Question about Miele Novotronic W1918A Front Load Washer
Miele W 1918 washing machine front door seal replacement
Is this something that can be done easily? or should I get Miele to come and do it? How much will it cost parts/labor?
The seal on the front door runs around 60 bucks and its quiet easy replaced takes 1/2 hour
Posted on Jun 06, 2008
How to replace door seal miele novotonic 502
Hi Adrian,
Open machine door then turn power off. Remove 3 bolts on front of machine. Remove the soap draw and remove the 2 (or 3) screws.Separate the front of the door seal from the metal front of the machine and fold the door seal in towards the drum. Front of whole machine will now hinge open (there is a spring catch at the bottom where the pump filter is - so dont be scared to use a little force). Use a screwdriver to loosen and remove the metal wire clamp that sits around the door seal. Once off, door seal can be removed from the outer drum. Replace with new door in reverse order. Note that putting on the new door seal to the outer drum is a bit of an art and may take you a few attempts (so be patient but persistant), as you must make sure it is seated in position correctly. Good luck.
Aug 19, 2015 | Miele Washing Machines
Miele w1918
Link to user manual. Code listed on page 32 indicates internal error Call service department.
Miele 1918 Operating Instructions Manual Page 32
Aug 03, 2014 | Miele Novotronic W1918A Front Load Washer
How do I change the seal on a Miele W526 washing machine?
Dont remove eather!
Only the front!
Remove seal front ring on the front. Its one 10mm bolt under the seal on the front, undo this, and the two srews on the door lock. And two srews on both sides under the front. The the whole front is now loose and can be removed.
Then take of the inner seal ring, and unplugg drum ligths/hoses if any.
Replace seal....
May 07, 2014 | Miele W526 Front Load Washer
Miele W 4840 door seal
the front rubber is moulded to the front hub at the back rubber under the lip is a wire belt that needs to be loosened to release the back rubber making sure both fron and back of the rubber is sealed coretly when putting it back on
May 07, 2012 | Miele W4840 Front Load Washer
My miele w3033 has mold in the rubber gasket. wha...
hi,
you can purchase a cleaning product to run through the machine but white vinegar on a 95c wash also works.don't put any clothes in it though. if it has eaten into the door seal too much you can easily have them replaced. always leave the door open after each wash for about half an hour to let it dry out otherwise a damp environment is perfect for bacteria to develop. lots of hot washes and the door open prevents this.
May 19, 2010 | Miele W2240 Front Load Washer
My miele novotronic W 1918 has a bad smell. Is there a filter that i should clean? Can't find it.
There is a fluff filter in the bottom left hand corner behind the flap. have a small tray, like a baking tray underneath it and open the flap with a flat lever or the miele yellow key. Turn the tap about 1/4 of a turn and collect about a litre of water from the unit. when it has stopped draining unscrew the tap all the way out and clean the fluff filter which is the tap in your hand. also have a look in the hole and you will see the drain pump. make sure this is free of any foreign particles and then re-screw the tap back making sure it is tight.
To avoid the smell in the unit run the machine on a few 95c washes. you can use a cleaner or just white vinegar as a cleaning agent. after every wash keep the door open for about 30 mins to let it dry out as shutting the door is then a perfect enviroment for bacteria to develop and the smell.
Also check the door seal for any foreign particles every wash.
Hope this helps.
Jan 29, 2010 | Miele Novotronic W1918A Front Load Washer
Miele W 1918 washing machine door seal replacement. Can my husband do it? Can't find instructions. Have had this problem before and it took the service rep ~15 minutes t o pop off old one and replace with...
I have done it. I had someone fix my machine once and they put it on wrong so I had to take it out and put it on correctly. The only tricky part is getting it in place around the drum. That takes a bit of care to do it right. Then clamp it down with the skinny clamp that comes with it.
Jun 24, 2009 | Miele Novotronic W1918A Front Load Washer
Miele Novotronic W1918A Front Load Washer Logo
1,452 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
