Question about Canon Pixma MP450 All-In-One InkJet Printer
Cannon Pixma 450 Paper jam
Printer says I have a paper jam, I have checked and cannot find any jam, have tried unplugging and and even reinstalling. plz advise
  • Flockie May 27, 2008
    error on screen says the paper is jamed .clear the paper and press ok . I cant find any paper! It will not clear!
    Genius:
  • 2,035 Answers
  1. Turn the printer off and open the access cover.
  2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
  3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
  4. Watch the paper as it feeds through and try to determine where the jam is occurring.
  5. Check to see if all the rollers are turning.
    If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
    If not, there is probably a feed motor or a gear problem and the printer may require service.
  6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
  7. Turn the printer off.
  8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
  9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on May 27, 2008
  • Anand Kumar
    Anand Kumar May 28, 2008
    This may defective printer if its within warranty get it replaced or get it serviced ...............
Cannon mp282 pixma ,how to fix error code 3
The E03 code indicates (1) That the Paper Output tray is closed and you are trying to print. Open the Paper Output Tray and the printer will resume printing. (2) There is a paper jam. Remove the jam, reload the paper into the printer, then press the "Black" or "Color" button,
Dec 25, 2014 | Cannon Office Equipment & Supplies
How to correct error 5100 on a cannon pixma MP 530
I would do all of the following and see if yo can clear this code. It is not on any Canon list of possible codes, so I have no idea what it means., but let's do this:
Turn off the printer and unplug it. Remove the print cartridges. Look at them, are they leak free? Look into the cartridge holders. Are they clean?. Dried ink or blobs should be cleaned off with a little alcohol and a Qtip.
Are the little wire holders bent or broken? Do they look exactly the same?
Turn the printer back on reinstall the cartridges.Check in your printer preferences/services and clean your cartridges. Turn the printer back on reinstall the cartridges.Check in your printer preferences/services and clean your cartridges.
Now turn it off again and unplug it. Open the paper jam door and gently push the paper roller forward until it clicks. At the same time, look for even the tiniest scrap of anything in there. Close the paper jam door and plug your printer back in. Restart your computer.
If the problem is not solved. You may need to reinstall the printer. Do You have your original disc? Be sure to do a clean install. ( Turn off all running programs in the lower right corner including your virus control. Also go to Toolbar>tools>internet options>general>and delete all you cookies and temporary internet files.) Turn off and unplug your printer.
Reinstall the software. When it is finished if it has not told you to plug your print back in do so now. Restart your computer and turn your printer on.
I hope this helps. Good luck to you.
Aug 19, 2012 | Canon PIXMA MP530 All-In-One InkJet...
Please help with cannon PIXMA MP150 printer problem, when trying to print, It reads that paper is jammed but I've checked several times and no paper is jammed. Printer will not print due to this...
Hello and Welcome to FixYa!
Paper jam means their may be small bit paper jam in side
, actually there are some "micro sensors" that detect a paper jam. There will be tiny piece of paper inside those sensors, thus tripping the sensor and paper jammed keeps coming up.
To solve this first of all Open printer cover and check to make sure no paper or foreign objects obstructing the printer feeder
, If you become sure that now really there is no paper, dust or foreign objects then Turn the printer off, and disconnect the AC power-cable. Open the printer cover & now give the printer a "blow-job" by compressed air.
If still problem exist then best & final option is to just contact to any Canon Printers service provider.
I hope this solution helps you
Thank you for using FixYa!
Aug 04, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Canon MP470 keeps saying "paper jammed"
I had the same problem for DAYS and there was no paper jammed at all. I went to the cannon site as a last ditch effort & the solution below fixed it. Just clean the rollers and the link tells you how. Good luck!
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15403
Jan 04, 2010 | Canon PIXMA MP470 All-in-One Printer
Paper output slot jammed
try uninstall printer and reinstall if you have cd for (if not go to cannon web site and download them
Aug 12, 2009 | Canon PIXMA MP830 All-In-One InkJet...
I have a new cannon pixma mp140, paper feed problem
it is problem paper prasser guide adjust or paper feed sensor is missing check it and service it
Jul 12, 2009 | Canon PIXMA MP160 All-In-One InkJet...
I have a Cannon printer/copier and it says i have a paper jam
push the reset button for several minutes untill work again
May 27, 2009 | Canon PIXMA MX310 All-In-One Printer
CANNON s400 pRINTER
there is paper stuck in the printer.. remove the paper it should be between the gears and rollers (it could even be a small piece) it should work..
If not do a roller cleaning...
if that fails or the printer does not support it then move the print head all the way to the other side with the printer turned off.
unplug the printer, hold the power button down and plug it back in, press the paper feed button twice. turn the printer of and on again and press the paper feed button once.
Dec 28, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Canon Pixma MP450 All-In-One InkJet Printer Logo
274 people viewed this question
old marine
old marine
