Question about Peg Perego 12 Volt Rechargeable Battery
HI, I HAVE A PEG PEREGO JOHN DEERE LOADER.I NEED A
HI, I HAVE A PEG PEREGO JOHN DEERE LOADER.I NEED A NEW BATTERY IT SYAS ON IT PEG PEREGO dmu 12-8 12v/8ah made by diamec, any suggestions where i can buy one? thanks andy
    Filmmaker:
    Uploaded 5 video answers.
    New Friend:
  • 31 Answers
You can get compatible replacement batteries for your ride-on toy from here.
John Deere Ground Loader Peg Perego Ride On Toy Battery 12 12 AH F2... You can just change the battery and use the plastic casing and wires attached to your current battery. This will save you a nice sum of money. It is not hard to do. Check this video to see how to do it.
Posted on Dec 22, 2014
    Genius:
  • Peg Perego Master
  • 1,508 Answers
You can order one here www.powerwheelsoutlet.com
Posted on Jun 07, 2012
  • 60 Answers
SOURCE: do I need to replace all tires on peg perego john deere
Hi!
On these, only the 2 rear wheels are the gear wheels. You will just need to replace the tires on those with the rubber ones if you choose to go that way.  Good luck!
Posted on Mar 11, 2009
  • 19 Answers
SOURCE: my sons peg perego john deere jeep only sets off
I would get the Peg Perego Gator Shifter Assembly from http://www.shopjandl.com/
Make sure the wires are secure on both motors in the back.
One time I had the same problem and I had loose wires on the motor, but I ended up replacing the switch assembly later because it would only work in 1st gear.
Hope this helps
Posted on Jun 09, 2009
  • 156 Answers
SOURCE: Peg Perego Gaucho Rock'in Worked for a minute than Stopped.
it sounds like a fuse is cutting it off.
I would contact the repair help at
They always help me with my repair problems.
hope this helps
Posted on Jul 20, 2009
mikeramesar
  • 37 Answers
SOURCE: cannot find out how to get to the battery for a
Where the front bully bar is, there is an indent in the middle , enough for your phillips head screw driver to get into, you must undo that screw and there will be a tab on either side of that panel to pull and the front bummer assembly will hinge out towards you, you can then unplug the battery and connect your charger..
Good luck!!
Posted on Dec 27, 2009
  • 699 Answers
SOURCE: new battery
A lower capacity battery (12v 8Ah) can/should preferrably be replaced by a better capacity (12v 12Ah), and usually more expensive, quality battery of the same voltage with higher amperage rating: it will in general take longer to charge but will also last longer in usage.
Please make sure that you fully charge and discharge your new battery pack a few times to 'condition' it.
Hope it helps and have fun!
Posted on Aug 01, 2010
How to change battery
you need the thing that connects to the battery and plugs into the wall. You can get one at walmart for around $40 Peg Perego 12 Volt Quick Charger for Peg Perego John Deere Polaris and...
Aug 01, 2014 | Peg Perego 12 Volt Rechargeable Battery
Prego john deere front loader wont go into reverse. it goes forward instead.
switch the wires around on the motors, it sounds like the polarity is reversed
Jan 05, 2014 | Peg Perego John Deere Front Loader
Someone gave me a Peg Perego John Deere Gator that needed a new battery.
check the battery with a multimeter and make sure that it is putting out at least 12 volts
Mar 20, 2013 | Peg Perego John Deere Gator HPX Ride on...
Peg perego john deere tractor charger indicator light does not light up and tractor does not take a charge - brand new
first of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show
any volts, lift up one side of the blue plastic housing on the top and verify that both the positive and negative wires are plugged in
Sep 02, 2012 | Peg Perego John Deere Gator HPX Ride on...
Battery connectors get hot on gator
are both wheels turning in all of the gears?
May 21, 2012 | Peg Perego John Deere Gator HPX Ride on...
John Deere Gator not responding with new battery.
I upgraded my Peg Perego shifter and it came with the wiring harness.
I bought it at http://www.shopjandl.com/
Hope this helps.
Jun 20, 2009 | Peg Perego John Deere Gator HPX Ride on...
Peg Perego 12 Volt Rechargeable Battery Logo
853 people viewed this question
Top Peg Perego Toys Experts
Adam Fjeld
Adam Fjeld
Gary
Gary
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
