Question about Watches
How to set day and date on Ravel ladies' wrist watch
  • 3 Answers
SOURCE: ladies aquaracer 300 meters
the crown is a screw down type to keep the watch water tight. Unscrew the crown (what you refer to as the dial) and you will then be able to set the date, time, etc. and be able to wind the watch manually. P.S. You unscrew the crown by rotating it counter-clockwise.
Posted on Jan 28, 2008
SOURCE: Pulsar Men's analog wrist watch - how to set day and date
Pull crown out to 1st position....Turning one way will alter the date and turning the other way will alter the day.
Posted on Jun 11, 2008
SOURCE: Setting Day/date on Helbros wrist watch
I have that watch too, and I love it. I never had a manual, but the only way I could set the date was to pull the crown out all the way and advance the time. Each 24 hours (clockwise) will advance the date one day. Turning the time counterclockwise will advance the day. Most day/date watches have two positions when you pull out the stem, first click for day/date, all the way for time. This watch seem to have only one position.
Posted on Jun 24, 2008
SOURCE: how to set up ladies roxy digital watch
I found users instructions on roxy website at:
http://www.roxy.com/search/index.jsp?f=Taxonomy%2FROXY%2F2818169&categoryId=2818071&f=Taxonomy%2FROXY%2F2818071&fbc=1&fbn=Taxonomy|Watches&fbx=0
We were able to program our watch completely!!!
If you look on the back of the watch that you bought on the metal plate, it tells you the style. Ours was the Roxy 70's digital watch, and I found specific instructions at (even if this is not your style, the instructions may work):
http://www.roxy.com/graphics/uc/roxy/manuals/Roxy_manual_watch_70s.pdf
Posted on Dec 23, 2008
  • 2501 Answers
SOURCE: Did not get instructions with my ladies digital
Enter "www.armitron.com", select "support" and then watch instructions" and a set of diagrams will appear.
Go to the one that looks like yours (use the two brown arrow heads to scroll through the list) and download the instructions.
Posted on Jan 30, 2010
How to set ladies rolex watch?
A standard ladies rolex should have just one stem and crown on the side. Occasionally the crown is a screw down crown. Try to pull the crown out if it does not pull out try to pull and unscrew it at the same time. There are two settings one you pull the stem all the way out and that should set the time, if there is a day or date setting, you push the stem halfway in turn one way for day and other way for date. Please let me know if there are any other buttons on watch thank you!
Aug 27, 2011 | Watches
How to advance date 4 or 5 days on a Timex T40021
This watch should have a "quick set" date function that lets you advance the dates by turning the setting crown. To get the watch in this mode, pull the set stem out half-way. At that point, turning the setting crown will advance the date on the watch without turning the hands. One some watches, finding the right position for the set stem can be a bit tricky--either it's not out far enough or it's out just a bit too far and the time hands turn. You may have to try pulling the stem in and out a few times to get it just right.
A word of advice: watches are generally designed to advance the date, not to turn it back. It's suggested that if you need turn the date back, you actually advance the date wheel up to 30 days to get to the date you want. Some watches do permit you to turn dates backwards, but I prefer not to risk the chance of hanging up the little springs and mechanism that are designed to advance the date indicator.
One final note: I have serviced several Timex mid-size (ladies or kids size) Expedition watches that lack a quick-set date. Many Timex watches in that size do have a quickset date like I've just described to you, so I have no idea whether these watches happen to have a cheaper movement or if they have some internal damage (it's been the same model each time). At any rate, for those watches, I have had to use the incredibly slow and painful process of advancing the time 24 hours to advance the date. With those watches, if the date is too far advanced by a day or two, it may be easier to stop the watch for 24-48 hours until the date is correct, rather than spend a huge amount of time spinning the crown to advance the time. Hopefully, your watch will have the more sophisticated movement, though.
May 28, 2011 | Timex Expedition® Metal Field 47042...
Fix date n month on wrist watch
mcdevito75 here The stem has 2 positions, we all know the 1 to pull the stem out and set the time, day, date. try this, first go thru the watches 24 hour cycle to get the month you need, now slip a fingernail just under the stem (crown) and gently lift to it"s first position, it may take a few times to get used to, when you have it turn the crown (stem) to change the date easily, change the date to 1 date before the date you want, now go thru the watches 24 hour cycle to get to the date you need. Now the watch is set and will change on time at around mid--nite.
Jul 19, 2010 | Pulsar 5117 Wrist Watch
0512037FA Wrist Watch: how do you set the date in the window of a seiko 6...
mcdevito75 here, The stem should have 2 positions to set the DATE without haveing to cycle the watch 60 times. Slip a finger nail just under the crown and gently, gently lift the crown to it's first position, it may take practice so be patient, once in it"s first position you can easily change the DATE, change it to 1 DATE before the DATE you want. NOW! push the stem back in and then pull it out to set the proper DATE and time of day, your watch is set and will change on time, around Mid Nite.
May 18, 2010 | Seiko 0512037FA Wrist Watch
Type of battery for ladies guess watch
I have a guess W15514G2.. and I want to change the day in the watch, In the first click I am able to adjust Date on one side and month on the other side, the next click makes me adjust the time. But what about the Day? How do i adjust that? Help me
Jul 13, 2009 | Guess G66355L Wrist Watch
Adjusting day/date on a self winding Seiko, 7S2GB
mcdevito75 here, Your stem has 1 positions to set the date easily without haveing to cycle the watch 60 times. First pull the stem out to set the day, set the day 1 day before the day you want, next, push the crown back in, NOW! Slip a finger nail just under the crown from the back as there is more room, it may take some practice so be patiernt and gently, gently lift the crown to it"s first position, once in it"s first position turn the stem and see the DATE change, set the DATE to 1 DATE before the DATE you want, NOW pull the stem out to set the day date and time of day. Your watch is set and the day date will change on time, a little past mid nite.
Apr 14, 2009 | Seiko SGF204 Wrist Watch
Ladies Cardinal Digital Watch
There is a "Contact Us' page on their website. Perhaps you can ask them directly:
http://www.cardinalwatch.com/
choose english, then 'Contact us' tab. Make sure you state the model of your watch so they can help you better.
May 27, 2008 | LogoArt St. Louis Cardinals Wrist Watch
Setting my day date on watch
mcdevito75 here, The stem has 2 positions, first, set the day to 1 day before the day you need, now, slip a finger nail just under the stem and gently, gently lift the crown to it;s first position, set the DATe to 1 date before the date you need. Push crown back in, now pull crown out to set the date and time of day. Your watch is set and should change around mid nite
May 03, 2008 | Seiko SLL003 Wrist Watch
Apr 23, 2008 | Pulsar PXF106 Wrist Watch
Setting sub-dials when several months wrong
Try the manufacturers web site, you can normally find all the information you could require
Dec 11, 2007 | Citizen Eco-Drive BL006056H Wrist Watch
Watches Logo
251 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
