Question about Oregon Scientific Measuring Tools & Sensors
I am looking for a Manual for the WMR928NX Weather Station firstly, and if there is a way to set the pressure on the main screen to compensate for altitude so that it gives the correct barometric reading for sea level
Noggin
  • 944 Answers
SOURCE: Incorrect altitude changes
Here is the link to the user manual for this watch if you need it; http://www.lacrossetechnology.com/k2100/manual.pdf page 12 gives you all the contact details for lacrosse. I couldnt find the info online to be sure, but some of these watches do have a separate pressure sensor for altitude and barometric pressure, and sometimes the path to one could get blocked or it could become faulty. I would contact la crosse and find a dealer to get the watch serviced, you could probably do it yourself but you need to get replacement seals from them anyway (these are important). ask them to check if the sensor is clogged, it happens sometimes. Hope this helps :)
Posted on Apr 14, 2007
emissionwiz
  • 76164 Answers
SOURCE: 1993 Nissan Altima will crank but won't start - sometimes - altitude issues?
The system is not affected by altitude in this way, the thing you need to check is fuel pressure, this may be pump related.
Posted on Oct 22, 2008
fslahmed
  • 127 Answers
SOURCE: setting up wireless for the first time. what's
you need to use station mode and it`s not like it`s unsecure.every network in the beginning is unsecure but you have to secure it using wep or wpa.take care
Posted on Jul 15, 2009
SOURCE: How to adjust the altitude in this weather
I solved it by my self by a try and error procedure
Posted on Oct 12, 2009
SOURCE: Acu-rite Weather Station Model 00593A2
press
Posted on Sep 25, 2010
The baro reading is 10.12 but the local weather station says it should read 30.04
What pressure units is the unit set to display? Looks suspiciously like a difference in units. The local weather station is reporting the baro reading in "inches of mercury."
Feb 04, 2016 | Measuring Tools & Sensors
Replaced batteries in both transmitter then w/station. Latter then started clicking & all items on screen flash on and off with the "clicking". Nothing functions or can be programmed.
Try putting the batteries in the weather station first and then the sender units.
Let me know make and model and I'll see if I can find a manual.
Oct 04, 2015 | Measuring Tools & Sensors
Display station not showing outside temperature
Check battery status indicator on main weather station of remote unit. If no indication, replace battery in remote unit. If battery is good then check "channel setting" of remote unit to make sure the channel setting on remote unit matches the "channel" setting on main unit. many weather stations will take up to 3 or 4 remote units and they must use different channels to relay the remote imfo to the main weather station unit.
Jun 19, 2015 | Measuring Tools & Sensors
I need a manual for the 00593W weather station. Please?
Push and hold the "-" button on the main unit until "P" displays on the screen. You'll now set the time zone so the system can automatically set the clock. The screen will begin cycling between the time zones. Push the "Set" button when the correct time zone appears.
Mar 06, 2013 | Acu-Rite Acurite Wireless Weather...
Download Digitech Weather station XC0346 Manual
To set station Hold SET key down for 3 secs. Press SET key to select setting in this sequence. 1. Time Zone 2. 12/24hr format 3.Manual time setting HR/Min. 4. Calendar setting y/mm/dd 5.Temp display C or F 6.Air pressure display hPa or inHg 7.Relative pressure setting from 919.0hPa-1080.0hPa 8 Pressure threshold (sensitivity)Default 2 9.Storm threshold Default 4 10.Wind speed reading km/h, mph etc 11 Rainfall display in mm or inch. Use the + and History keys to adjust values (History key is - ) When replacing batteries Fit outside unit ones first then fit inside unit ones in that sequence so it can interpret the security code.
Apr 05, 2012 | Measuring Tools & Sensors
WMR928NX battery replacement
I have an Oregon WMR928NX weather station. I have replaced the alkaline batteries in the wind and rain sensors. These did not communicate with the main unit, so I reset both units but only the wind sensor communicates. I have checked both battery voltages on the cuircuit board and both are correct, I don't know a solution. Thanks Rob
Nov 23, 2010 | Oregon Scientific Cable Free Weather...
Setting the time zone
I actually have the same problem with an older model Brookstone weather station with remote temperature gauge. The time/date settings do not allow you to set time zone and eventually the clock syncs to PST.... ANY HELP HERE?
Mar 19, 2009 | First Alert FWS-101 Wireless RF Weather...
Projection t.v.
When you say Main color setting, Do you mean your trying to make the colors look better as there are no main color settings but there are main screen controls and this would give the set its B & W settings so then the colors look better. And theres main focus control that would sharpen up the picture. Ok first thing your gonna need to do is Get a service manual so we can find where all the adjustments are. You should ba able to find a service manual if you look in your user manual for a service station for hitachi. Now if your a tech or experienced with tv repair we can go over this but I need to know exactly you are trying to do first Thanks
May 28, 2006 | Hitachi 60EX01B 60" Rear Projection...
Measuring Tools & Sensors Logo
75 people viewed this question
Top Oregon Scientific Measuring Tools & Sensors Experts
Lawrence Oravetz
Timllfixit
Are you an Oregon Scientific Measuring Tool and Sensor Expert? Answer questions, earn points and help others
