I have changed the batteries in the keyboard (yes, correct + & -) pressed the button on the transmitter but get no response. The keyboard has worked fine for four years and this is my first change of batteries. Why no response??!! Any ideas? Jamie Heron
  • 66 Answers
Do it once more
Posted on Oct 03, 2010
My Ford Focus car doesn't centrally lock anymore, I have to use the key. It's not the fob battery because I changed it.
Sure you did put in a new battery? sure you did insert it correct? not the other way around? sure you did use the correct battery? like CR23 or AAA?
Sure all contacts in the battery compartment and on the battery are clean and shiny?
just a few things you could check.
Feb 09, 2015 | Ford Focus Cars & Trucks
How do i ? ive a 2012 chery j11 and iam unable to find any info on how to program the keyless remote for it please help regards Dan
The Service Manual says this...
Remote Keyless Entry (RKE) Inoperative
No Response From Remote Keyless Entry (RKE) Transmitter
1. CHECK BATTERY
• Check battery of the RKE transmitter.
Is the battery voltage of the RKE transmitter normal?
Yes >> Go to the next step.
No >> This concern has been caused by the transmitter battery.
Go to step 4.
2. CHECK THE IGNITION LOCK CYLINDER CONDITION
• Check the ignition lock cylinder for proper operation.
Is the check result normal?
No >> Repair or replace the ignition lock cylinder key switch.
3. PERFORM THE RKE TRANSMITTER MATCH PROCEDURE
• Close all the doors.
• Insert the ignition key into the ignition switch which has lost synchronization in LOCK position.
• Press any button on the RKE transmitter within 5 seconds.
• Pull the ignition key out of the ignition switch.
• Try to operate the RKE transmitter.
Does the RKE transmitter operate properly?
Yes >> Erase all codes before returning the vehicle to the customer.
No >> Go to the next step.
4. PERFORM THE RKE TRANSMITTER MATCH WITH THE X-431
• Replace the RKE transmitter.
• Connect the X-431 scan tool to the Data Link Connector (DLC), press the POWER key to start the X-431 (use the most current software available).
• Turn ignition switch on.
? Enter the Diagnostic Program.
? Select Chery main program.
? Select diagnostic version.
? Enter download program.
? Select T11 series, and then select ISU.
? Select Remoter Match.
• Press the lock button on the RKE transmitter for less than 2 seconds.
• Pull out the ignition switch.
The concern was caused by the RKE transmitter.
No >> Replace the FBCM (See FBCM Removal & Installation in Section 15 Body & Accessories).
Refer to the RKE transmitter match procedure with X-431 as the description.
Perform match between the RKE transmitter and FBCM with X-431.
Best wishes from another Chery J11 owner.
You can download the entire service manual from the link below.
Kevin Mullen
Perth WA
Chery Tiggo 2009 Service Manual Page 1699
Nov 18, 2014 | Refrigerators
Hello, I have a Logitech wireless mouse and keyboard. I changed the battery for the keyboard and now both are not working. I should install the driver again?
I just had the same problem. First of all, make sure the transmitter to the wireless keyboard and mouse is plugged in tightly to the computer. It's possible that you could have pulled on the wire without realizing it, and it's not plugged in tightly! Unplug and replug the transmitter anyway after you change the batteries for the wireless keyboard. Then, there's a button on the transmitter, press it for 3 seconds, then quickly press the small button on the keyboard for 3 seconds, (my small buttons are underneath my wireless keyboard and mouse, and I use the tip of a ball point pen to press them). Then do the same for the wireless mouse. This syncronizes and boots them to start.
I'm not sure about the driver, but try the above first, it worked for me after I changed the batteries on my wireless keyboard and mouse.
Nov 03, 2010 | Logitech Wireless Access Duo Optical...
My key board just quit responding, on turn on it would not type,I put in new batteries,pressed connect several times---no response
you need to press the connect button on your transmitter, then the connect button on the keyboard.
if that does not work, verify the transmitter is connected to the PC.
Mar 05, 2010 | Office Equipment & Supplies
Problem with LOGITECH S 510 cordless keyboard and mouse..
I have this same keyboard/mouse set and love/hate it when the batteries die. After you change the batteies, power on your pc, press & hold the connect button on the bottem of the keyboard first and then the connect button on the transmitter. Release them and wait for a few seconds. Repeat the same steps for the mouse.
When I have connection issue with this keyboard after new batteries, I have found most of the time the problem is the connection to the pc and/or batteries in wrong. Good Luck
C2Solutions
Aug 21, 2009 | Logitech S 510 (967555) (DH967555)...
Microsoft Curve 3000 Keyboard battery Low with new batteries
Your response to the clarification request was placed correctly.
Your keyboard must have a button on the bottom to sync with the USB transmitter. Press the button on the transmitter first and then the button on the keyboard. This will re-sync the devices in a new radio channel. Give it a try, it might just be a communincatin problem between the two.
The intellipoint software and drivers are not really needed for the the keyboard to work, even if it has special keys for functions like volume and such. As soon as your batteries start to run out you will be able to tell by the keyboard not responding properly to key-presses.
Jun 23, 2009 | Logitech Cordless Desktop MX 3000...
Computer doesn't recognize keyboard
This is sort of general but it just may help.
Make sure your batteries are in correctly.
Make sure the transmitter dongle is in the USB.
Look on the transmitter and the mouse and keyboard
itself (bottom) for a little tiny button that says connect
or reconnect. Move the mouse about six inches away from
the transmitter and press both the transmitter and the mouse.
That should reestablish the signal twixt the two.(or three KB)
May 14, 2009 | Dell Bluetooth Wireless Keyboard/Mouse for...
Keyboard not working
May 10, 2009 | Logitech Inc Cordless Desktop Express...
Amptron wireless keyboard/mouse needs to be reset, do not know how.
May 06, 2009 | Computers & Internet
Need battery size and how to open it up without breaking it. I have no manual.
AAs and the end (top where you normally hold it ) just slides back towards the rear. and do the following to reconnect ...(you might as well change the batteries a this time as well)
Look on the transmitter, the mouse and keyboard itself (bottom) for a little tiny button that says connect or reconnect. Move the mouse about six inches away from the transmitter and press both the transmitter and the mouse.
May 06, 2009 | Micro Innovations PD7250LSR Wireless RF...
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
