Question about HP OfficeJet 7410 All-In-One InkJet Printer
Whizzzzzing sound and will not send fax.
7410 will not send a fax and makes a Wizzzzzing sound half way thru sending.Will get a report of a power failure and screen will advise to to turn off machine and restart.
  • nomore HP May 27, 2008
    Having tried your solution for the fax problem with the H/P 7410 all in one ,it did not work.Its still makes the Wizzzzzing sound when it starts to send a fax and then the screen will read scanner failure with the the icon of a explanation mark blinking.Then it will print out a read out saying, result, power failure.This problem seems to be the same as a few other postings I have read. Thanks for trying!
    nomore H/P
    Genius:
  • 2,035 Answers
The problem is the power supply try to plug to different outlet and then send a fax if it fails then its a power supply fault please change it.............
Posted on May 27, 2008
When Ifax a letter is there a report sheet that tells me it went thru
When you setup the fax machine you might of turn off the feature that prints out the report when you send a fax, but there should be a log report. you Just need to go thru the menu to print it out.
Oct 22, 2014 | Office Equipment & Supplies
How to I turn off the automatic printing of the fax logs.
To change fax confirmation
1. Press Setup.
2. Press Print Report, and then Fax Confirmation.
3. Press the right arrow button to select one of the following, and then press OK.
Off - Does not print a fax confirmation report when you send and receive
faxes successfully. This is the default setting.
On Fax Send - Prints a fax confirmation report for every fax you send.
On Fax Receive - Prints a fax confirmation report for every fax you receive.
Send & Receive - Prints a fax confirmation report for every fax you send and receive.
May 03, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
HP 6310 All-in-One. How do I get a fax confirmation?
If you need printed confirmation that your faxes were successfully sent, follow these instructions to enable fax confirmation before sending any faxes. Select either On Fax Send or Send & Receive.
The default fax confirmation setting is Off. This means that the HP All-in-One will not print a confirmation report for each fax sent or received. A confirmation message indicating whether a fax was successfully sent appears briefly on the display after each transaction.
To enable fax confirmation from the control panel
1. Press Setup.
2. Press 2, and then press 3.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
Fax
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and
receive.
Oct 27, 2010 | HP Officejet 6310 All-In-One InkJet...
Does magicjack allow the hp officjet 7410 to send and recieve faxes
You should be able to send and receive faxes with the majic jack.
Nov 01, 2009 | HP OfficeJet 7410 All-In-One InkJet...
How do I get a fax conformation?
This is an excerpt of the User's Guide for your machine. You can download from here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=1138342&
Print fax confirmation reports
each transaction.
1. Press Setup.
2. Press 2, and then press 1.
Send & Receive Prints a fax confirmation report for every fax you send and receive.
User Guide 65
Fax
Tip
If you choose On Fax Send or Send & Receive, and scan your fax to send from memory, you can include an image of the first page of the fax on the Fax Sent Confirmation report. Press Setup, press 2, and then press 2 again. Select On from the Image on Fax Send Report menu.
Aug 14, 2009 | HP OfficeJet 4315 All-In-One InkJet...
01.12.2008 i fax to one number. now i want aknowledgement of that fax. its gone or not. How i can find on HP Officejet 5610 all in One System?
You can get the manual here if you do not have one - LINK.
Here is an exert form the manual on this:
1. Press Setup.
Send &
Receive
receive.
Dec 10, 2008 | HP Officejet 5610 All-In-One InkJet...
Fax Journal Report
Step through the REPORTS menu and select CONFIRMATION REPORT
Jun 09, 2008 | Brother IntelliFax-2820 Laser Fax
Unable to send a fax
Is your fax correctly plug in the outlet line of the wall and the same in the back of your fax....????
Mar 25, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Fax not answering or receiving
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu02151&lc=en&cc=us&dlc=en&product=391194&rule=44610&lang=en
Visit the HP Support and Drivers Home page .
Jan 24, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Grabs two sheets when sending a fax
Sounds like it just needs to be cleaned. If you can give me the make and model of the fax, I'm sure that I can find the manuals for you.
Mar 26, 2007 | HP OfficeJet 7410 All-In-One InkJet...
HP OfficeJet 7410 All-In-One InkJet Printer Logo
64 people viewed this question
Ben Johnson
