Question about Belling XOU252 Electric Single Oven
Oven is making a dreadfull knocking, banging, whizzing sound from Fan.. Cannot use to due noise. Ok to use with grill etc Approx 6 yrs old...
  • 4,924 Answers
If the fan is making noise it means that the blades from the fan are damaged or bent and this cause the banging ..Take a look and see if you can straight it back ...or maybe the cover protection is bent or deformed by the heat ..anyway if the fan is spinning it means that the basic function is ok ..and all you have to work is for to avoid the blades touching the side or the cover ..(if it has...)
or ...you can get a new fan and change it ..and will be like new..
Another suggestion is to disconnect the fan ..but this will cause difference in the reading of the temperature ..and if you are used to cook by the temperature...this will kinda mess things until you get used with the new temps..
Posted on Oct 03, 2010
I need to replace my 1987 approx. Chef wall oven Balmain fan forced and grill. Does anyone know the cut out dimensions. I want to buy anew oven that will fit the existing opening. Thanks
when you buy the ovens replacement
instructions are given in the paper work how to adjust the cavity to suit
there will have to be an air gap on back and sides of the new oven
you should call an electrician to wire in the new oven
to check , even replace the 1987 wiring and connections
if needed to meet the 2016 house wiring standards
you will need
tape measure
pencils
a square
straight edge
reversible hand drill and bits
two levels .... for inside the cavity to level oven
approx a 15 inch .one 6 inch
a hand saw or circular saw
, i found a jigsaw helpful
self tapping screws different lengths
as per the oven fitting requirements
you can use any paint to finish the job
white board or MDF board is ok
some extras strips of timber to level the new oven
maybe required
if imperial was used for the cavity of the old oven
metric might be for the new oven
some DIY about wall oven installs are found on youtube
Oct 14, 2016 | Ovens
My new world double oven fan makes a loud noise and now the large oven does not heat up
Newworld model 444447289 made a loud bang and doesn't come on. The top oven oven is ok. What could the problem be
Oct 11, 2013 | Ovens
My oven keeps tripping the electric
It will be the ring element, short circuit. This is the element that runs around the fan behind the backplate in the oven. It can be replaced by isolating from the mains, remove the 4-6 screws hold the backplate on. remove the two screws on the element brabket and one screw holding the element in position at approx 4 o' clock. Be very careful removing the element at the bracket, ease it out very slolwly so as not to detach the spade connector and wiring. A replacement can be obtained from ebay, espares etc or neff direct via there website (link to spares shop). Make sure the wiring goes back on the new element as it came off the old one. Replace screws and backplate and it should be sorted.
Hope this helps
Apr 03, 2013 | Neff B1421 Electric Single Oven
Smeg cucina SE375 single electric oven not heating-grill and lights etc working ok and fan making noise-oven approx 18 months old
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Jan 14, 2011 | Smeg Ovens
Oven fan not working so oven not heating up
have the motor checked and replaced if no runnig the oven will not heat as it is a safty measure
on moter the fan blade could have been loose, the motor bearings could be worn out or the fan motor gone kaput
Jun 15, 2010 | Zanussi ZBQ665 Electric Single Oven
Leisure levc66x - bang from fan oven blew tripswitch - fan operating but no heat - top oven ok - 18 month old unit
It appears that the ring element for the oven has burnt out and will need replacing.
Hope this helped.
May 13, 2010 | Ovens
Oven is AEG Competence, single oven, fan assisted, 4 yrs old. Oven doesn't heat. Light ok, automatic cooking settings not switched on, grill working
If the fan is working o/k, then you need to replace the oven element.
This is located at the rear of the oven compartment, behind a removeable cover.
This should solve the prob.
Please leave feed back.
Thankyou.
Jan 06, 2010 | AEG Ovens
Grill fan sounds like an old morris minor
Replace the fan motor.
Apparently it is going bad.
You should be able to find a replacement for less than 60 bucks at your local appliance parts warehouse.
You may try cleaning it if it is coated with stickiness or grease.
But chances are, if its already slowing down and making noise, its beyond saving.
Jan 14, 2009 | New World G90m Gas Double Oven
Neff single oven
fan heating heating element gone replace it ;Ire close bye
Sep 04, 2007 | Neff U1721 Double circotherm Electric Oven
Fan oven not heating, bosch hbn 202t
the fan oven element is separate from the grill element. the problem is that the circular element round the fan is blown. remove the back panel of the oven and you will see the element. replacement is easy. on most bosch, the element is removable from inside the oven but for some you have to remove the oven and take off the back casing
May 04, 2007 | Bosch HBL 5032 Electric Single Oven
Belling XOU252 Electric Single Oven Logo
157 people viewed this question
Top Belling Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you a Belling Oven Expert? Answer questions, earn points and help others
