Question about Bosch Washing Machines
My washing is coming out smelling fausty and stagnent
4 Suggested Answers
  • 116 Answers
SOURCE: WT540 Washing machine has a smell coming from it
Based on the front load picture you included with you description...
This usually comes from a build up of soap and dirt that you cannot get to to clean. It is in the inner wall of the outer tub.
You should run a thorough cleaning with a product called Washing Machine Magic. It is designed to reduce this build up over time.
Another way to reduce it is use a very hot wash and put 1 cup of powder dish detergent in the tub before starting it. (yes I know this is a clothes washer). The dish detergent has ingredients to help reduce the odour.
These methods may have to be repeated several times to be 100% effective, but a large part of the odour should be reduced after the first cycle. If more are needed repeat once every couple of weeks until the odour is not noticeable.
The rubber door seal on this model should not accumulate smell but it may have depending upon the machine's age. This will have to be replaced if it has.
Posted on Aug 05, 2008
  • 6277 Answers
SOURCE: there is a stagnent water
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jun 16, 2011
  • 6 Answers
SOURCE: Stagnent water smell while filling
I found that running about a quart of white vinegar through a cycle with hot water and no clothes or detergent takes care of the musty smell. Vinegar removes detergent build-up.
Posted on Nov 13, 2011
Fausty smell in car
Never heard of a "fausty" smell.
However, I am supposing you do not like it.
If so, try a container or two of baking soda.
Sprinkle it liberally all over the inside of the car, and leave it for about a week, and then vacuum it up.
Be certain to allow no water or moisture inside the car for that time, lest you have "mud".
See if that helps.
Understand that if the smell is coming from the heater or air conditioner area, this will not help.
God bless your efforts.
Dec 11, 2017 | Cars & Trucks
Machine smells fausty
It is good to use the juice of a fresh lemon to wipe around the drum and then rinse.
Sep 23, 2017 | Washing Machines
Smell from vents
do the A/C mold killing spray , procedures.
on most newer cars with the filter in dash.
you remove the filter and spray that killer down in there.
this kills the mold in the condesate tray.
also clean the condensate drain tube that goes from (USA) passengers toes to below car, as pool of fresh water as seen
on all cars with A/C running,or parking after.
if the tube cloges water can go stagnent and as the name implies.
stinks bad.
Jan 08, 2014 | 2007 Suzuki Forenza Sedan
Nov 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Stagnent smell from inside drum
is ther a **** trap fitted to the outlet pipe
Mar 01, 2010 | Washing Machines
We have a Meile fridge freezer and the smell seems to be coming from the back (no smell inside)It has been a constant smell but occasionaly gets worse. It has taken us a week to find out that its coming...
Self de-frosting tray at the back of the fridge was full of old stagnent water. Removed tray cleaned out, flushed out the pipe from the inside of the fridge to the drip tray. No more smell.
Nov 02, 2009 | Refrigerators
Aug 05, 2008 | Hotpoint First Edition FEW10P Front Load...
Washing Machine smell
The problem comes from the design of the front load washers. There is always a little water left in the tub after the machine is used. Running a bleach load will deal with the mildew until the machine is used again. I leave the door open when I am not using my washer, and this does help.
Apr 10, 2008 | Washing Machines
Whirlpool AWM6120 Front Load Washer
Cleaning depends on use. 8 years is a bit over the top! When your water does not drain, check the outlet filter first, then the pipe from below the tub to the filter. Your washer wont spin 'cause the pump/filter is blocked.
Jul 24, 2006 | Whirlpool AWM6120 Front Load Washer
Fabric softener compartment problem.
Squeee, It's been more than a year since you posted this so I guess you must know the answer. It sounds like a Visit from an engineer(?) I've got exactly the same problem with a Servis Easilogic 1500 and would appreciate knowing what you had to do to resolve the issue.
Jun 11, 2006 | Ariston Technologies LBE12X Ariston
Washing Machines Logo
60 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
