sheet Feeders expects to touch only the plain reverse side of a sheet of paper as it is passed through and turned over to rest on the Platten (scanning surface) of the scanner ready to be scanned.
Multifunction printers with built in scanners and sheet feeders and duplex printing capability are designed in a way that makes them more forgiving of dealing with duplex printed paper.
Duplex printing printed in a laser printer is less likely to cause a problem as long as it is allowed to dry thoroughly. Inkjet printing that is allowed to drry thoroughly should also be okay.
If the scanning is being attempted very soon after printing, then the wetness of the printing may be the problem.
Sheet Feeders that handle duplex printed sheets invariably become stained and need periodic cleaning.
If the document is not too long, you may have to scan it manually, page-by-page.
If the document exists as a PDF somewhere on your computer or on the internet, then it is unclear why you would need to scan it. This is why your question is puzzling.
Post a further comment, if this answer does not help you solve the problem.
I hope this helps.
Aug 25, 2011 | Fujitsu fi-5750C Flatbed Scanner
HP 5Si printer, multiple images on one sheet HP 5Si, Windows XP, Networked Jetdirect card, 20MB memory, duplex option. Unit worked fine before. Power outage occurred, seemed to have knocked out the...
If this is a "ghost" image like whats on the top of the page is re-appearing on the middle and/or bottom. The fuser is defective and needs to be replaced. Part # RG5-4447
Jan 03, 2011 | HP LaserJet 5si Printer
Printer keeps printing off blank pages or ones with random characters in the corners or top of page .
Follow these steps :
Disconnect the USB cable from your computer.
Make sure that letter-size paper is loaded in the sheet feeder.
Press the On button while also pressing the Ink button.
This product prints an operation check page that includes a nozzle check pattern. or get more information from here
Sep 01, 2010 | Brother DCP-8060 All-In-One Laser Printer
Date/time stamper will not print correctly
mine is doing the same thing. I read that the 3V battery may need to be changed.... so I changed the 3V and all four AA batteries and hit reset and am still experiencing the same as you. Random **** printing when display seems okay. Never same stuff twice. Very frustrating.
Jun 18, 2009 | Dymo DateMark Date/Time Stamper
HP DeskJet 1560 - multiple paper feed
This link may not help you to print duplex, but it will possibly explain why you're having problems...Make sure you fan the paper before loading it. You might try putting a fan on it to dry out the ink as it prints...or try a heavier paper. Good luck! If you google duplexer feed problem you'll see this is the subject of numerous patents and attempts to resolve the very difficulty you are having.
(Maybe another of the same model would work better? Hp should exchange it if it's not working, no?)
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 16, 2009 | HP D1560 Deskjet Printer InkJet
Printer stops in process of duplex printing
Duplex solenoid not working. It's worth getting it fixed.
Jan 02, 2009 | HP LaserJet 1320 Printer
Epson Stylus Photo R260 doesn't complete prints
Make sure that you have the correct paper size set in your printer settings. Incorrect size would cause the problem you describe.
Sep 17, 2008 | Epson Stylus Photo R260 InkJet Printer
Stops printing a full page picture half-way through and prints the rest on the next page in some random place. I have also had some problems printing text in the same way. The picture I am trying to print...
I noticed that when I restart Windows, I can print one sheet fine, the second sheet prints only half. Restart again, and I can print one more sheet.
My local Canon helpdesk proves as unhelpful as all helpdesks these days.
Dec 07, 2007 | Canon PIXMA MP600 all-In-One InkJet...
HP Officejet Pro L7680 All-In-One Printer Logo
57 people viewed this question
Ben Johnson
