Question about Sony Playstation 3 (PS3) Console
DNS error Okay, so, i was using my neighbor's network connection, and my ps3 worked splendidly on that. But then he moved away, and so i began to use my mom's, and now whn i try to get on it dosn't load the webpage. so i went to internet connection test and it says it is a DNS error (80710102), so what do I do?
You have to set up an new internet connection. then try it if it doesnt work call sony
Posted on May 27, 2008
Cannot connect dns error 80710102
Your ps3 cannot connect to your dns server, if your using a router make sure all ports are open for your ps3 google ps3 port forwarding for help.
if you want to manually type it in open command prompt and type ipconfig hit enter
this will show your ip and dns settings plug them into the ps3 network settings and try again.
Nov 18, 2009 | Sony Playstation 3 (PS3) Console
Connect ps3 to laptop via web and walk
Connecting PS3 to a network I have LinkSys wireless router which is working perfectly for other devices (like laptop, Xbox360, TiVO). My wireless network is configured to NOT broadcast the SID and with a WEP key. After entering this manually in the network setup on my PS3, I was able to obtain an ip address from my router, I was able to open the configureation page on my router, but connecting to the internet would fail with some kind of DNS error. The way this was resolved for me, was to enter the DNS server addresses manually in the PS3 network settings AND use tetertiary DNS server from my ISP as either the primary or the secondary DNS server. ..btw, this also fixed the similar problem I had with my PSP.. Thanks!
Jul 29, 2009 | Sony Computers & Internet
My ps3 HAS A dns problem
Whenever you are dealin with a DNS error, it is a problem on your internet service provider's end. Contact them for a solution. Thanks
Dec 31, 2008 | NetGear WGR614 Wireless Router
Roy lee
Finally the DNS problems I had with connecting my PS3 to my network has been resolved. I have LinkSys wireless router which is working perfectly for other devices (like laptop, Xbox360, TiVO). My wireless network is configured to NOT broadcast the SID and with a WEP key. After entering this manually in the network setup on my PS3, I was able to obtain an ip address from my router, I was able to open the configureation page on my router, but connecting to the internet would fail with some kind of DNS error. The way this was resolved for me (and I know someone else mentioned it in an other post here), was to enter the DNS server addresses manually in the PS3 network settings AND use tetertiary DNS server from my ISP as either the primary or the secondary DNS server. Voila... I am upgrading my PS3 software as I write this.... ..btw, this also fixed the similar problem I had with my PSP.. Thanks!
Aug 26, 2008 | Sony Playstation 3 (PS3) Console
Cant get internet connection on my ps
first check wether you received a valid ip address for your local network. usually, this should be something like 192.168.x.y. if so, then you might indeed face a dns issue. dns is used to resolve web site names to ip address. usually, your ip service provider will broadcast the external dns servers for your router to recognize.
try to connect with a computer first. if it works, check the ip settings. if your computer also cannot connect without explicit dns server settings you can do one of the following:
- explicit dns server address in ps3. go to "advanced internet connection settings", and then to "dns settings" and set the dns server address
- purchase a 30$ network router and hook it between your internet and the ps3. in the router settings, set the dns server address to be broadcasted to the clients. you can use 168.126.63.1 and 2 which are dns servers in korea (i live in korea), but you might want to find the server near to your location or promoted by your isp
Jul 28, 2008 | Sony Playstation 3 (PS3) Console
Dns error (80710102) on my ps3. It works wirelessly fine (but weak signal causes glitches) - but when I use a wired connection it will sometimes work fine for an hour or so and then kick me off the network...
please help me iam wired connection to the playstation 3 i have ((dns error)) but i still can make any download please help me quikly ......
engineer.sabah .talal
Apr 01, 2008 | Sony Playstation 3 (PS3) Console
Ps3 help
OK, so i just went through this whole deal and its actually not too hard, and i gaurentee you will never have to do it again...
1) hook your ps3 as a wired connection to your router, you may need to go buy a really long cable to do this if you cant move your router in distance.
2) connect it automatically through the setup and it should work fine and connect, if not then i think your fucked.
3) go to network setting > setting and connection status list, write down all the info you can which is shows.
4) unplug the LAN cable, and go back to wireless setup.
5) do a manual setup for IP settings, and type in all the info you have, but DONT type in a WEP or WPA... EVEN IF YOU KNOW YOU HAVE ONE (mine has one but i didnt need it, but if it doesnt work the first time then hell try your passkey)
6) click enter and test connection and it should work!!
hope this helps cuz i see alot of people asking the same question and i had to spend 3 hours figuring it out for myself.
Mar 12, 2008 | Sony Playstation 3 (PS3) Console
Hooking up my playstation 3 to the internet with a wireless connection
Feb 01, 2008 | Sony Playstation 3 (PS3) Console
PS3 says DNS error (80710102) when i try to connect to the internet with a wired connection
for mine i tried other fixes and they didn't work. Turns our my router had enabled security but the PS3 had forgotten the password (WEP key).
I turned off the WEP on my router and the PS3 suddenly found its connection.
To say I was getting stressed is an understatement, Sony should put something on their website, it seems like a really commonm problem to which people have no clear route to solution.
Dec 21, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
