I have plugged in my hard drive, but the computer is not reading my hard drive. It acknowleges that "new hard ware found" but when I search under my computer it is not there. PLEASE HELP!
  • 66 Answers
First install usb driver 2.0 and do it
Posted on Oct 03, 2010
Got wd elements 1.5 tb plug n play hard drive n errh it wont plug n play ??? used on playstation 3 always worked used on my lap top and other peoples neva had any problems lent to a m8 he removed with out...
PlayStation 3 has a Unix like operating system. It is proprietary. http://www.tomshardware.com/forum/279261-32-retrieving-files-stuck-help
The below is how the WD was reformatted to accept P3 content. Even if the PC reads the Fat format, the file types are native to the Unix like system, not Windows. But the above link may be of some help.
http://www.wikihow.com/Add-an-External-Hard-Drive-to-a-PlayStation-3
Jun 14, 2017 | Western Digital MY BOOK HOME 1TB EXT...
I have a NexStar 3 external hard drive that is not being recognized by my computer. It used to work now it gives an unknown device message
remove the hard drive restart your computer the plug the hard drive back into your usb port this should come up with new hard ware found and install the driver If not try a different usb port or your sata drive
Mar 30, 2010 | Vantec NexStar-3 External 3.5inch...
I plug my usb external hard drive into my laptop but it does not read. How can I fix it?
Have you tried changing which USB port it's hooked into. If not is there any cd (Drivers/Software) for your external / that it came with?
If not you might have to search for unrecognized hard ware. This will help with that: http://www.techmantras.com/content/finding-drivers-unrecognized-hardware-windows-system
Dec 23, 2009 | SmartDisk FireLite 40 GB Hard Drive
My new computer has a LG DVD player , but it just stopped reading a disk, i have went to hardware un installed and computer found new hard ware , but want work -has power light is on
Make sure latest drivers are downloaded.
You can also go to my computer, go to dvd drive, right click, properties and make sure device is enabled and working correctly. If need, reinstall dvd software and codecs
Aug 25, 2009 | Televison & Video
It was missed and dropped down.. and it's not being recognised in 'My Computer' but in the task bar it is showing that a new hard ware " A mass storage device is plugged in ' ....
If it shows in Taskbar that it found new hardware then it does detect the PC board of the hard drive but the drive's head mechanics or the actual disk inside have been damaged by the fall and therefore it cannot read off the drive which means your drive has now permanent damage.
Therefore it cannot be detected at bootup...
You may try a DATA RETRIEVAL company to see if they can get your information off the fallen drive.
Jul 03, 2009 | Western Digital (WDXB1200BBRNN) 120 GB...
My WD portable 250 gb hard drive
Had similar issue with my WD passport , it turned out that it didn’t like my USB 2 ext lead, as i am unable to access my PC’S USB socket i was a bit stuck ...... i have now found that a low cost “POWERED” USB hub solved the issue .....good luck
Apr 22, 2009 | Western Digital WD Passport 250GB Portable...
Western Digital 250GB External Hard Drive not working
there are a couple of reasons for this. Likely the drive has not been setup in Windows. Hard drives need to setup in Disk Management. Disk Management can be found under Computer Management in the Control Panel. After you run Computer Management, expand the Storage tab and Disk Management is located there. At the bottom of the screen threre is a listing of all drives (hard and CD) located in or attached to system... You will see your new drive listed, but not active. Right click on the new drive in the bottom window and Windows will prompt you on how to configure the drive. You'll need to activate so Windows can assign a drive letter to the drive, partition and format. Once this is done, you will be able to see and use the drive under windows.
I've attached a link from Western Digital that provides their FAQ response to your issue.....
http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=1017&p_created=1055796499&p_sid=7R8631pj&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTQsMTQmcF9wcm9kcz0yMjgsMTAxLDIxOSZwX2NhdHM9JnBfcHY9My4yMTkmcF9jdj0mcF9zZWFyY2hfdHlwZT1hbnN3ZXJzLnNlYXJjaF9ubCZwX3BhZ2U9MSZwX3NlYXJjaF90ZXh0PXJlY29nbml6ZWQ*&p_li=&p_topview=1
You didn't mention what type of connection it uses (USB, etc). According to Western Digital, if you have a USB External Drive, you should get a prompt to install drivers by Windows when a new device is installed. Similar for Firewire device.... Did Windows "recognise" the new device by opening a New Device Found window? If not, try using a different USB port and/or ensure the USB port is enabled in WIndows.... The Quick Start guides for all models can also be found from the link provided above.
Jan 24, 2009 | Western Digital 250GB MyBook External USB...
Lost hard disk identification and data systems
Use Recuva and a deep search to see if the files are still on the drive. If so save them to a new location.
Jun 13, 2017 | Seagate 60GB 5400RPM SATA 100 – ST96812AS...
FULL fantom external usb harddrive is not acknowleged after power outage running check disk.
ACS Data Recovery specializes in Fantom hard drives, and can perform successful recoveries on any model Fantom hard drive. If you have a crashed Fantom hard drive, please call us today to get a quote: 1-800-717-8974
unless you fancy trying to connect the drive inside the unit directly to a pc by taking the box a part.
Jul 18, 2008 | Fantom Titanium Hard Drive
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
