Question about Smeg 18 in. STX45-1 Stainless Steel Built-in Dishwasher
Hi, it seems my dishwasher is getting stuck mid cycle.... I have a smeg SA945X... Have cleaned the filters etc... not making much of a differene though. Can you give me any suggestions please?
  • 641 Answers
SOURCE: smeg dishwasher wash cycle freezes ,
Thanks for the information.
Posted on Jul 24, 2007
wheelshot
  • 102 Answers
SOURCE: missing Instruction manual smeg dishwasher SA945X
try going to servicematters.com. You can download owners manuals there.
Posted on Apr 04, 2009
  • 109 Answers
SOURCE: SMEG dishwasher - cycle buttons
What is the model of the dishwasher? Open the door and look down the right hand side for a sticker and repost please. As a rule number 3 is a normal wash :D
Posted on Jun 16, 2009
caroldon
  • 17130 Answers
SOURCE: I have a smeg dishwasher
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect.
So I think you will need a new program timer unit to be fitted to get the machine working. Please take estimate and decide.
Check how to remove the control panel: http://www.espares.co.uk/advice/dishwashers/a/3/1287/how-to-replace-a-hotpoint-dishwasher-fascia-p.html
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor. The water pressure must be good and the spraying must be seen to be good. If there is low pumping or pressure then the spray arms will not turn around to inject with pressure. If so the pump must be checked for clogging.
To replace check this link:
http://www.espares.co.uk/advice/dishwashers/a/3/1293/how-to-replace-the-spraying-system-on-a-dishw.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the drain valve/pump activated so as to drain off all the water.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
Thank You for using Fixya
Posted on Sep 01, 2011
caroldon
  • 17130 Answers
SOURCE: smeg dishwasher getting stuck mid
I cleaned out the filter on my Smeg integrated dishwasher, model D16012, yesterday then started a fully loaded cycle. The items were all clean when I unloaded but some water remained in the bottom of the...
It may be possible that something fell out of the filter and into the drain pump. The machine will do a short drain cycle at the start of a program and if it is jammed or blocked, this will cause this problem.
Jul 02, 2014 | Smeg Dishwashers
Re: SMEG Integrated Dishwasher ST663. I'm having
usually a screw on the striker (the bit sticking out that goes into the door) it will be a slotted adjustment so just loosen (not remove) the screw and pull it out a mm or 2.
retighten and test.
Also, clean the seal. While your at it, the sump filters and spray arms.
Oct 18, 2013 | Dishwashers
The dishwasher is not completing it's cycle and doesn't seem to drain at the end.
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 15, 2011 | Smeg 18 in. DWD409SS Built-in Dishwasher
Kenmore Dishwasher 587.15163401 knob stuck mid-cycle
See if it is stuck on a water heat cycle. if the heater circuit or the thermostat is not working properly it will continue to run looking for a rise in temperature. If these are in working order the timer it self could be sticking and not advancing.
Eric
Oct 23, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Missing Instruction manual smeg dishwasher SA945X
Apr 03, 2009 | Smeg 18 in. STX45-1 Stainless Steel...
Mar 23, 2009 | Smeg 18 in. DWI410 Built-in Dishwasher
Smeg Intergrated Dishwasher
Do any objects hang down (or stick up from below) and block it? Is the shelf pushed all the way in so it gets water through it? Does it seem to be spraying water, but not spinning?
Try spinning it by hand to see if it moves freely. It may just be blockede by a small object in the water.
Oct 08, 2007 | Smeg DWI614 Built-in Dishwasher
It's stuck on Bio...
Here is the link to the user manual, hopefully this solves your problem else please ask again; http://www.smegtech.com/site/smeg/pdf_libretti/19590097802-GB.pdf Hope this helps :)
Jun 25, 2007 | Smeg 18 in. DWF410SS Slim-Line...
Help
We have a Smeg SA8605W which has had a similar problem 3 times in its short 3 month life. The problem with ours is that the control panel on the front pushes against a very brittle plastic frame to activate the micro switches. Because of the brittle nature the 'fingers' of plastic break off and either get stuck holding the machine in a set cycle or break off fully so nothing functions. Gaffa tape or Elastoplast is a simple solution.
Nov 08, 2006 | Smeg CSU2001 Built-in Dishwasher
Smeg 18 in. STX45-1 Stainless Steel Built-in Dishwasher Logo
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
