Question about ASK Proxima ASK M3 projector lamp Projector Lamp
My ask m3 projector powers on but doesnot display anything. No light comes out of the bulb. Is it possible that the projector's bulb hours are finished?
  • 35 Answers
Very possible. Replacement lamp:
http://www.shopvsc.com/Ask-Replacement-Projector-Lamps-s/135549.htm?searching=Y&sort=7&cat=135549&show=50&page=1&f-M2+=135515
Posted on Oct 27, 2010
I've just replaced the lamp on my Panasonic PT-LM2E projector and it will switch on but no light comes out. The previous lamp blew in the projector after around 2000 hrs. The indicators are as...
I'd recommend checking the fans of the projector, and make sure that they're spinning. Since you've mentioned that the lamp blew inside the unit, bits and pieces of the lamp might have lodged itself within the fans. It might also have to do w/ the after-market replacement bulb, which I normally wouldn't recommend.
Aug 08, 2011 | Panasonic PT-AE900U Multimedia Projector
I have two issues with the pb8220 1. How do you reset the bulb hrs when a new bulb is installed? 2. Projects for about 10 seconds then goes black. The red bulb light comes on when the screen goes...
Reset the lamp hours as follows.
Press the Exit button on the projector for 3 seconds to display the total used lamp time. Press the MENU button on the projector during the lamp hour message. An adjustment message will appear. Press left or right arrow to reset lamp hours or press EXIT to leave.
sonsunny
Jul 09, 2011 | BenQ PE5120 Multimedia Projector
I have green light so I know the bulbe is good,
just because the green light is on doesn't mean the bulb is lit. look into the lens from the side--not directly into it to see if it is in fact lit. if it is lit but you have no display, the main board is likely bad, but you can try resetting the lamp hours and reflashing the unit with the most current firmware.
Jun 17, 2010 | InFocus X2 Projector
My Hitachi cp x250 projector powers on and displays and then the bulb turns off after a few minutes, and the lamp light and the power light come on red.
Most likely you have a defective lamp or it is near the end of its life. It's also possible that the high voltage power supply is going out. You might check the lamp hours - you can find this in the advanced menu. Also check the air filter, if you haven't cleaned it, the airflow might be restricted, shutting down the projector.
Sep 18, 2009 | Hitachi CP-X250 Multimedia Projector
Lamp and temp lights come on after power up and stay on. Lamp only has 330 hours on it.
OK, that explains it. The bulb you have installed in the projector might be the original bulb that came with the projecoter when it was new. Just becuase it states 334 hours does not mean it is new. In fact, you could have a original bulb with 3000 hrs and reset the hour timer on the projector, which means your 3000 hour bulb might have 3334 hours on it because the person who owned it before you, reset the hour timer.. Best bet, buy a new bulb and reset the hour meter and see what happens. If you have the same problem, then your ballest might needs to be replace which is rare...
May 30, 2009 | ViewSonic PJ400 Multimedia Projector
Projector keeps turn itself off
I have a Dell MP2300 with a bad power supply. Everything else is in excellent working condition. the bulb is less than a year old and has less than 500 hours on it. My asking prices are:
1. WITHOUT BULB: $50 shipping
2. WITH BULB: $150 plus shipping .
If you are interested, please contact me. I will also consider offers.
JJ
Bethesda MD - 301-588-7222
Jan 09, 2009 | Dell 2300MP Multimedia Projector
Projector keeps turning off
When i turn the projector on it only comes on four about a minute until the temp lights go amber and it turns off, the fan is working but the air coming out is a little warm. what if anything is making my projector overheat, or is it not heating at all?
Aug 07, 2008 | Dell 2300MP Multimedia Projector
PROJECTOR POWERS DOWN
This would appear to be a bulb that has reached end of life -- or the projector thinks that it is because of hours. Usually most bulbs are 1000 or 2000 hours. Depending on your projector there are different ways of checking bulb life hours -- if you Google your projector model number and "bulb life" you will usually get a post on how to check these hours. Also, if it is a new bulb and you haven't reset the hours counter, it may need to be reset (however you also don't want to wait too long before changing a bulb that has reached EOL since they can and do explode sometimes taking out the projector with it).
Jan 18, 2008 | Sanyo PLC XU50 Multimedia Projector
Panasonic PT-L557U Bulb Life
lamp hours can only be displayed by connecting two test points in side the projector. in normal operation, a message will be displayed on the screen when the lamp hours = 1090. when the lamp reaches 1100 hours, the projector will shut itself off. when you do replace the lamp, be sure to reset the lamp time in the setup menu (this is covered in your manual).
Dec 14, 2007 | Panasonic PT L557U Multimedia Projector
Bad Lamp lights even with new bulb.
confirm that it is not made in china-because some chinese lamps is not good in life time.
Dec 02, 2006 | Dell 2300MP Multimedia Projector
166 people viewed this question
Top ASK Proxima Office Equipment & Supplies Experts
jasbo
jasbo
240cpa
Lyle Siemens
Lyle Siemens
Are you an ASK Proxima Office Equipment and Supply Expert? Answer questions, earn points and help others
