Question about Belkin Wireless Share Router (F7D3302)
Hi. I have just set up a Belkin Share wireless router, Connecting to internet fine, but can't get printer to work via usb. Green light above socket doesn't come on when I plug it in. Thanks in advance - ian
    Novelist:
  • 108 Answers
Ian, you have to 1st of all connect that printer to the computer and check if its working fine or not. Check if you have installed the necessary drivers and software that came along with the printer. Once that gets to go, then, connect the printer to Share router and check if the light above the USB is lit up to check if the port on router is working. If that is lit, you have to be connected to the router (make sure that you aren't connected wireless as a guest). Guest access doesn't have the rights to have file and printer sharing! Install the router monitor software properly that would be on the disk which came along with router or download the latest version of software from: http://en-us-support.belkin.com/app/answers/detail/a_id/3714/p/5132
You also have a brief tutorial on how to configure a printer with this router on the Belkin Support website. Here is the link for that. http://en-us-support.belkin.com/app/answers/detail/a_id/3796/p/5132.
For further clarifications, do revert!
Thanks for asking.
Regards,
Arvind S Iyer
Posted on Oct 03, 2010
Connecting Seagate Backup Plus Desktop drive (STCA3000101) to Belkin N750 wireless router.
Usually you don't need to setup any additional settings or creating new users on the Belkin router to access an USB HDD attached to it, if you used the Belkin Router Manager to set it up.
The Seagate drive you are using have it's own power supply, so that should not be a problem. Also the accepted formats are FAT16, FAT32 and NTFS formatted HDD.
You can try to set it up again using the manager. This is the user manual for your router, if it helps:
http://www.belkin.com/networking/manual/MAN_F9K1103_8820-00778_RevA01_N750.pdf
If you still can't get it working, let me know and we will try to find another solution.
Jan 05, 2014 | Belkin (F5D8231-4) Wireless Router...
Hi there, i got a usb air card for my laptop and i want to send out a signal to my belkin wireless router (with a cable) so that it can send out a wireless signal and be able to put my wireless printer on...
Sure, I can help. First off I need to know more information. Are you planning on connecting the printer, through USB, to your laptop then sharing the printer from there to other computers? If so, it is a matter of adding that printer, going into the printer properties, sharing tab, and sharing the printer. Or are you trying to share your printer wirelessly? If so you may need to buy a wireless print server. It acts as a base to share that printer and then allow you to wirelessly find it and connect. If the above doesn't help please tell me the make and model of your printer, laptop, and wireless router.
Best, -Mind
Aug 03, 2011 | Belkin (F5D7230-4) Router (587009)
I have a embarq 660 series router and using a compaq presario computer. I have already installed the belkin surf/share wireless USB adapter to this laptop. When I go to Internet explorer it says offline.
your problem is a IP address conflict
Embarq and Belkin have the same IP address 192.168.2.1
change the IP address in to your Router.
To restore the router to factory default settings, please do the following:
1. Unplug the router's power supply
2. Press and hold the reset button on the bottom of the router
3. Keep the reset button depressed and, at the same time, plug the power supply back in
4. Keep the reset button depressed for another 10 seconds
5. Release the reset button
======================= Manually configuration ==============================
Step 1 : Connect modem - Router - Computer ( Wired )
Step 2 : Open router setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left side under internet WAN click Connection Type
Step 4 : leave the Password Blank and click submit
Step 5 : Choose the connection type as dynamic and click next
Now go to lan settings and change the IP address 192.168.2.1 in to 192.168.1.2
Step 6 : Leave the Host name blank and click apply
Step 7 : On the left Under Internet WAN Click MAC Address
Step 8 : Click Clone and Click Apply changes
Step 9 : If the Internet status on the top right is connected
Step 10 : Then check if you have internet
Step 11 : if not Then unplug the Power Cable from the Modem And the Router
Step 12 : Plug the power Cord to the Modem
Step 13 : Wait till all the lights are on
Step 14 : Plug the power to the belkin
Step 15 : Check the color of the light in the belkin
Step 16 :If green then Check if you have internet
If not working then call belkin
=================== WIRELESS SETTING UP A WIRELESS CONNECTION ====================
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Sep 06, 2010 | Belkin Surf Share Wireless USB Adapters...
Belkin G plus mimo router no internet light? had to reformate system and lost settings. it was working and connecting with my laptops and able to share verizon usb modem internet connection but now i cant...
Belkin router stopped working all of the sudden there Can be many reasons behind it Like router Overheating, Router Firmware, I.S.P Issue, Hardware Problem etc.
?let's get this issue resolved by following some easy steps:-
1. First, you need to unplug the Belkin wireless router from the modem and now connect the computer to your modem with a cable Just to see you are getting the internet.
2.connect the modem to the router using an internet cable to the internet port(Ethernet port).
For more steps you need to visit https://fixingblog.com/belkin-wireless-router-is-not-working/
I Hope it will work for you
Dec 02, 2009 | Belkin (F5D7230-4) Router (587009)
F5D7231-4 stopped connecting to Internet via downstream router
Why did you change it from dynamic to static? My suggestion would be to put it back to dynamic and let it grab a good ip address from the gateway. The other option is to contact whoever managed the network at your apartment and see what they will charge you for a static IP address.
May 23, 2009 | Belkin (F5D7231-4) Wireless Router
Hi, I have a desktop and a wireless router. The desktop was connected to the internet via a Belkin USB wireless adaptor but it has suddenly stopped and does not pick up any signal. I have uninstalled and...
Belkin products are notorious for breaking down at a high rate. If you wanted to rule out your computer as the culprit, you could install the belking adapter on your laptop (disable the built-in one) and see if it still works. I would also suggest going here:
http://www.belkin.com/support/
and typing in your product model # and downloading the latest firmware/software for it. As always, restart your computer.
Jun 10, 2008 | Belkin Computers & Internet
Belkin wireless g problem
First, you will need to restore the settings on your router, then get your laptop onto the network.
Apr 21, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin f5d7633-4 wireless g modem/router
when you upgraded did any settings from your isp change like passwords or usenames that your router may not be registering at your isp's server, or the line speed that you are now getting is not suported by the router.
type 192.168.2.1 in your web browser and check the connection settings.
Oct 20, 2007 | Belkin (F5D7633UK4A) Wireless Router
Belkin F5D8630 wont take my new log in details
check to see if all of the ssid's are all the same or if there is another wireless system interfering.
Sep 11, 2007 | Belkin (A3L85014BLS24)
Belkin Wireless Share Router (F7D3302) Logo
348 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
