Question about Kenmore 88732 Top Load Stacked Washer / Dryer
It doesnt agitate, it merely spins - Kenmore 88732 Top Load Stacked Washer / Dryer
    Genius:
  • 1,417 Answers
There are several reasons that a washing machine won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work down to the more difficult causes.
INSTRUCTION BELOW
  • A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
  • 2 If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
  • 3 Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
  • 4 Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
  • 5 If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall
  • thanks and good luck.
    Posted on Oct 03, 2010
    Wont agitate or spin everything else working
    hi Paulmahoney.
    If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drive washing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
    read up some more at this link might help you out some more.
    Washer Doesnt Agitate or Spin
    or this link.
    washing machine Wont agitate or spin Google Search
    Dec 14, 2017 | Washing Machines
    My Hoover500MB washing machine sometimes doesnt agitate or spin but will empty and fill
    99% of those problems are with the lid switch. Check make sure it is functioning properly.
    Oct 03, 2012 | Washing Machines
    My WHDSR109J8WW Top Load Washer will not agitate or spin. When to the spin cycle something clicks as if trying to spin but does not. Checked belt...fine. Did the reset motor troubleshoot...did not help....
    hi Jlove.
    Washer Fills but Does Not Agitate. If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drive washing machines do not have belts..
    Top Load Washer will not agitate or spin Google Search
    Dec 13, 2017 | GE Washing Machines
    Kenmore 90 Series Heavy Duty Washer - Agitator doesnt spin
    THIS IS A TYPICLE PROBLEM . BETWEEN THE MOTOR & THE TRANSMISSION THERE IS A COLLECTOR ASSEMBY (THREE PIECE
    SET) REAL EASY TO GET TOO EASY TO FIX . ALSO COST EFFICENT
    Sep 21, 2009 | Kenmore 24032\24036 Top Load Washer
    Agitator doesnt start
    Sounds like the lid switch is acting up on you.
    Jul 26, 2009 | Whirlpool LTE6234D Top Load Stacked...
    Washer doesnt agitate but spins and drains. how
    Agitator pulls straight up and off. (you may have to slip a belt under it to pull it..... a hard yank) Drive coupler is nylon part you will now see, held on by one bolt. Remove bolt and pull off. If it won't come off, just break it apart with a chisel, as you need to replace that part anyway.
    Jul 19, 2009 | GE WBSR3140DW Top Load Washer
    Replace the agitator drive coupling dome under the agitator. It is stripped out from overloads.
    Jul 05, 2009 | GE WBSR3140DW Top Load Washer
    Kenmore 88732 Top Load Stacked Washer / Dryer Logo
    41 people viewed this question
    Sal De
    fordexpert
    Jim Goldsmith
    Jim Goldsmith
