Question about Garden
I need a diagram of the wiring on a cooper lighting raintight motion sensor flood light model MS185R
5 Suggested Answers
  • 76 Answers
SOURCE: need to know wiring diagram for cooper single pole lighted switch
well lets see on one side you should have two brass screws that would be to interupt your lead to the fixture then you either have a brass and silver screws on the other side or you have black and white wires the black or brass is always hot the silver or white is neutral does that answer your question if not hit me back with a description of what your switch looks like
Posted on Jun 27, 2009
  • 188 Answers
SOURCE: Have Cooper lighting outdoor motion detected flood
Sounds like the relay in motion sensor. Change the bulb. Rechargeable batteries are no good after 3-4 years also.
Posted on Jul 23, 2009
  • 250 Answers
SOURCE: need to wire motion sensor to light, have three
The black wire goes with the black house supply wire, and the red wire goes with the black wire from the lighting fixture. The white wires all connect together.
Posted on Feb 22, 2010
cdorot
  • 132 Answers
SOURCE: wire diagram for siemens motion sensor light
you might find it here:
http://support.automation.siemens.com/WW/llisapi.dll?func=cslib.csinfo&lang=en&siteid=cseus&aktprim=0&extranet=standard&viewreg=WW&objid=18257724&treeLang=en
please vote for me if helped :)
Posted on Jan 18, 2012
Cooper ms34w wont turn off stays on night an day without movment
Have you had a look at the underside of the motion detector the should be some things for you to a just it with
Mar 25, 2014 | Cooper Lighting Flood Lights. 180 Degree...
Motion sensor outdoor light won't go off
How long has this been going on? Has this light fixture been updated recently? Has the lite switch been changed that operates this fixture?
Feb 23, 2013 | Cooper Lighting regent light BRZ Motion...
Instructions to wire a cooper light model number MS35 rain tight
1) Copy following link for wiring diagram of 2-light outdoor motion sensor.
http://waterheatertimer.org/How-to-wire-switches.html#motion
2) Existing light fixture will have 2 wires: Connect wiring as shown on link above, then keep light switch turned ON.
Jan 21, 2013 | Hardware & Accessories
Motion sensor light wiring
problem could be sensor, not light, black is power, white is neutral, green is ground, sensor may have a red wire, black wire and a white wire, hook black wire to power from sensor, red to black wire on light,
white wires will connect together, then wire black to power on home, white to white on home and green to ground, if you need help call an electrician and they will wire it for you
Feb 03, 2012 | Home
Installation instructions for a Cooper Wiring Devices OS310U-W-K Motion-Activated Occupancy Sensor Wall Switch, White
LED bulbs with leaking motion sensors tend to flicker as well, more so than CFL. I switched to Cooper style - but now my Cooper OS310u will sense motion - and keep sensing motion almost all the time. If it's in test mode - it will shut off but otherwise it keeps sensing it. This is in a garage - and door open or closed does not seem to affect it. I have the same unit working in my basement just fine.
suggestion - don't try LEDs to solve the problem and yes - it will burn out your CFLs real fast.
Jan 12, 2012 | Electrical Supplies
I have a cooper 6107 motion sensing 3 way wall swithch and I am using it to replace a three way non motion sensing switch. I have it wired correctly, green to ground, black to common, and the red and brown...
Cooper 6107 instruction sheets:
http://www.cooperindustries.com/content/dam/public/wiringdevices/products/documents/instruction_sheets/469mt_pta_rev._a_.pdf
http://www.cooperindustries.com/content/dam/public/wiringdevices/products/documents/spec_sheets/std_sensswitch_spsht_4_10_anp.pdf
3-way installation shows two motion sensor switches.
Instructions do not show 1 motion sensor and 1 ordinary 3-way switch.
Also note the maximum load rating is 500Watt
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on electrical work or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 09, 2011 | Cooper Wiring Devices Motion Sensing...
I have a stairs with a switch and a bulb on each floor and i need to replace them with a wall pir sensor on each floor i need the wiring diagram
I answer questions for free.
I know electrical wiring.
I am unsure about a few things in your question.
Are you wanting to know how to wire a product you purchased?
Are looking for a wiring diagram to see if you can do what your want?
1) Is your circuit a 3-way circuit with 2 switches controlling both lights?
2) Or are there 2 different circuits where each switch controls one light?
Here is a Leviton manual with wiring for occupancy sensors:
http://waterheatertimer.org/pdf/Leviton-IPP0R-1LW.pdf
If you want sensors to replace 3-way switches, you need a control sensor and a remote sensor.
Click link below to see this image clearly
http://waterheatertimer.org/images/3-way-sensor-600.jpg
Add a comment and I will get back to you with specific details about wiring.
Oct 31, 2010 | Cooper Wiring Devices Motion Sensing...
How to wire a cooper industries 6107 3-way motion detector switch
I opened the box and traced the lines to see which are connected
when the switch is turned on and I left the red wire disconnected.
Jan 28, 2010 | Cooper Wiring Devices Motion Sensing...
How do you connect a motion sensor light switch to a chord that can be plugged into a wall?
hmmm lets see... what is the motion sensor controlling?... lets assume it is a lamp with a plug on it. so you need to wire the motion sensor so that it has a male plug on one end and a female plug on the other. lets also assume it is two wire lamp cord and a two prong plug. Take a standard extension cord and split off one of the wires and cut it, attach one of the motion sensor wire to one of those wires and the other motion sensor wires to the other wire.. so the motion sensor is splitting on of the wires.. oh this would be so easy to draw...
Nov 05, 2009 | Cooper Wiring Devices ACE6001V-K "ACE"...
Jul 18, 2009 | Desa International 240 Deg. White Twin 150...
Garden Logo
62 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
