Question about Acer AL1916W 19" LCD Monitor
The monitor shows no signal after some time while the cpu is runing
    Sergeant:
    Champion:
  • 293 Answers
Check the VGA cable connection.u better fixed VGA connector screw.
Posted on Oct 03, 2010
Pls check the fan inside the cpu wether some wires are close to it
if this happens push the wire away frm it
Posted on Oct 05, 2010
My cpu is front light on but not go to disply powr fan is ok runing but not show the disply plz help me any on
check the display monitor cord to CPU if attached perfectly/check on off switch of display screen
Feb 23, 2015 | Computers & Internet
Monitor shows no signal message.
Check for a loose CPU. You video will never work independent of the CPU. I assume you used CPU thermal grease. Also double check memory. Additionally, not all CPUs work with all motherboards even if they have the same socket. Try another computer on the monitor. I personally never do more then 1 change at a time to isolate the causes. You may also have a loose cable. If your monitor was defective you would not get such a message from it. It would most likely just be blank.
Jan 01, 2014 | Acer G205H Monitor
Ibm e74 monitor is no but signals is showing one time only 2 second than Blak screen power led alos on, one time eht is on than is off
Hi.try use other monitor connect to your CPU. if it's running good problem of your monitor data cable CPU to monitor. you need to trace loose wiring or pin of cable to CPU maybe loose.
See attach picture.
Jun 18, 2011 | Computers & Internet
VX922 only shows "No Signal" on black screen
The monitor shows no signal probably it didnt detect the tower
Ill be advising you to remoev the cable that conencts the cable
used a clean cot or rug clean both ends of the cable , clean also the area whre you plug in the cable , the ports on the monitor and on the CPU make sure its clean .
Then plugged it in , in case nothing happens
try to used another cable that conenct from the monitor to the CPU
you may aslo try to used other CPU to checked if monitor is working fine or try other monitor to checked if the port on the your CPU is working fine
May 23, 2011 | ViewSonic VX922 19" Monitor Flat Panel
Screen monitor self diagnostics show
that means no incoming signal, but some problem i encountered related in vga cable and lost connection on ckt board. as long that the cpu is working and the monitor show (no signal) focus trouble shooting on that parts. replace cable if possible( same port configuration)
Apr 20, 2010 | Princeton Digital VL2018W Monitor
No input signal
that is the problem of cpu not a monitor to confirm disconnect signal cable and power on. monitor will show "no signal check signal cable" it means that monitor is ok and fault lies in cpu .then open the cpu and disconnect ram and listen the beep. contineus beep should be heard then ram is faulty replace it. if no beep heard then motherboard is faulty .
Mar 08, 2010 | HP vs17
My monitor will not come on, the on/off light flashes occasionally and the monitor gives over a very brief light
make sure that your cpu is working. if the cpu is dead, there will be no display in the monitor. If the monitor light is flashing as you said, it could be the CPU not sending video signal to the monitor. also check if the cpu beeps when you start your computer. if not, check your cpu. try to re-seat your RAM modules. this will solve most of these types of problems
Sep 03, 2009 | Computers & Internet
Dell dimension 8400 beeps 6 times monitor dosen't turn on
Below is a link to the beep and light codes for a Dimension 8400. Check your codes and reply back if you need further assistance.
http://support.dell.com/support/edocs/systems/dim8400/SM/adtshoot.htm
Jun 03, 2009 | Dell Dimension 8400 PC Desktop
Led pwr+hd isn on, cpu fan is runing, but no
if your monitor is working properlly,then you should check the following things:-Remove ram and start the computer. If it gives you any beep then your motherboard is all right.And if not,then it's time to buy a new motherboard.
Mar 17, 2009 | Gigabyte GA-8I848P-G Motherboard
Black Screen on ACER LCD 1916 Monitor
see there is power in monitor and check also that your monitor is getting signal from cpu just remove the data vga data cable from cpu and see is it showing any massage on screen like check signal or any other massage. and check your keybord also by pressing num lock key see the light is on and aoff when you pressing the num lock button . if nothing is happen that mean your monitor is not getting signal from cpu and it is not monitor problem . bye
Sep 25, 2007 | Acer AL1916W 19" LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
530 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
