Question about Samsung 7.3 Cu. Ft. 9-Cycle Super Capacity Gas Dryer - White
The cooling light is on. my clothes aren't dry. how do I get it out of cooling mode
Whirlpool duet gas dryer
The question is are your clothes getting dry? The flame does not stay on constantly, but cycles on and off. Now if the clothes aren't drying properly, then the first thing to check is if you have good air flow coming out of the back of the machine and air flow completely outside where the vent exhaust to. If that is good then most likely your flame sensor has gone bad and needs to be replaced.
Aug 25, 2012 | Whirlpool GEW9250 Electric Dryer
My dryer will run for a couple of minutes then shut off we already replaced the heating element
If your dryer has electronic sensors like this:
They might have a coating builtup on them preventing them from feeling the wet clothes.As the wet clothes tumble in the dryer they rub up against these sensor strips. As long a wetness is there the capacitor is dicharged on the controls upstairs and it continues to dry them wet clothes. If junk gets on them sensors no wetness will e felt by them sensors. It is a simple as that. The dryer thinks the clothes is dry because no dampness is being detected so is shuts down thinking all is propah. Get some windex and scrub them sensors good so dampness can be sensed by the two sensors once more and party on!
Jul 23, 2011 | Dryers
I just got this HE dryer and the cloths aren't dry when the buzzer goes off. And the permanent press clothes are wrinkled... HELP! Plus it took almost 3 hours to dry sheets
It could have a faulty thermostat which shuts down to fast in drying mode, be sure and check that the vent is clear and not obstructed at all, thats the only way moisture has to leave the machine and dry the clothes
Jun 17, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
It seems like the burners are not all lighting. Maytag Epic Z gas
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 11, 2010 | Maytag EPICz 6.7 Cu. Ft. 8-Cycle King-Size...
2004 Audi A6 A/C permanently in econ mode
Sounds like the refrigerant has either become low or run out. May just require a regas if there aren’t any leaks.
Nov 08, 2017 | 2005 Audi A6
"cooling" display won't turn off causing heating problems.
Try cleaning off the two curved metal bars (about 4 inches long) on the inside near the lint filter. They are what senses the moisture on automatic dry. When you use fabric softener sheets, the stuff from the fabric softener sheets can coat the bars, which makes the dryer think the clothes are already dry, and puts the dryer into cool down. (using time dry will also take the moisture sensor out of the cycle, if you'd like) This should be a Fix-Ya for your problem.
Dec 15, 2008 | Dryers
Cooling light on?
The cooling light is always on, it flashes when it is in that part of the cycle, sounds like he put it in to a test mode. Was it a thermistor that he changed?
No heat, sounds to me like a thermostat might be blown. Call the guy back, if you haven't already.
Sgt 48
Apr 05, 2008 | LG DLE5977 Electric Dryer
LG DLG 5988 Gas Dryer Does not heat and does not dry
Same problem after 1 year of use. In the past couple of months, the Sensor and Cooling mode light stay on and unit does not dry.
Oct 08, 2007 | LG DLG5988 Gas Dryer
Samsung 7.3 Cu. Ft. 9-Cycle Super Capacity Gas Dryer - White Logo
407 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
