Question about Mitsubishi WD-52725 52". Rear Projection HDTV
Lamp light comes on and tv wont power up . if you cut the tv off and unplug it for a few hrs . it will come back on for a few hrs
  • Mitsubishi Master
  • 19,396 Answers
Hi.
That means that the lamp must be replaced. The lamp indicator comes on when the lamp is over the max life hours. If you cut off the the power you reset the TV and the lamp is allowed working for some hour before turning off. This is not a good practice, as a drained lamp has a different power draw and may damage the ballast board.
Lamp part is PHI915P020010
Here lamp: http://salestores.com/philipsphi91.html
Here cheapest offer: WD52725 Lamp with Housing 915P020010
The lamp is replaced accessing the service panel located at the back of the TV. Detailed instructions with pictures will be included with the lamp replacement part.
Regards.
Ginko.
Posted on Oct 03, 2010
Replaced projection lamp in panasonic multi media projection television and reset timer t_v played for a day or so then cut it off now power will not come back on green light is blinking on power
Make sure the Lamp door is tight. Unplug the TV, and remove the lamp and then reinstall the lamp making sure the door is tight. Then plug the TV in and try again. If it does not work, please post the model # of the TV.
Jun 03, 2015 | Panasonic Televison & Video
Sharp lc-32sb220u lcd tv. Green Power LED flashes steady
Okay, I found the problem. There is a problem with the
ccfl (lamp) groung PCB. Mine is completely burnt through. I am going to attempt to repair it, but will likely need to extract it from a different unit. This board is on the front right of the lx in the lamp housing behind the
lcd panel. What is happening: The inverter circuit on the power supply is detecting that one of the lamps is not lighting and it goes into shut down.
Hope this helps!
~Seth
Feb 07, 2012 | Sharp LC Televison & Video
I have a Samsung 50" HDTV DLP TV that I purchased 10/12/2008. I turned the set on the other day and it would come on generate a normal picture then power itself off. I unplugged the set for a few hours...
Lamp could still be going out they only last for 5,000 hrs some 8,000 playing hours.
Check the Lamp Fan if it stops running when Lamp turns on set will turn OFF.
But if you have never replaced Lamp Problem will be the Lamp Mats Has them for $99.00
1-800-628-1118
Oct 23, 2010 | Samsung SP50L3HX 50" DLP TV
Lamp replaced 1.5 years ago, now the picture goes out but comes back on every few minutes, as if it gets to hot and needs to cool down. Fan comes on.
Lamps only last for 5,000 hrs -8,000 Playing hrs
It means every hour you Play TV Lamp burns up the hours, so after 5,000hrs on most Lamp needs replacing, some Lamps dont even last this long DLPs are not like Projection you can play them 24-7 and Tubes will remain good, But Lamps are like a light bulb they all burn out after so many hours.
Best thing is to turn TV off if you are not watching it, in order to Save Hours burt on Lamp.
Mats has Lamps for $99.00 1-800-628-1118
Replace the Lamp.
Mar 05, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Samsung HL-S5086W Television. 3 yr old. Never serviced. Last evening the TV started turning off by itself. It would turn back on easily and run for a few minutes. I unplugged a new Wii game that was...
Dont worry, the problem is coincidental to you installing the Wii. You need a new lamp.
What you are seeing is the lamp ballast/power supply attempting to start and restart your lamp. The resistance of your lamp to it's power source has increased to the point that it is shutting down, but has not blown out yet. You can find these at justlamps.com
Good luck
Jan 04, 2010 | Samsung HL-S5086W 50" HDTV
50VS69A will not trun on, Lights just flash
its really hard to tell without being there to see what its actrually doing, Im asumed is out of warranty and few things you can do yourself. go ahead since its projection tv is to open the back up and check the fuses and the lamp, make sure is unplug and use a good lighting so you can truly see clear of the circuits board. some boad will have its own fuses and check them all make sure they are good. pull the lamp out and check it. projector tv are not hard to work on since is big and easy access behind the TV. to test the lamp you can take it to the local tv shop and have it tested for nothing. If all the lamp and fuses check out fine to fix your problems I would not think it will cost more than 150-200 to fix it. hope that help some ..Good luck
Jul 16, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Lamp modules on tv wont last
Richard,
Could be a bad spark gap on the ballast board. Should have a tech come in a do some Hv testing to see whether the ballast should be replaced, could make the difference on getting the lamp to last 1000 hrs or 3000 hrs...
Bill
Jan 04, 2009 | Televison & Video
Panasonic pt ae900 wont fire up
First , start over and unplug it. Wait a few minutes. Turn on AV system that is connected to it but not video or dvd player. With remote, point at is corectly and push power 1 sec or as soon as you see green light come on. Be quick.
If this fails you can wait 4 hours and repeat. OR try only projector with out any feed.
Let me know if this worked.
Dec 14, 2008 | Panasonic PT-AE900U Multimedia Projector
Tv cuts off and green light flashes
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
56 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
