Question about Hotpoint FFA70 Bottom Freezer Refrigerator
Fridge and freezer not getting cold - Hotpoint FFA70 Bottom Freezer Refrigerator
  • Hotpoint Master
  • 43,501 Answers
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Dec 27, 2010
Fridge of fridge freezer does not get cold (bosch excel KGN34X61GB-05)
Sounds short of refrigerant or very blocked up condenser. Is there a lot of heat from the back/ underneath>
Mar 21, 2014 | Freezers
Bottom freezer left open overnight. Freezer does not work anymore. Top fridge does not getting cold as it should be.
Your fridge gets it's cold air from the freezer. If the freezer is not working then the fridge won't get cold.
May 26, 2011 | Refrigerators
The refrigerator doesnt stay cold. freezers fine. the refrigerator will get cold if you don't use it for a long time
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 04, 2009 | Refrigerators
Fridge (KBRA22KLSS00) has lower freezer compartment. Fridge is running, & freezer is cold,however upper portion of fridge is not cold. Is there a fan or a control to bring the cold into the fridge...
Aug 31, 2009 | Refrigerators
Fridge won't get cold
Check to make sure that the fan in the freezer is running whenever the compressor turns on to cool the unit down. If the fan's not going, warmer moist air from the fridge will make the air duct frost up. The fan needs to be running to blow the cold air into the fridge section.
Apr 28, 2009 | Refrigerators
MY FREEZER IS GETTING TOO COLD AND THE FRIDGE IS NOT GETTING COLD AT ALL
In most refrigerator freezers, the refrigerator gets its cold from the freezer. The evaporator fan circulates air over the coils in the freezer and cold air circulates into the refrigerator through vents. If the vents are blocked or closed, then the fridge will not get cold enough but the freezer will. If neither is cold enough, then the number of possibilities increases.
Lowering the freezer temperature will increase the cooling cycle activity. Setting the refrigerator temperature may have little affect on the cooling cycles because it simply changes the vent opening size. Decreasing the fridge temperature opens the vents more and increases air circulation from the freezer.
The temperature can be adjusted using the controls found inside the refrigerator or freezer. The ideal freezer temperature is about 0 to 5 degrees (F) and about 38 degrees (F) for the fridge.
Measure the temperature by placing a cup of water with a cooking thermometer into the refrigerator for about 2 hours or more. To test the freezer, substitute alcohol or cooking oil.
Oct 08, 2008 | Whirlpool Refrigerators
Fridge not cold
my freezer is over freezing and my fridge is not cold. I have a whirlpool where the freezer is on top and the fridge is on the bottom. I need guidence in trying to figure out the problem.
Sep 29, 2008 | Kenmore 64802 Top Freezer Refrigerator
Freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Aug 05, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Admiral side by side
All the cold air from your freezer gets pushed into the fridge with a fan in your freezer section. So your problem is from the fact that this cold air isn't get to your fridge.
- the door that allows this cold air into the fridge, normally in the top left corner of the fridge, is stuck shut and needs replacement.
-the freezer isn't defrosting and restricting the air flow
-the temp controller for the fridge is damaged and thinks that the fridge is cold enough.
Nov 15, 2007 | Admiral 26 cu. ft. Side-By-Side...
Hotpoint FFA70 Bottom Freezer Refrigerator Logo
55 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal DeAngelo
Dan Webster
Dan Webster
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
