Question about Dell Inspiron 1501 Notebook
How to save Adobe Flash files - Dell Inspiron 1501 Notebook
Flash player not installing
1) Check the settings of your anti-virus program. A lot of times an anti-virus program will not let a program download.
2) The main thing with Adobe Flash Player, is that it will NOT install a new version of Flash Player; with an old version present.
And it will NOT automatically delete the old version.
Use the Adobe Flash Player Uninstaller tool.
Then go back to Adobe Flash Player Support, and download AND install the newest version of Adobe Flash Player.
Adobe Flash Player Uninstaller tool,
http://www.adobe.com/support/flashplayer/downloads.html
Go down to the bottom of the page, where it states in bold print -
Click on the blue - Tech note - in the paragraph.
Takes you to here,
http://helpx.adobe.com/flash-player/kb/uninstall-flash-player-windows.html
Scroll down to -
1. Download the uninstaller for Flash Player
Click on the blue - uninstaller - underneath the above heading. [Uninstaller (674KB) ]
A small window will come up. Click on Save File.
A small download window will come up.
Allow the file to fully download, then DOUBLE-click right on the file name.
At the bottom of the next 3 small windows, click on Next, Next, and Finish.
If you are not asked to restart your computer, do so.
When Windows loads back up again, go back to Adobe Flash Player Support, download and install the newest version of Adobe Flash Player.
Regards,
joecoolvette
Jan 15, 2013 | Acer TravelMate 529ATX Notebook
You tube vidoes wont load
1) Make sure your Adobe Flash Player is up to date,
http://get.adobe.com/flashplayer/
[ Advise click on the small square to the left of -
Yes, install McAfee Security Scan Plus - optional
,and remove the green checkmark. THEN click on Download now ]
Be advised though, sometimes the new Adobe Flash Player download, will not automatically remove the old Adobe Flash Player version that is installed; and the Adobe Flash Player Uninstaller Tool is needed.
Go to the bottom of this page. Under the bold subheading -
Adobe Flash Player Uninstaller - click on the blue - Tech Note.
On the following page go down to the subheading -
1. Download the uninstaller for Flash Player -
,and click on - uninstaller - in blue. (674 KB)
In the small window that comes up click on Save File.
Close all internet windows.
In the small download window that comes up next, allow the file to fully download, then DOUBLE-click right on the file name.
When you are finished with the Adobe Flash Player uninstaller, close all windows, restart the computer.
Now go back to Adobe Flash Player Support, and download the new Adobe Flash Player.
2) Make sure your Java is up to date,
http://www.java.com/en/
3) Sometimes I have found, that you have to click on Pause for the video, and allow it to download for a bit, then click on Play.
Regards,
joecoolvette
Oct 22, 2012 | Dell Computers & Internet
I want to download Adobe Flash player in Dell Vostro 1015 intel core due n series which is the best one
Hello, there are usually two versions of adobe flash player: one for internet explorer browser and the other for all other browsers. You just have to download the version for the browser you use. You can use this link to download from the adobe website:
It will automatically detect your browser and choose the correct version for you.
Thanks for using FixYa
Aug 21, 2011 | Dell Vostro 1510 Laptop
How to get my flat bed scanner to save in pdf format? For years I have been able to scan documents and save as pdf or choose another format such as bmp or jpeg. I have of remove the software and reload...
There are 2 steps you can do to get this option back.
First, You need to update Adobe Flash player Or you need to uninstall and Reinstall the Adobe Flash player.
Since you uninstalled the Software and and reinstalled, the Software is not able to detect the latest Adobe software in your PC.
May i know what is the operating system ?
Try this step below to update to adobe flash player if you are using Windows XP or Windows Vista
Click on START button
Click on MY Computer or Computer
Open C:/ local Disk
Open Windows Folder
Open System32 Folder
Open Macromed Folder
Open Flash Folder
You will find few flash files
Double click on file Flashutil10 and it should give you update screen. Continue and complete the process.
Restart your PC and try to Scan
If this does not work, you need to uninstall adobe flash player and reinstall it and it will work.
Regards,
Ron
Mar 09, 2011 | Microtek ScanMaker V6USL Flatbed Scanner
Downloading adobe flash player be come a problem on my computer
When you download and install Flash Player from the Adobe Flash Player Download Center, the download uses the Adobe Download Manager. Instead of using the Adobe Download Manager, you can download and run the Flash Player installer manually.
  1. If you haven't already done so, Uninstall previous versions of Flash Player.
  2. Select the manual installer depending on the browser you use. Select one of the following:
  1. A File Download dialog box appears. Select Save. (If you are using Firefox, select Save File).
  2. Print these instructions and then close all applications.
  3. Open the folder in which you saved the file.
  4. Double-click the file name to run the manual installer.
  5. Select the license agreement and then select Install.
  6. When the installation completes, select Done.
  7. Go to http://www.adobe.com/software/flash/about. If the installation was successful, the page displays the Adobe Flash Player version. For more information, see Determine the Flash Player version you installed, if any.
For more help, please check out: http://kb2.adobe.com/cps/191/tn_19166.html
Jan 23, 2011 | Computers & Internet
Why my adobe flash player 10 crash all the time
Try a fresh install of the program after you uninstall the old one. Download a fresh file and save it somewhere on your computer. Go to Start, Control Panel and Add/Remove programs. Find the Adobe Flash Player and uninstall it. I would reboot computer and then install fresh file.
Sep 05, 2010 | Adobe Systems Adobe Flash Player
Firefox: it says i always need adobe flash something needs ...
Install the adobe flash player..
Here's the link: http://fpdownload.adobe.com/get/flashplayer/current/install_flash_player_ax.exe
Just click the link and save the file. Once finished downloading.. install i to your pc..
Much appreciated if you rate this help. thanks
May 18, 2010 | Mozilla Firefox
In need a way around a block to get in youtube
Youtube needs additional plug-ins software in order to play flash videos.
Download and install Adobe Flash Player to play videos in Youtube.
Instruction:
1. From your browser (Internet Explorer/Mozilla Firefox) address bar type: www.adobe.com
2. On the right part of the page click on Get Adobe Flash Player
3. In "Install Adobe Flash Player" page, it is recommended to unchecked the free Mcafee Security Scan if your computer already has a anti-virus software.
4. Click on Agree and Install now.
5. You'll see this message, click the link to download the flash player.
Thank You! Your download will start automatically.
If it does not start, click here to download
6. Choose the location to save the flash player file.
Saved files from Mozilla Firefox is located under Downloads folder under My Documents while Desktop is the default location of files downloaded from Internet Explorer.
7. After downloading the flash player, close all browser to begin with the Adobe Flash Player Installation.
8 Double Click the Adobe Flash Player file from your computer, to install ( It only runs in a matter of second to finish )
Feb 23, 2010 | Joy IBM Netvista Intel Desktop Computer -...
Unable to download adobe flash player 9
Download Adobe from this link....
http://www.softpedia.com/get/Internet/WEB-Design/Flash/Macromedia-Flash-Player.shtml
http://www.filehippo.com/download_flashplayer_ie/
Save the file to the desktop location when prompted, then run the adobe program. file
Goodlucl :-)
Jun 05, 2008 | Microsoft Windows XP Home Edition
Dell Inspiron 1501 Notebook Logo
14 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
