Question about Dell DVD-rom DVD Drive
My dvd rom is not reading any disks.....so what should i do????
    Master:
  • 397 Answers
This may be a dirty read lens- you can clean it with kits, or if you have glasses, glasses/camera lens cleaning cloths work as well. DO NOT USE WINDEX! If that doesn't work, you may consider purchasing a replacement drive- any drive will work since you could either go external or internal. If you are still in warranty however, you can get a replacement at no cost from Dell.
Posted on Oct 03, 2010
    Sergeant:
  • 157 Answers
If your Dell System is in warranty then you can ask the service center to change it. Or if its not then you need to change the DVD Rom. You can search the ebay for this.
2 Suggested Answers
rhinoking1
  • 85 Answers
SOURCE: New DVD CD ROM Player didn't help
Try this, "start" "run" type in "regedit" click the "+" next to "Hkey_Local_machine" + next to "System" + next to "CurrentControlSet" + next to "Control" + next to "Class" click on "4D36E965-E325-11CE-BFC1-08002BE10318" in the right field, right click on "upper filters" click "delete" right click on "lower filters" click "delete" restart computer. Hope this helps.
Posted on Jun 23, 2009
Dvd rom not working propetly
Please try to insert another disk for testing.
If nothing works then try to check with another DVD rom for testing.
If the other DVD rom not working then this is registry of windows problem
If other DVD rom works then your original DVD rom is faulty.
Mar 05, 2013 | Acer Aspire 1640Z Notebook
My DVDRAM driver read all kind of disk but doesn't write DVD disk.
are you sure you have a dvd-ram drive? it sounds like you have a dvd-rom drive to me. the difference between the two is that dvd-ram drives can read and write, dvd-rom drives can only read not write
Feb 26, 2011 | Computers & Internet
My dvd rom have some difficulty to read some DVD.. But not all i can read the matrix 1 but not the matrix 3... Any suggestion
A DVD rom driver can read DVD disks only. DVD Recorded, DVD ReWritable disks cannot be read on the DVD rom driver. Acquire an external DVD RW driver to make possible any recorded digital formats readability.
Dec 21, 2010 | HP Pavilion a1630n PC Desktop
It won't see a blank disk or write to it
CD-ROM and DVD-ROM. ROM stands for "Read Only Memory". On the other hand, CD-RW, DVD-RW stand for "Read/Write". So, if the specs of your laptop say that you only have a DVD-ROM, not COMBO or something ending in RW, then you laptop's optical drive is simply not built for writing to discs.
Feb 15, 2010 | Sony Computers & Internet
I CAN NOT READ DVD
Hello my friend, Thus you Disk Rom is a DVD? if it not DVD then it cannot read DVD but if it is DVD then try to insert other DVD or CD Disk to check if it really works. Also try to clean your ROM with a disk cleaner. Then if all of the steps are done and still the result is same problem then ship it back to the suplier or buy new ROM. Thanks
Jun 17, 2009 | Samsung (TSH492BLACK) CD-RW/DVD-ROM Combo...
DELL laptop does not read blank DVDs
the combo drive you listed above is a cd-rw/ DVD-ROM....meaning that it will play and burn cd, cd-r, and cd-rw disks. the dvd rom will only be able to play dvd-rom and dvd-r disks providing they are in the proper format. check that the disk in question is not a dvd-rw or (+2) disk. the drive will not recognize that a disk is in the drive if the disk isnt compatable. try a dvd movie, if that works then a dvd-r, if that works then try a dvd-rw +1. if the last option doesnt work then you will have to stick with the dvd-rom and dvd-r, or purchase a dvd-rw drive to install.
GOOD LUCK AND DONT FORGET TO RATE MY POST!! :D
Mar 18, 2009 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
My computer will not read any of my disk or install
when you say disk did you mean hard disk? if you do... did you recenlty install a new hard disks?... if you did... did you check the jumper-master-slave configuration when installing the new hard disk?
only one hard disk can be configured as master in each ide channel. set up to master (not single) the one on the end of the ide cable and set up to slave the one attached to the midlle of the ide cable.
check that both hard drives are properly attached to the cable and that the power cable is properly seated.
when you say disk did you mean cd rom disks or dvd disks?
does it work in other computers? if it doesnt.. you cd/dvd disks may be the problem
are you trying to read a dvd disk on a cd rom only drive... you can't read a dvd in a cd rom drive.
if you cd/dvd rom drive should read the disk you're putting in, check in device manager if your system detects the cd/dvd rom drive. if it doesn't: check the physical connections (reseat ide cable, check jumper configuration for slave and master on your cd/dvd rom drive and check that the power cable is properly seated), check also in device manager the properties of the cd/dvd rom drive and check if it says on device status if the device is working correctly. if it doesn't post the error code that it may give you or google a solution with error code.
suggestion.. be more specific when posting your questions.. that way it will be easier for a solution to be provided as your issue could be interpreted in different ways
Sep 24, 2008 | HP Computers & Internet
DVD ROM
Have you tried using a lense cleaner disk?
Can you hear the disk spinning at all?
Is the problem with both cd and dvds?
What kid of disk are you trying to play? Some dvd roms will not read dvdrw disks.
Dec 28, 2007 | Dell Inspiron 2200 PC Notebook
Will not read a disc
First of do one thing u should have chek your dvd rom detected or not in bios. if it is detected then chek another disk in to dvd rom after these same problem persist you should have to replace your dvd rom.
Thanks
Dec 28, 2007 | Acer Aspire E380-UD420A (ASE380-UD420A)...
Having a trouble with my DVD-ROM - IBM ThinkPad T42
Internal the pickup assy. (the laser) there are three components that read the discs, one for DVD one for CD and one for the DVD-ROM its likely that the DVD-ROM laser has gone out. Take the drive out and get the part number and look it up online on ebay or the like :-)
Sep 13, 2007 | IBM ThinkPad DVD_ROM Ultrabay (73p3270)...
Computers & Internet Logo
69 people viewed this question
Alun Cox
