Question about Saeco INCANTO DELUXE Espresso Machine
I have a new Incanto Deluxe. I can not start the machine because it always indicates "fill watertank" even the tank is fully filled up.I tried to ventilate the system but pump doesn't start. Switching on and off did not help. Immediatley after self test I have the same reading. Any idea ?
    President:
  • 1,618 Answers
When inserting tank slide it down the back so that it makes contact with the machine, sometimes the reed switch does not read the magnet in the tank.
Posted on Oct 04, 2010
I purchased this machine only 2 days ago and it permanently displays the 'fill watertank' message. I've tried filling and refilling the tank and turning the unit off...some advice would be very helpful1
In the water tank there is a float with magnet inside. When water is filled it should rise up to indicate the machine has water.If it is not floating up ,try putting some foam underneath to raise up.It should help.
Oct 18, 2010 | Saeco INCANTO DELUXE Espresso Machine
Our Comfort machine won't brew and constantly displays, "Fill Watertank" even with the tank full. In order to brew, one has to remove the water tank then gently lower it only partially down in place. As...
Hi
The magnet in the water tanks is either upside down or has sunk to the bottom of the tank. It should float to the top of the cage it is in and it should have a flat top not rounded. If its rounded side up the magnet is upside down. This is what would cause your problem.
Sep 22, 2010 | Saeco Magic Comfort Plus Espresso Machine
The level float sinks to the bottom and it indicates it's out of water but it is , I have the incanto deluxe, what can i do to fix it or can i get a new one
You can get a new float from servicesunlimited or wholelattelove, I think there is a hole in the one that you have and it ges fill with water and sinks.
Sep 15, 2010 | Saeco INCANTO DELUXE Espresso Machine
Exactly the same problem - fill watertank message
clean unit with vinegar and water. run two or three cycles then flush with two or three cycles of straight water
Jun 13, 2009 | Saeco Incanto Classic Espresso Machine
The machine says fill watertank. ventilate. the
Open the hot water valve, and run about a cup of water, this will engage the pump and fill the circuit.
Jun 04, 2009 | Saeco Vienna Digital Coffee Maker,...
Fill Water tank - Ventilate
Hi Mike,
Make sure the magnet flow up, if it flow up and you still get fill water tank then you have to replace the magnet.
If you get ventilate all time, try to remove the filter and try again.
/Mirran
Aug 23, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Incanto De Luxe S-Class - Fill Watertank constantly on
The machine appears to be blocked due to limestone formation in water piping. Suggestion is decalcify following instructions of manufacturer .
Jan 13, 2008 | Saeco Incanto Classic Espresso Machine
Fill Watertank Message
The black thing floating in the water tank is a plastic shell with a magnet inside. If you clean it...make sure you reinstall it with the tapered (smaller) side down. There is a slight size difference BUT it will make ALL the difference in the world.
I had no idea there was a magnet in that black/greyish case. The direction of the casing is important.
I had the same problem and that solved it!
Jul 29, 2007 | Miele CVA615 Espresso Machine
Saeco INCANTO DELUXE Espresso Machine Logo
309 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
