Question about Nintendo DS Lite Console
Our ds lite keeps powering off while playing. it seems to be charged (the green light is on) and restarts ok. it happens with every game. any ideas? it is so frustrating!
  • ginal_morela Oct 03, 2010
    Well, thanks for that, but unfortunately I can't get past step 1 cuz I don't have a small enough srewdriver! I'm afraid I'm going to strip the screws if I apply too much force. Should a standard eyeglass repair type screwdriver work? Or do I need something even smaller?
    President:
  • 1,139 Answers
This unfortunately is a common problem for the DS. There can be a couple of causes to it. The first cause is a loose wi-fi module within the console itself, relatively easy to sort out. You can check my tip out on how to take apart a DS and then when the motherboard is exposed just make sure the wi-fi module is seated properly. It is located here -
The other problem could be as simple as the battery not making good contact with the terminals. Remove the battery and make sure that the pins that the battery connects to are not bent and make good contact.
The third most severe problem is that there is a problem with the motherboard. This unfortunately is terminal and the only way to solve it is to buy a new DS motherboard, usually available for around £40 on ebay. Hopefully the previous things will fix it.
Hope this helps and thank you for using FixYa
Posted on Oct 03, 2010
  • Kevin Penn Oct 03, 2010
    For the tri-wing screws you may need something smaller but really they should only be opened with a tri-wing screwdriver. If you can wait, you can pick them up very cheaply off of ebay. I would do this just to be sure you dont muck the heads up on the screws. As for the phillips screws, they are easily removed with a small phillips screwdriver.
    Hope this helps
DS Lite screen won't light up
your battery is very low. Charge the battery for 3 hours. you can still play games, while it charges.
Jan 14, 2013 | Nintendo DS Lite Console
The power light on my DS Lite keeps blinking even when its green, and I swear I have never seen that happen before, what does it mean??
A blinking green light usually indicated that your connected to a wifi connection or a ds to ds link.
Mar 07, 2011 | Nintendo DS Lite Console
What does it mean if a ds lite red light doesnt show up when you are playing it? The green light is on and plays fine but then when battery gets low the green light goes off and stays off but the red light...
This is OK the Red LED Has just gone out... simply just keep an eye on time if you think that it might die soon plug it in... there is not much that you can do to fix it.
Nov 21, 2010 | Nintendo DS Lite Console
My ds lite battery wont hold chrge, can play for
use the charger so it can be green and then you can play longer
Nov 07, 2009 | Nintendo DS Lite Console
Ds lite flashes on but fuses are ok
One or both your screens have blown.
Try removing the motherboard from the screens and attach the battery the green light should turn on and stay on.
Now attach the lower screen and turn on. If the screen is ok the screen and green light will flash and then turn off. (if the screen doesn't flash the bottom screen is you're problem and will have to be replaced)
If this happens the problem is then you're top screen which you will have to replace.
Jul 26, 2009 | Nintendo DS Lite Console
Nintendo DS Lite Broken Right Hinge & failure to stay powered on
the nintendo DS IS A *******!!!!!!!!!!!!!!!!! PIECE OF **** YOU ******* ****
Feb 07, 2009 | Nintendo DS Lite Console
DS lite, power is on but nothing happens
Ditto... except my daughter is 10. Both screens remain black, are fully charged and green light stays on for more than 4 minutes.
Sep 14, 2008 | Nintendo DS Lite Console
Ds lite charging problem
See if you can move it to a different outlet. There could be another solution. If you have 2 Ds's make sure that they're not on the same outlet. If one of the plugs is upside down, it sometimes won't work. See if these ideas will help... and by the way, i don't know why you can't play it when it's charging.
Jun 05, 2008 | Nintendo DS Lite Console
Ds lite charging lite comes on but when i press power button nothing happens
Are you leaving the DS charge until the light comes off? Remember that there are two likes too, one for charging and one for power. If you're just charging for some random period of time (lets say... One hour) then your Battery isn't going to be fully charged. The best way to ensure that your DS Lite is charged is to leave it charge until the charge light turns off. You can play your DS Lite while you are charging (I do it all the time), but it just means that you're just running off of the outlet.
A good test is to charge it fully (until the charge light comes off), unplug the charger cord (Make sure it's secured tightly to your DS while charging), then play for a little bit, your light should be a normal color (green).
If you cannot even play by using the outlet, then you need to
find a charger cord that actually works (You may need to send in the charger for replacement). If the same thing happens with 2 different batteries (assuming that you have two official Nintendo batteries).
TIP: Also run your fingers across the Charger cord. You're going to get a slight friction burn from the rubber, but you're going to get all of the kinks out of the wire in the cord. My charger cord had a similar problem (did not charge all the way, only charged until I moved the DS) but when I ran my fingers across it (pinching) it worked again.
Also check the pins in both charger cords, charging will not work if one pin is missing, nor if any are bent.
May 12, 2008 | Nintendo DS Lite Console
Power problems with DS Lite
Really sounds like a dead battery. The DS will not work if the battery is bad even when it's plugged in. You get the quick flash of the power light and that's it.
Mar 29, 2008 | Nintendo DS Console
Nintendo DS Lite Console Logo
23 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
