Question about Hotpoint Ovens
My hotpoint ew82 tripped my switch whilst using the oven. When I put it back on again neither oven will work. My hob and grill however are still working. Any idea what might be wrong?
barkencoa
  • 3463 Answers
SOURCE: hotpoint ew83p oven has no heat
The oven fan element has failed, you need to fit a new one.
Remove inner rear panel of oven and you will see the round element at rear.Unscew screw(s) that secure element, disconnect leads, and fit new element.
Refit element cover.
Job done..
Make sure you have power off to oven before you start.
Plz rate my solution.
Thanks.
Posted on Jan 12, 2009
barkencoa
  • 3463 Answers
SOURCE: AEG Competence Double Fan Oven Fault
Sounds like oven element is faulty, disconnect it and try again, if it does not trip, then it is definately the element..
It is easy to replace.
Plz leave feedback.
Posted on Dec 09, 2008
  • 1214 Answers
SOURCE: bottom oven not working
A tripped breaker or blown fuse on an electric oven or cook-top, combined with an element that has stopped working, is usually a sign of a shorted, then blown (if the fuse or breaker no longer fail) element.
If you know how to use an ohmeter, you can pull the element, disconnect the wires from each end, then measure the resistance between each end of the element, and each element to the outer sheath.
A good element has just a few ohms of resistance between the wire connection points, and infinite resistance from the wire connection points to the outer sheath. Any readings other than that means the element is bad and need's to be replaced.
Posted on Jan 14, 2009
barkencoa
  • 3463 Answers
SOURCE: PRIMA FAN ASSISTED COOKER - FAN WORKING BUT NO HEAT?
Hi.
You will need to check the oven element, it probably needs replacing.
Please rate my solution.
Thanks.
Posted on Jul 14, 2009
hattonhall
  • 349 Answers
SOURCE: hotpoint oven bu72 gave out loud bang when cooking
Sounds like the element has internally shorted to earth and will have to be replaced by a qualified Techo.
While this may have caused a fright...think how lucky you are that the Safety Switch was invented as a fail safe lifesaver!
Posted on Oct 25, 2009
Testimonial: "Thanks for prompt response - will contact Hotpoint Service Centre tomorrow a.m."
Knobs on hob above the oven getting very hot. Guess heat must be escaping from the oven. Any suggestions?
Try putting a layer of insulating materials between the Knob and the oven. That should help.
Aug 10, 2015 | Ovens
The grill on my Hotpoint EW 41 Electric freestanding cooker has stopped working after my wife put aluminum foil into the grill pan which then touched the grill element causing it to 'blow' and so...
The grill element should not 'blow' by just touching it - it should be earthed. The elements do gradually disintegrate over time & the inside wire element either fractures or touches the element casing causing the mains to trip. Sometimes this makes it trip just once & then stops working. Replace the element - not usually any fuse in circuit with this. Often held in by 2 screws adjacent to the element at back of oven and conections via Fast-ons- Rick
Jun 12, 2011 | Hotpoint Ovens
Hob on my hotpoint oven trips my RCD
It is either a faulty ring, or the regulator that controls it is faulty.
You really need a meter to test the ring with to be certain which part is faulty.
Hope this helps.
Feb 21, 2010 | Ovens
Complete power loss to Hotpoint electric oven
You need to ascertain that the oven is actually getting power.To do this, you are going to have to remove it from the housing and remove the terminal cover where the the cable comes in, and check for power there.
You may find that the terminal block has charred due to a bad connection and the wire has burnt away
If this o/k, and you are getting voltage there, then the problem is obviously within the oven itself, could be a timer fault.
If you have no voltage at terminal block, then the problem is between the terminal block and the main switch.
Hope this helps with your problem.
Dec 03, 2009 | Hotpoint Ovens
Hotpoint oven bu72 gave out loud bang when cooking dinner and blew trip, reset trip and whilst top oven and grill work we cannot get any heat from main bottom oven
Oct 25, 2009 | Ovens
Hi.
Thanks.
Apr 27, 2009 | Bosch HBL 5032 Electric Single Oven
Lights grill and fan work but oven isnt heating up
On our oven, we have to reset the clock before the oven will work. I think it's because of the automatic timer features.
Yours is a slightly different model, but on ours we have to press the two buttons with arrows on, at the same time as turning the clock dial. Once this is done, the oven should work again.
Good luck.
Jan 04, 2009 | Neff U1721 Double circotherm Electric Oven
Grill not working fully Oven model 660W
That is due to expansion of the element making the terminal touch the chassis, taking the earth leakage trip out.
Get your oven repaired by a competent electrician.
Sep 16, 2017 | Zanussi ZBF660 Electric Single Oven
Hotpoint Double Oven ceramic hob
suspect more than one problem. half grill not working may be due to half the element gone open circuit. the other problems could be due to an installation fault. many ovens have links in the connection box which have to be tightened down. this is often overlooked. look at the connection box or terminal strip to check. there is often a diagram of hoiw it should be done adjacent.
Jun 02, 2007 | Hotpoint UY46 Style Line Stainless Steel...
Ovens Logo
76 people viewed this question
Top Hotpoint Ovens Experts
Jason Harris
Jason Harris
ashburton
Colin Stickland
Colin Stickland
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
