I can connect to some wireless network but not in our home WLAN, it always says web: No gateway reply. Pls help me. Thanks.
    Master:
  • 397 Answers
Try verifying your WEP key- by default, most gateways from an ISP setup WEP on their combination wireless/router/modems. If there are multiple wifi networks, you may considering shifting the channel- that is done by accessing the wireless router (I recommend via ethernet cable!) and shifting the channel to something other than 2, 4, or 11 (I usually use 3)
The usual IP's for routers are 192.168.0.1, 1.1, and 2.1
Depending on the manufacturer, it may require an user name and password- sometimes your ISP can help with that.
Posted on Oct 03, 2010
Cannot connect to wifi in psp
Hi zablancruzma,
To be able to connect your psp wirelessly you need to know the settings of your router. I've listed the steps on how to get the information on your router and Connecting your psp to the internet.
How to access the Router:
1. You need to know the ipaddress of your router. You can refer to the manual or check the Default Gateway of your computer (Make sure that you connect the computer to the router using an ethernet cable for you to get the Default Gateway). Click on START then RUN. Type CMD on the small box on the lower left of the screen. Type IPCONFIG on the black window and get the value of your DEFAULT GATEWAY (it starts with 192.168.x.x)
2. Open a Browser, Type the DEFAULT GATEWAY on the address bar of your Browser. It will ask you for a username and password. (Refer to the manual of your router or post a reply so that i can provide you the username and password of your router)
3. Go to the Wireless Settings Page of your router. Look for the SSID or the Network Name and the Network Key or Passphrase. You can personalize it so that you can easily remeber the details.
4. Make sure you connect to your SSID and enter the Network Key to make it secure.
How to connect your PSP
1. Open Psp
2. Go to Network Settings
3. Go to Infrastructure Mode
4. New Connection (then select available connection)
5. Under Wlan Setting choose Enter Manually or Scan your SSID
6. SSID (Select your SSID)
7. Wlan Security Setting (WEP/WPA/WPA2)
8. Enter you Network Key
9. Test Connection Settings
and lastly Rate me if this helps so i can help others.
Thanks for using Fixya.
Jan 31, 2011 | Sony PlayStation Portable (PSP) Console
Wireless Connection to the Internet
Hey mate,
So looking at your pda - it has no wlan build in, so you would need to get a wireless adapter for it.
Its pretty simple, install the adapter, plug it in, setup the wireless details of your home and your set to go.
Jul 03, 2008 | Matsunichi i-mat IP3230 Pocket PC
Failed to connect to the internet thr wi-fi
f Active Standby is activated on your Cell, your WLAN connection status is always visible from standby mode. The bottom line of the screen shows your WLAN status. If there are no wireless networks in the area, you'll see the message 'No WLAN network found'. If you're near a WLAN that you're not connected to, you'll see the message 'WLAN name found'.
To log on to this network, simply highlight the WLAN status line and press the centre selection key. You'll see three options:
  • Start Web browsing
  • Search for WLAN
  • Switch WLAN scan off
If the WLAN has detected then cell will open, unprotected network (and needs no passcode to access) then simply highlight Start Web browsing and press the centre selection key to go to your Bookmarks page and start browsing the web.
Hope this helps
Jan 17, 2011 | Cell Phones
Sir am trying to coneect my samsung GT-S5233W to WLAN & its all ways gieing me disconnected or Authentication failed please need help if am doin some thing wrong appreciate your kind reply
Before trying to connect to the WLAN
get the SSiD ( Network Name )
Password ( WEP /WPA )
And then try connecting to the network
If it is your home network then , Change the Security to 64 - Bit WEP
And change the Wireless Channel to ' 6 '
Change the network Name into a much simpler one ( without spaces )
Scan and connect to this network
Regards
TOM
Dec 24, 2010 | Samsung Star GT-S5233 Cell Phone
How can i activate internet on nokia E63?
Your device can detect and connect to wireless local area networks (WLAN). Using a WLAN, you can connect your device to the internet. To use a WLAN connection, you must create an internet access point (IAP) for the WLAN. Use the access point for applications that need to connect to the internet.
Use the WLAN wizard to create an access point
1. You can access the WLAN wizard directly from your home screen's information area. Another way to get to the WLAN wizard is to select Menu > Connectivity > WLAN wizard.
2. If the search finds WLANs, you can create an internet access point - scroll to the connection, select Options > Start web browsing. If you select a secured WLAN, you will be asked to enter the relevant password. To connect to a hidden network, you must enter the correct network name (service set identifier, SSID).
3. To end the active connection, select the connection > Options and Exit. If you want to define whether you want to use the WLAN or packet data connection when starting to browse the web, you can set it so that the device always asks which access point is to be used.
Set up an access point inquiry when you open the browser
1. Select Options > Settings.
2. Select General > Access point, and from Always ask - You always get to select which access point you use.
Nov 02, 2010 | Nokia E63 Cell Phone
Nokia n95 8gb connection problem
To connect to your home network via a modem you need to configure the Connection settings.
First off, go to Menu > Tools > WLAN Wiz.
Now open up WLAN Wiz. and it will automatically scan for nearby wireless networks available. Find which one you want to connect to.
If there are passwords and configurations required for it just highlight it and press Options and go to Define/Edit Access Point.
If there is no password then simply just connect.
Now you should be able to successfully connect to your home network.
Hope I have been of assistance to you,
Cheers :)
Feb 14, 2010 | Nokia N95 Cellular Phone
Nokia E61 Wifi connection
setup Internet access point for WLAN menu>tool>settings>connections>access points select options>new access points Enter Connection name Data bearer: select Wireless LAN WLAN network name: select search wlan to select wlan in range. network status: select "public" if you can see wlan in range WLAN network mode: select infrs or adhoc WLAN security mode: select same settings used by WLAN access point WLAN security settings: Homepage: select the homepage you want
now you can connect & browse the internet. hope this helps
Jul 08, 2009 | Nokia E61 Smartphone
I m havin BSNL ADSL2+ DNA-A211-1 modem..i don know how to connect my laptop wit modem in wifi mode..pls tell how to configure n connect it..modem has ethernet port oly not having usb port..pls suggest some...
Secured Wireless is better than a unsecured one. Configuring a secured wireless network easy.
· First Check it the Wireless is turned on in the modem.
You must see the wireless light glow on.
Wireless LAN (WLAN) should be Enabled before configuring the wireless network
· To make sure, if the WLAN is enabled you can check the WLAN light glow.
· If it is off, then you can be sure that WLAN is disabled.
May 27, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Limited or no connectivity
hi,
welcome sir,
what i can suggest u is that just reset the router and then install the wireless driver into ur computer and then try and connect to wireless network and hope u will be connected......good luck....
pls rate this solution..........pls...thanks
Feb 12, 2009 | Adapters.com PLANET USB WLAN...
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
