Where Is My RV water pump located?"); display: inline-block; height: 24px; width: 24px; margin-top: -1px; transform: rotateZ(-180deg);">
Generally, the water pump may be located within 2 feet of your freshwater tank. Where that sits about your motorhome is another question. By that, we mean that within 2 feet of your water tank could position the pump under a bed, cabinet, floorboard, and so on
In most travel trailers, the water pump is typically located underneath the trailer, near the fresh water tank. The exact location may vary depending on the specific make and model of your trailer.
To locate the water pump, you will likely need to access the underside of the trailer by crawling under it or using a jack to lift it up. Once you are underneath the trailer, look for the fresh water tank and follow the water lines from the tank to the pump.
If you are unable to locate the water pump or are unsure of its exact location, you may want to consult the manual for your specific model of North Trail 22RBK travel trailer or contact the manufacturer or a qualified technician for assistance.
I hope this information is helpful. Let me know if you have any other questions or if there is anything else I can assist with.
your owners manual will show location ----it is located next to holding tank in utility cubby by water hook up but check breakers and fuses and 12v supply for pump and switch if still have prolems contact rv dealer --rv repair shop for diagram or location
There should be a diverter valve switch (manual) that allows water to flow into the fresh water tank or supply city water to the RV. Some have a inline 1 way valve that prevents water going to the fresh water tank. When this valve goes bad, water is diverted into the fresh water tank. since it will not allow pressure to build up.
One way to locate the water pump is to turn on a facet and then turn on the water pump. You should be able to hear it run as it tries to "catch up" on water flow/pressure. Look where the sound comes from. You can find the water heater from outside the RV by looking at the walls for a access door that has a screen on a portion of it. This will be the location of either the water pump or the furnace. If furnace, look for another such door.
Get under the RV while the pump is running (be safe, chalk the wheels, make shure it is stable), then look for the running pump location. Once found, shut the pump, get back inside and find the compartiment where it is located (usually behind a panel that does not open by hand) use a screw drive to open it. Find the pump and ensure that you verfy the valves and all accessible fittings.
To do that use soapy water, apply it on the fittings and valves. If you happend to see bubles forming that means that the pump is sucking air from that area and does not make a 100 percent seal which will falsly lead the shutdown of your pump. Also refer to your pump manual for proper placement of your service valves.
Hope it helped!
