Question about Freezers
Makes ice won't drop
Kenmore elite coldspot
free standing ice machine
model #89482991
loades with water makes ice will not fill with more water leaves pump trying to circulate the water , than won't drop ice evan when hand filled.gave machine 4 hours to complete cycle. runs the clean cycle ok
  • eevader Sep 14, 2008
    hoshizaki ice machine model km320mah-dbi30h . found ice machine toggle switch off. I turned ice machine toggle switch back to "ice". waited a couple of minutes...and noticed red light inside circuit board solid red...had to open up metal cover to access the white reset button located at the upper right hand corner of the circuit board...pressed down on button for a few seconds..noticed green and yellow l.e.d.s lit up and machine began to run water through coils...waited about 5 minutes compressor and fan kicked on...came back a hour later to check for ice....nothing came out and compressor was still running. what should I look for to see that machine is actully making ice?? please would like to know
4 Suggested Answers
Master_Tech
  • 770 Answers
SOURCE: Ice Machine
there is a cutter grid which makes the cubes check that if this unit is not inside of a freezer is it?
Posted on Jul 08, 2008
  • 358 Answers
SOURCE: Kenmore Coldspot Model 57577791 S/S Ice Maker Problem
Probably the solenoid (electric valve that opens when the ice maker calls for water ) is leaking and has to be replaced (it's a very common problem ) . To be sure the solenoid is the problem , turn off the ice maker by raising the arm up , and check after a few hours if is any water in the ice tray , if yes the solenoid is leaking , if not , the ice maker control board has a problem , and to replaced it will cost you almost as a new ice maker.
Posted on Oct 19, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Sears Kenmore free standing ice maker not making ice
Hi and wel;come to FixYa. I am Kelly.
Do you know if the compressor is even running?
Also how long has this icemaker been in service?
There are only 3 things that can cause a condition that the unit is not freezing.
1. Low coolant
2. The compressor is not running.
3. The condensor or evaporator fan is not running.
Having said that...
The most common failures for a cooling system are
the PTC relay / thermal overload and the run capacitor.
PTC Relay is item 18 of link below
Thermal overload is item 20 of link below
The condensor fan motor is Item 4 of the link below
Link:
http://www.searspartsdirect.com/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fP0109006-00005.png
Item 5 the electronic control board (see link below) controls the operation of the compressor via the thermostat Item 12 of link below. In addition to that there is also 1 thermistor (Item 20) that is also part of the control circuit.
http://www.searspartsdirect.com/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fP0109006-00004.png
ANY of the above can cause your icemaker not to function correctly. It will take circuit analysis to isolate which component may be causing your current system.
If the compressor is running and it is not cooling then
There can be any one of the following causing the problem.
1. Low coolant
2. A stuck valve for the cooling / ice making system (5ea)
3. The compressor can be running but not up to speed due to a dragging rotor.
I wish I could say _______ part is what causing your current symptom. It just is not possible without someone doing some on site troubleshooting of everything listed in this post.
Kelly
Link to all of your units parts:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=106.89482993+&=part+number&pathTaken=partSearch
Posted on Apr 17, 2010
Water freezing in tube to icemaker
Change the water control valve because it is not shutting off once the ice maker is full. The valve is sticking open slightly once power is off to water valve. What is the model number of your Kenmore Elite Model numbers for Kenmore most times look like this example=> 321.456789 Sea Breeze
Kenmore Model Numbers
Apr 01, 2013 | Kenmore 26.5 cu. ft. Side-by-Side...
Squealing sound when making ice
most of the time it is the water pump is going bad. It squeals real loud.
Sep 25, 2012 | Hoshizaki Freezer Commercial Ice Machines...
Kenmore Coldspot side by side ice maker not working, red lite bliking
Often I find your ice maker on the Kenmore side by side thefill tube frozen. The fill tube is ablack rubber hose located above and to the right of your ice maker. Simplypinch the tube to see if it frozen solid. If it is, use a hair dryer set onmedium to defrost the fill line. http://www.on-timeappliance.com/kenmorerefrigeratorrepairdallastx.html
Mar 24, 2012 | Kenmore Freezers
Oct 19, 2009 | Freezers
Slow filter water stream and hollow ice.
You have a mesh screen in the water supply line where it connects to the water inlet valve. It can be stopped up with sediment.
Sep 27, 2009 | Freezers
Kenmore Coldspot side by side. The ice maker will
Hello. You will need to replace the icemaker. The swicth in the head is causing the arm to stay up and is not repairable. If you can get me the model number I can get you the part number.
Jul 15, 2009 | Freezers
Sears Coldspot 17 frostless freezer not defrosting
One reason for the fan running is that it is trying to distribute the air in the compartment. Look at the very rear of the freezer on the bottom and see if the little vents, which allow water to disperse, are not filled with frozen ice. If so, turn off the fridge (unplug it) and use a hair dryer to melt that ice until it is all gone. That will probably fill the condensation pan under the unit and you'll need to empty it.
Feb 01, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Ice Machine
Jul 08, 2008 | Freezers
Freezers Logo
70 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
