Question about Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor
My computer won't boot but power supply is okay
My computer has intel pentium 4 processor, the optical mouse has light and the hard disk led is on but it won't start up
  • Anonymous May 28, 2008
    i already check the hard disk to another computer and it is working well i suspected that somewhere in the motherboard is the culprit by i want to be sure.
    Problem Solver:
  • 23 Answers
Checked the hard disk if it is detected, if it wont start up, try to reinstall the operating system..
Posted on May 27, 2008
Intel D945GCNL has no display though ram, hard disk,power supply, processor is fine
Okay.
Provided you have checked out the simple stuff; monitor, AND monitor cable, suggestion would be to install a graphics card, and connect the monitor to it.
You won't have THE drivers for the graphics card installed yet, as you have no display, but you should get a display you can see well enough, to install the drivers.
I do need to ask a few questions before this is done, however.
1) Do you know the Power Supply is good?
Your LED lights may light, fans may spin, and it may sound like the harddrive is spinning, but the Processor may not be on.
Why?
A) IF, all of the LED lights were on at once, they would use less than 1 Watt of power.
B) EACH fan uses 2 to 3 Watts of power.
C) A typical Processor can use 51 to 125 Watts of power. Just depends on what Processor it is.
{ The Intel D945GCNL mobo has an LGA 775 processor socket.
Front Side Bus support is 800MegaHertz.
The motherboard chipset is an Intel 945GC (Part number 82945GC)
Can use up to an Intel Core2 Duo processor, with a 800MHz FSB.
These processors can use up to 65 Watts.
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Core_2_chipsets
I'll go with the chipset info, and not the stated 1066MHz support,
http://www.overstock.com/Electronics/Intel-Essential-D945GCNL-Desktop-Motherboard-Intel-945GC-Express-Ch-Refurbished/6113423/product.html
Stated facts from Intel,
http://www.intel.com/support/motherboards/desktop/d945gcnl/sb/CS-026727.htm }
2) How do you know the;
A) Processor
B) Harddrive
C) Ram Memory
D) Power Supply
,is fine?
Connected them/it to another working motherboard? Won't work with the harddrive, unless Windows Activation screen comes up, and then the harddrive will be for THAT motherboard, and not the original one.
Post back in a Comment.
Regards,
joecoolvette
May 21, 2012 | Intel D945GCNL Motherboard
1 out 50 times I turn on my Dell Dimension E520 there is no signal to the monitor. I have tried to install a new PCI express card instead of using the integrated graphics but the result was the same e.i no...
The problem is the Power Supply. Weak voltage power rail.
You've taken the right steps with your diagnosis.
1) Start with the monitor cable. If removable use a known to be good monitor cable.
Checks okay, go onto the graphics 'engine' of the computer.
If the monitor cable is not removable, use another monitor, and cable for a test.
2) If you are presently using Integrated Graphics the next step in diagnosing is to install a graphics card.
See if the problem is the Integrated Graphics 'engine'.
[ Just to add:
Intel GM X3100 is the graphics 'engine'. It is integrated into the Northbridge chip of the motherboard chipset.
Intel G965 chipset is the motherboard chipset. The Intel ID number on the Northbridge chip is 82G965.
The Southbridge chip is an Intel ICH8, or ICH8R, or ICH8-DH,
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Core_2_Chipsets
{Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Intergrated_Circuit }
The Northbridge chip handles the Processor, Ram Memory, and HIGH-speed graphics.
AGP and PCI Express are High-speed graphics.
A graphics card in a PCI slot is not High-speed graphics.
The Southbridge chip handles the slower capabilities of a computer.
PCI and Integrated Graphics being two of the slower capabilities.
SATA, IDE, USB, and Ethernet, are also some of the slower capabilities of a computer,
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
CPU = Central Processing Unit. Another name used is Microprocessor, or Processor for short ]
3) Power Supply.
The Power Supply has enough power to light LED lights, and maybe spin fans, but Not enough power to turn the Processor on.
A) ALL the LED lights on at once will consume less than 1 Watt of power.
B) EACH fan consumes 2 to 3 Watts of power.
C) A typical Processor can consume (Maximum) 51 to 125 Watts of power.
Depends on what Processor it is.
The Dell Dimension E521 desktop computer's motherboard, has an LGA 775 processor socket.
(Processor has the socket holes, processor socket has the pins)
The Intel processors that can be used in this processor socket, can be an Intel Pentium 4, (Version that uses an LGA 775 processor socket), Intel Pentium D, or Intel Core2 Duo, AND Intel Core 2 Quad, with a maximum FSB of 1066MHz. (If the BIOS version will support Intel Core2 Quad processors)
{Front Side Bus of 1066Megahertz}
Wattage consumption can be as much as 105 Watts.
Do you have a KNOWN to be good, compatible Power Supply available, to use as a test unit?
{Compatible being that the Power Supply case fits, (ATX), has the right amount of power cables, and the correct power cables. (Needs to have a 24-pin ATX main power cable, and a 4-pin ATX +12 Volt power cable, for one)
Perhaps there is an unused computer that has a Power Supply you can borrow.
Maybe someone has upgraded to a better computer, and has an unused one with a compatible power supply for a test unit.
Nov 07, 2010 | Dell Dimension E520 PC Desktop
FAN OK BUT NO DISPLAY
I like that. Kinda' rhymes. "Fan OK but no Display"
Problem is your Processor isn't turned on.
You have a bad Power Supply.
You probably have a 200 to 300 Watt power supply. (SMPS)
1) ALL of the LED lights together use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts.
3) A typical Processor can use 51 to 125 watts. Depends on what Processor it is.
The Intel D845GVSR motherboard uses a Socket 478 processor socket.
Supports Intel Celeron, Intel Pentium 4, and Intel Celeron D, that utilize a Socket 478 processor socket, and have a maximum FSB of 533MHz.
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Pentium_4_Chipsets
Utilizes the Intel 845GV motherboard chipset.
[ Intel 82845GV Northbridge chip, and Intel ICH4 Southbridge chip ]
89 Watts is the maximum wattage, that can be used by a Processor for the Intel D845GVSR motherboard.
Power Supply has enough power to light LED lights, and spins fans, but not enough to turn the Processor on.
No Processor operating, No computer.
No computer, No video signal to the monitor.
(No Signal)
Do you have access to a KNOWN to be good, compatible Power Supply, for a test unit?
Motherboard Manual in PDF file form:
http://www.intel.com/p/en_US/support/highlights/dsktpboards/d845gvsr
Under the heading > Documents and Guides, left-click on > Product Guides for D845GVSR.
Then left-click on the first file listed.
Product Guide - PDF File Name: D845GVSR_ProductGuide_English.pdf
Nov 03, 2010 | Intel D845GVSR Motherboard
My pc with EliteGroup P4VMM2 Motherboard didnot turn on but the fan and of cpu are working but wont open! what shoul i do? pls email me @ nhatz_cruel@yahoo.com
verify that the monitor is working if you can. Is the hard drive lite lighting up, If not try removing and reseating the ram. if the hd lite in on then it would sound like the graphics card is out, try replacing it.
Oct 21, 2010 | EliteGroup P4VMM2 Motherboard
Gateway 550GR Still Not Booting Up
Have you tried a different power-supply?
A power-supply must emit a few different voltages; if it fails to output one of those voltages, the fans still may spin, and the CD-drive-tray may still open, but the motherboard may not be getting the correct voltages.
Disconnect the AC power, and then open the case. Look at the capacitors (those black/silver cylinders with an X in their silver-coloured top).
Any capacitor that is bulging, i.e., does NOT have a perfectly-flat top, is leaking. Any capacitor that seems to have rusty-brown "sand" on top also is leaking. Either way, it's time to replace the motherboard.
Jul 03, 2010 | Gateway 550GR PC Desktop
Computer will not boot to windows. the screen displays phoenix - awardbios v6.oopg, an energy star ally copyright(c) 1984-2004, phoenix tehcnologies, ltd p4m800-m7 (pm48m309 bf) main processor: intel(r)...
The light you're referring to is the HDD Activity Lamp.
(HarDDrive)
It blinks green when it's operating, and orange for inactivity, or not operating.
You're getting to the BIOS Post screen, but BIOS is handing over the computer to the Operating System.
(Windows XP is an example of an O/S)
When you press the Power On button;
1) A temporary connection is made from the motherboard to the power supply. A 5 volt circuit is made. This turns the power supply on. (Soft Power On)
2) The BIOS chipset, is the first chipset to receive power. (Chipset is a slang term for IC. Integrated Circuit)
The BIOS program, ( 64MB in size), looks to see what all devices are connected.
(Harddrive, optical drives, mouse, keyboard, etc.)
3) Then BIOS does a Ram Memory count,
4) Turns the Processor on,
5) Then hands the computer over to the Operating System.
It looks like BIOS has recognized your Intel Pentium 4 processor, (2.66GHz frequency rate, 533MHz FSB), but hasn't turned the processor on.
[Let me stop,and explain something real quick.
Where you see -
Intel (r) Pentium (r) 4 cpu 2.66ghz (133x20.0)
The r stands for Registered. Intel and Pentium are registered trademarks of Intel Corporation.
It's a Pentium 4 model.
2.66GigaHertz is the Frequency Rate. Slang term for frequency rate is 'Speed'.
Giga = Approximately 1 Billion
Hertz stands for Cycles per Second.
At maximum capacity, your Pentium 4 processor can operate, at a 2.66 Billion Cycles per Second frequency rate.
133 stands for 133Mhz. 133 MegaHertz.
Mega = Approximately 1 Million
This is the Clock Rate. Intel processors are 'Quad-Pumped', so the FSB is actually 533MHz.
(FSB = Front Side Bus)
The 20.0 is the multiplier.
20 times 133Mhz = 2600 Mhz,
or 2.66GHz ]
Now, why is the processor not turning on?
Suspect the Power Supply.
1.ALL the lights for your computer use less than 1 Watt.
2.EACH fan uses 2 to 3 Watts.
3.A typical processor uses 55 to 125 Watts!
(The Processor hasn't been turned on, so nothing else is receiving power yet)
This is the basic specifications for your processor,
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#Prescott_.2890.C2.A0nm.29
Scroll down the left column of the list.
Where you see Pentium 4 505, Pentium 4 505J, and Pentium 4 506. Your processor is one of these three.
Scroll across. You will see 2667 MHz. 2667Mhz is rounded off to 2660 MHz, or 2.66GHz.
You will see 533M/T as you scroll across.
M/T stands for MegaTransfers. A more accurate description of FSB. Front Side Bus.
Scroll further across. You will see 20x. This is the Multiplier. (Look up)
Lastly scroll across a little further. You will see 84W.
This stands for 84 Watts.
Your processor operating at maximum load, uses 84 watts.
Why do I suspect the power supply?
Because it's the number 1 thing to fail in a computer.
Electrolytic Capacitors fail inside, or are failing.
They have Electrolytic Paste inside them.
The paste has developed a gas, (Hydrogen gas), and has popped seals for the capacitor's case.
This results in Electrolytic Paste slowly oozing out of the capacitor, and resulting in the capacitor failing, or has failed.
Electrolytic Capacitors are used as Filters in a computer power supply. They filter the incoming AC electricity from your house, and the outgoing DC electricity made from the power supply.
When capacitors are failing, or have failed, they create a bad power rail.
There are three main power rails in a computer power supply.
1) The 3.3 Volt power rail
2) The 5 Volt power rail
3) The 12 Volt power rail.
With a weak power rail due to failing capacitors, or a bad power rail due to failed capacitors, you do not have enough power to turn the processor on.
Solution?
Use a known, good, compatible power supply for a test. If the power supply is found to be bad, replace it.
Questions?
Dec 20, 2009 | Biostar P4M80-M7 Motherboard
What is the hardware specification of windows 95
System requirements for installing Windows 95:
  • Personal computer with a 386DX or higher processor (486 recommended)
  • 4 megabytes (MB) of memory (8 MB recommended)
  • Typical hard disk space required to upgrade to Windows 95: 35-40 MB The actual requirement varies depending on the features you choose to install.
  • Typical hard disk space required to install Windows 95 on a clean system: 50-55 MB The actual requirement varies depending on the features you choose to install.
  • One 3.5-inch high-density floppy disk drive
  • VGA or higher resolution (256-color SVGA recommended)
Oct 22, 2009 | Microsoft Windows 95 for PC
Intel D945GCLF - No post, No video Signal
Sounds like your wiring isnt right on the on off power. Make sure your power supply can handle this MotherboardAdapter cables are available that allow the incorrect use of older ATX or SFX power supplies in place of an ATX12V or SFX12V power supply. Intel does not recommend the use of these cables. These cables convert a standard 1x4 peripheral connector to the ATX12V 2x2 connector. An ATX12V or SFX12V with the 2x2 connector is required for all Pentium® 4 processor based Intel® Desktop Boards. Using the 1x4 converter cables can lead to system component or power supply damage and/or boot failures. The ATX12V and SFX12V power supply design guides (http://www.formfactors.org/)* recommend a minimum of 8A at 12Volts to properly power any Pentium 4 processor based Intel® Desktop Board. Standard ATX and SFX power supplies typically provide approximately 5A of current, which is not capable of reliably powering the Pentium 4 processor based Intel® Desktop Board. And I think the motherboards going to look for a formatted hard drive wired to the motherboard It wont boot off that USB stick.
Sep 22, 2009 | Intel D945GCLF Motherboard
My computer won't start but power supply and Motherboard is okay
if i understand correctly you swapped the cpu to another computer and it did not work... you need to purchase or find another cpu that is compatable with your motherboard.
Robert
Aug 25, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor Logo
64 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
